What can cause excessive oil consumption?
Old Nov 19, 2010 | 11:36 AM
89AKurt's Avatar
89AKurt
I know driving any car hard, and with over 100,000 miles, will cause wear.
My questions:
1. What is most likely the cause, worn piston rings, or valve guides?
2. How can it be diagnosed without tearing into the engine?
Old Nov 19, 2010 | 11:51 AM
///Mflossin's Avatar
///Mflossin
compression/leak down testing can certainly give you some data. Valve seals are typically a mileage consumable but can go earlier than expected depending on the driving conditions.
Old Nov 21, 2010 | 06:30 PM
hernlui's Avatar
hernlui
Have a buddy drive behind you. If tour car smokes under acceleration it's the piston rings. If it smokes when you abruptly release the gas, it's the valve guides.
Old Nov 21, 2010 | 07:14 PM
steve20607's Avatar
steve20607
What's excessive to you? More than a quart every XXX miles?
CardinalsRule
Jun 11, 2016 04:34 PM
molala
Oct 2, 2015 01:53 PM
David Eric Rosenberg
R57 :: Cabrio Talk (2009+)
Sep 10, 2015 12:34 PM
Sep 2, 2015 09:05 AM
