Not a cracked head!!!
Old Nov 6, 2010 | 03:58 PM
bcacres's Avatar
bcacres
OK, short story, car overheated and was driven a few miles in that condition. Coolant started leaking into cylinder. Took head off today and thoroughly inspected it with light and magnifying glass. Found no cracks Put the straight edge to it and was gauging .4mm diag and .35 horiz. The book says no more than .1mm. I take it the head got to hot and warped and the head gasket blew from that. I will take it to the machine shop Monday to have it re-surfaced.
BTW....what it the best way to clean the old head gasket junk off the block and head without scratching the surface
Old Nov 6, 2010 | 04:40 PM
ZippyNH's Avatar
ZippyNH
So you blew the headgasket...
Have you changed out the oil to get rid of the glycol...it corrodes bearings pretty fast.
Sounds like you were lucky!!
Old Nov 7, 2010 | 09:15 AM
bcacres's Avatar
bcacres
Well, I may have jumped the gun on this one! I will take it to the machine shop and let them make that determination.
Old Nov 9, 2010 | 05:46 AM
bcacres's Avatar
bcacres
Good news, the machine shop said no crack, just needs to be resurfaced
I guess I will buy a thicker head gasket depending on how much they take off.
Say they only take off .15mm, do I buy the +.3mm gasket or just use a stock one. What are the guide lines
Filmy
15
Jun 6, 2023 06:27 AM
DevilMeTaz
R60/R61 Stock Problems/Issues
Oct 2, 2015 06:44 AM
COOPT UP
Sep 11, 2015 04:59 AM
Manny_cooper
Sep 4, 2015 08:28 AM
