re-surfacing a head
Old Nov 8, 2010 | 09:44 AM
bcacres's Avatar
bcacres
re-surfacing a head
what is the maximum amount you can take off during resurfacing and use stock head gasket?
2005 mini s
Old Nov 8, 2010 | 11:19 AM
daflake's Avatar
daflake
From what I have heard via these forums, there is not enough there to actually skim a MINI head. Most that I know that have warped a head buy a new one.
Old Nov 9, 2010 | 07:45 AM
cristo's Avatar
cristo
Alliance Member
From the Bentley Manual:
Machine warped cylinder head.
Do not remove more than 0.3 mm (0.012 in.) of material.
If further machining is required, replace cylinder head.
The standard thickness of the cylinder head gasket is 0.65 mm.
A thicker one of 0.95 mm is available for machined heads.
Old Nov 9, 2010 | 12:41 PM
daflake's Avatar
daflake
Thanks for that... I should probably pull my Bentley out and use the dang thing.
Old Nov 9, 2010 | 01:18 PM
JIMINNI's Avatar
JIMINNI
Some people don't even trust a new head, they resurface them too, and also a new block.
Old Nov 9, 2010 | 01:25 PM
daflake's Avatar
daflake
Good point... I was only talking about thickness. I remember someone saying that the original head was too think to skim. It was read so take it with a grain of salt. The Bentley says you can take a little off so I assume this is more accurate.
NYMADMINI
Dec 14, 2016 02:33 PM
OutMotoring
Nov 16, 2015 07:04 AM
Doc Pain
Oct 28, 2015 07:09 PM
Fordgt4
Oct 10, 2015 10:42 AM
silence2-38554
Sep 28, 2015 12:19 PM
