cherry red exhaust manifold
Old Oct 28, 2010 | 11:43 AM
bumlebee's Avatar
bumlebee
I just changed oil in supercharger (by removing it). I have a 2004 Mini S, I put it back together & I have an irrattic idel ,& the exhaust manifold gets red hot, anyone have any clues to what I did wrong?
Old Oct 28, 2010 | 09:18 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
First off, welcome to the forum. Sorry that your first post had to be an issue like this.
No engine codes? Will the car drive ok despite the rough idle? I'd recheck the s/c vacuum line and the intercooler boots. Did you get new gaskets for the s/c to manifold and s/c to intercooler horn contact points? Perhaps this is it.
I do not know if these things would cause the red hot exhaust, but the could certainly cause the rough idle. Hopefully someone who works on these cars for a living will be able to chime in with some ideas. I also moved the thread for more exposure.
Old Oct 28, 2010 | 11:04 PM
verveAbsolut's Avatar
verveAbsolut
Glowing exhaust manifold is a sign of excessive EGT's, generally meaning you're running very rich...
Old Oct 29, 2010 | 06:26 AM
Alerious's Avatar
Alerious
Not sure if this might help you, but when I went about replacing my clutch several years ago, after we put everything back together, I had a similar situation. After some diagnosis, we discovered the boots for the IC were not sealing properly and caused a leak.
GotMINI
Old Oct 29, 2010 | 08:40 AM
apexer's Avatar
apexer
Wouldn't cherry red exhaust manifold (high EGTs) mean your running too lean?
Old Oct 29, 2010 | 09:04 AM
DICKS GARAGE R53's Avatar
DICKS GARAGE R53
Yes higher EGT's are more comon on cars running lean. Unless it is injecting so much fuel that it is still burning in the exahust system.
As for the OP's problem, make sure to re check all your work. Outside of that I am clueless of the cause. Sorry.
Old Oct 29, 2010 | 03:27 PM
apexer's Avatar
apexer
Not saying your wrong but, I've never heard of being too rich causing high EGT's.
Old Oct 29, 2010 | 07:38 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Here's the scenario. A rich mixture and a small exhaust manifold leak. All the extra fuel gets burned in the manifold when oxygen is drawn in through the leak.
For the EGT to be so high that the manifold glows red, that would take a really lean condition. On my kart the piston melted before the manifold started to glow.
Rich
Old Oct 30, 2010 | 12:27 AM
verveAbsolut
Sorry all, just got done with a diesel course and my mind slipped. Complete correct. Gasoline engine w/ glowing headers = lean. Diesel engine with glowing headers = rich.
Apologies.
Old Oct 30, 2010 | 08:04 AM
apexer's Avatar
apexer
Rich
I use to race a 1275 Midget in F/P. Tube headers would glow red and EGTs were fine. However, with the oem Mini cast header glowing red, I agree the EGTs would have to be off the scale.
Old Dec 15, 2010 | 08:48 AM
starionturbo's Avatar
starionturbo
Are you still having this issue ?
I had the same problem when rebuilding my engine.
While reading this thread, I saw that someone mentioned the supercharger and had an idea that the bypass valve was not working.
Correct! Connected bypass vacuum valve to supercharger and I got nice idle and brown exhaust again
Jan 4, 2019 12:51 PM
Aug 12, 2015 01:24 PM
Aug 11, 2015 11:58 AM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
