MCSA - Aisin 6 Speed AUTOMATIC, failed at 80K?
Old May 6, 2020 | 03:32 PM
  #551
Lex2008's Avatar
Lex2008
No warranty on those used trannys? Can you provide more background info on these transmissions? My OEM unit was shifting fine 150k miles or so then developed a leak in the main inner seal and so I opted to put in a used unit with < 60k miles and 1 year warranty. So far so good. That certainly doesn't mean valve body couldn't crap out on this one too.
Old May 6, 2020 | 04:13 PM
  #552
speedman's Avatar
speedman
I had a one year warranty on the second one but it has been in for 2.5 years
Old May 6, 2020 | 05:11 PM
  #553
Lex2008's Avatar
Lex2008
Wish I could help bro. Even the dealer doesnt repair these trannys. My local independent mini-specialist and local tranny shop don't repair them either and no one-rebuilds that I know of on the east coast. I heard about some guy one west coast that rebuilds. They just R&R them.
Old May 7, 2020 | 06:08 AM
  #554
eyeckr's Avatar
eyeckr
I've done a couple valve body swaps. When I installed my second RevMax VB I was getting codes until I double checked the fluid level which was off. If you have not already I would make sure your AT fluid is filled properly at the right level. Good luck either way!
Old May 7, 2020 | 09:49 AM
  #555
RB-MINI's Avatar
RB-MINI
Also, make sure the fluid temp is within the range specified by Aisin when checking. If it’s too cold the level will be too high and vice versa.
Unfortunately, the 1st gens don’t seem to have an OBD II trans fluid temp readout like the later MINI’s which makes it harder to set the proper level.
Old May 7, 2020 | 12:16 PM
  #556
speedman's Avatar
speedman
I have brought the fluid temp up to 100F and I have filled the trans to the level shown on the pelican parts website. I had the same codes before spent $599 for a new valve body did all the work and still have the same codes and the car stuck in 3rd gear. I can’t afford to put another transmission on it but I really want to keep the car.
Old May 7, 2020 | 01:26 PM
  #557
RB-MINI's Avatar
RB-MINI
Did you check the wiring/connector or try to reset the adaptations on the transmission control module? Not sure if it’s possible on 1st gen Aisin’s, but I’ve read it’s possible to reset the adaptations on the CVT module.
Maybe Way Motor Works knows or someone else on the forum who’s an expert with INPA/NCSExpert/DIS software.
Old May 7, 2020 | 03:27 PM
  #558
Lex2008's Avatar
Lex2008
Speedman, seems that the issue isn't the valve body if you're getting the same codes as with the old valve body and the fluid level was correct in both scenarios.
RB-MINI, good point about resetting adaptations. A trans shop put in my used trans but I doubt they reset any adaptations. I know that Autoenginuity can reset some adaptations. Not sure about the trans.
Old May 7, 2020 | 05:21 PM
  #559
speedman's Avatar
speedman
I have not reset the adaption yet. I thought since I had a code the soda the E circuit solenoid was low that the valve body would fix the problem. I am not sure that INPA software will access the TCM and that is why o started looking for someone. I am in Richmond Virginia and there aren’t any transmission shop around here that are eager to help. When you tell them it is a MC they immediately tell you it will need a new transmission.
Old May 7, 2020 | 05:24 PM
  #560
speedman's Avatar
speedman
I have put four years into getting it just right for me but I can’t afford to drop another $4800 on another transmission without trying to find out what is wrong. This is the second failure exactly the same way.
Old May 8, 2020 | 09:33 AM
  #561
Lex2008's Avatar
Lex2008
Why $4800? I think I paid $1200 for a unit with 60k miles with 1 year warranty plus installation.
Old May 8, 2020 | 10:43 AM
  #562
speedman's Avatar
speedman
The original transmission went up at 96k. The second transmission had 51k and a 24 month warranty. I got 36 months out of this one. ithe second transmission that went in cost $3150 plus $1600 to do all the work and reprogramming to swap them out. So I don’t want to go that same route again without a little more assurance that it will not happen again
Old May 8, 2020 | 11:56 AM
  #563
Lex2008's Avatar
Lex2008
why did this 3rd trans cost so much Speedman?
Old Aug 17, 2020 | 09:21 PM
  #564
jvidamins's Avatar
jvidamins
Originally Posted by GreenR53
With statements like this it proves you have no clue what your talking about.
How is removing the entire engine and trans assembly faster than dropping the pan and swapping out valve bodies?
Engine removal and re installation 8-12 hours (done it twice now)
Valve body removal and re installation 1 hour (five as today)
The '06 Mini I JUST stinking bought for my daughter like 6 days ago from a friend with 92,000 on it just slipped for the first time today a couple times. I'm going to go ahead and do the valve body replacement now followed by tranny fluid changes every 30k from here on out. Hopefully I'm able to get it running and dodge a costly bullet. I'm in South Bend, IN GreenR53. Any special tools needed to DIY this you could loan me?
Old Aug 23, 2020 | 05:35 PM
  #565
jvidamins's Avatar
jvidamins
That bentley guide link doesn't work. Here's the new one: https://bentleypubs.atlassian.net/wi...c+transmission
Old Aug 25, 2020 | 04:23 PM
  #566
jvidamins's Avatar
jvidamins
Electronic pressure control valve SLC1 fault after new valve body
So I bought the valve body from RevMax. Everything installed easy enough. Got it all buttoned up with proper ATF level with fluid at proper temperature. Reset the adaptation values using ISTA+, took it for a drive and within 3 min, it gets stuck in 5th gear and I get the following fault code: 002921 - which is the Electronic pressure control valve SLC1. I did a readout of all the Solenoid valves using ISTA+ and get mA readings for every solenoid but SLC1, which is displaying 0.00 mA. I called RevMax and they said that solenoid must have been bad (in the rebuilt, tested unit they sent me). They told me to try swapping that solenoid with the one from the old valve body I took off. Does anybody have any idea what's going on? Has this happened to anyone? Did I really just get that unlucky that I got a faulty SLC1 solenoid from RevMax??? Any help or insight would be welcomed.
Old Aug 25, 2020 | 04:37 PM
  #567
jvidamins's Avatar
jvidamins
Pics
Here are few pics...
Old Aug 25, 2020 | 06:46 PM
  #568
Lex2008's Avatar
Lex2008
Tangential question. Did you send the original fluid to be tested for wear meals by chance?
Old Aug 25, 2020 | 08:19 PM
  #569
jvidamins's Avatar
jvidamins
No I did not. It was dark and a bit burnt smelling, but I didn't find anything bad in the pan, other than the typical gunk on the magnets.
Old Aug 26, 2020 | 01:40 PM
  #570
Lex2008's Avatar
Lex2008
Keep us posted bro. Wish I could be if more assistance.
Mine was flushed for the first time at 140k miles...
Old Aug 27, 2020 | 09:34 PM
  #571
jvidamins's Avatar
jvidamins
Ok, so feel like a bonehead... I hadn't fully plugged in that solenoid, so that was an easy fix. I reset the adaptations again with ISTA+ and went through the relearn procedure of shifting between gears several times, then driving up and down through the gears several times. It seemed to be smoothing out some. But then took it out a few hours after my initial drive (which was about an hour) and it was really jumpy from 1st to 2nd (like it was trying to let the clutch out 3 quick times in a row before it finally shifted). It wasn't harsh, it just felt like it was trying too hard or something. Then 2nd to 3rd was happening a bit too early and set me into 3rd with lower RPM's than it should have, making 3rd gear start out rather bogged down more than it should (like just a hair under 2k RPM's). How long does it take for the computer to relearn as much as it's going to? At what point do I assume it's just the solenoids that need adjusting or something? Also, I read that there can't be any fault codes present for the relearn procedure to actually work. I actually have a headlight and a taillight out, so I have 2 codes in the ISTA+ system, but no lights on in the dash or anything. Not sure if that counts and could possibly prevent the relearn from happening??
Old Aug 27, 2020 | 11:47 PM
  #572
RB-MINI's Avatar
RB-MINI
This page might be helpful: https://www.sonnax.com/tech_resource...n-fwd-6-speeds
About half way down the page, between the charts and valve body pics, are some notes, symptoms, and adjustments for Aisin valve bodies. If the info doesn't apply to the your specific valve body, the site has info on other valve bodies that might.
Old Aug 29, 2020 | 11:57 AM
  #573
jvidamins's Avatar
jvidamins
yeah, I’ve read that a few times. I was just hoping the relearn process takes longer than a few drives and could potentially solve it without me having to take off the oil pan and drain the tranny fluid again...
Old Aug 31, 2020 | 06:35 AM
  #574
Lex2008's Avatar
Lex2008
jvidamins, what's the latest? You get that tranny to behave itself?
Old Sep 2, 2020 | 01:51 PM
  #575
jvidamins's Avatar
jvidamins
1st to 2nd is still a bit choppy. 2nd to 3rd still shifts, then loses RPM's a split second after the shift. Weird... Maybe it's not relearning due to the headlight being out and throwing a code into the system? How long should it take for the relearn to be complete and iron out stuff like that? Never had either of those problems before with the old valve body. Good news is it hasn't slipped and clunked since the valvebody swap!
