So My R56's Engine Went FUBAR
#76
So my brother was driving the MINI tonight and engine shuts and gives the oil lamp light then exclamation point lamp light. Car losses power. Limped it home and these are the codes I get:
P2D52
P2DCB
P2968
P2982
P2983
No oil splatter anywhere. I open the oil cover and I see a chunk of metal in there (I'll take pictures tomorrow). Car engine is gone for sure just don't know the extent of the damage. Now have to get the car towed to the dealership. I have a feeling that this is going to be a nightmare.
Anyone have insight on these codes? Thanks a lot for the help!
P2D52
P2DCB
P2968
P2982
P2983
By "oil cover" you are referring to the oil cap right? If there is a chuck of metal up there it would have to be a piece of valve I would think?
Does the car sound different at all? Try pulling the plugs and taking a peak at them and into the cylinder....it will give a good indication of whats going on in there. Anything involving a chunk of metal though...not good. Keep us updated!
#77
Were there any indicators of trouble prior to this incident?
#78
P2D52 is the code for superknock if I remember correctly...as far as the others, not sure.
#79
No indications at all. The chain tensioner was replaced 10/2010, water pump 04/2011, and HPFP 06/2011. Oil was changed every 5K. There were occasional rattles but only on cold starts and only lasted for about 1-3 mins. Didn't think it was a big deal.
Car won't start at all. Yeah, I'm gonna find out tomorrow what the damages are and extent of it. Then i guess will wait to see if they will cover under warranty or not. I just hope they don't give me a hard time like from what I've read in the forums about engine failure. I dont track, autoX, or drag the car. It's my daily driver with spirited driving and some canyon runs about 1-2x per year.
If you have exceeded where the stock rev limiter is set, you will have yourself an uphill battle. Also, depending on how the car was being driven at the moment all of the codes were triggered, you also might have another uphill battle.
Good luck though, and again...keep us posted!
#81
http://www.flickr.com/photos/minibolr56/6190663311/http://www.flickr.com/photos/minibolr56/6190663311/ by http://www.flickr.com/people/minibolr56/, on Flickr
http://www.flickr.com/photos/minibolr56/6191180678/http://www.flickr.com/photos/minibolr56/6191180678/ by http://www.flickr.com/people/minibolr56/, on Flickr
http://www.flickr.com/photos/minibolr56/6190661105/http://www.flickr.com/photos/minibolr56/6190661105/ by http://www.flickr.com/people/minibolr56/, on Flickr
http://www.flickr.com/photos/minibolr56/6191179012/http://www.flickr.com/photos/minibolr56/6191179012/ by http://www.flickr.com/people/minibolr56/, on Flickr
http://www.flickr.com/photos/minibolr56/6190659473/http://www.flickr.com/photos/minibolr56/6190659473/ by http://www.flickr.com/people/minibolr56/, on Flickr
http://www.flickr.com/photos/minibolr56/6191181222/http://www.flickr.com/photos/minibolr56/6191181222/ by http://www.flickr.com/people/minibolr56/, on Flickr
Here is the piece that is laying in the engine. There's actually 2 of them thats visible. I took one of them out for pics (sorry for pics quality - phone camera). Can you guys tell me what piece of the engine this is? The other piece is similar but just a tad bit smaller.
#82
IMG_1401 by sexyflip75, on Flickr
IMG_1403 by sexyflip75, on Flickr
IMG_1405 by sexyflip75, on Flickr
IMG_1399 by sexyflip75, on Flickr
IMG_1408 by sexyflip75, on Flickr
IMG_1410 by sexyflip75, on Flickr
Randy
#83
Hey Randy...my brother was driving the car. He said "he was shifting then the the car revved then engine shut off" and that was the end of it. The sad part was he was just around the block from home. Crushing right now since I wasn't there to witness what happened.
The more I think about it and investigate the more I lose hope about warranty coverage. I haven't taken it to the dealer yet. Hopefully tomorrow or Thursday. Too much going on at work right now.
$hīeeęT!
$hīeeęT!
#84
$hīeeęT!
$hīeeęT!
That is a tough break with you not being behind the wheel , I am sure he feels poorly about everything as well .
I dont see anything in your Sig that should give them any reason to deny warrenty but you can bet there will be a inspection of the recorded info in any event . Good luck
Randy
#85
#86
Randy
#87
Sure looks like the rocker arm to me. From the Dealership perspective they will think overspeed and will certainly look at any recorded data. But the rev limiter should prevent any damage like that.
As long as there is no tune on the engine with rev limits within spec and the engine oil is full, it seems to me the problem is just an engine failure. It happens. The rocker arms are probably one of the weakest point of any engine.
I hope it works out for you in the end.
#88
To the Gov't.
FWIW, on other car sites I've been on, members were strongly encouraged to file complaints with the US Office of Defects Investigation (ODI) @ https://www-odi.nhtsa.dot.gov/ivoq/index.cfm whenever a problem tended to become common to many members. This one seems pretty bad.
#89
Hello Everybody,
I have reviewed this complete thread and found it very insightful and worrying. Having recently replaced what I feel should have been a warranty clutch that BMW NA did not cover, I am left with a very bad taste in my mouth with BMW in general. This was a $2500.00 bill for a car a year and a half old with 23,000 miles or so.
What bothers me most about the various engine failures is the common thread of lack of oil pressure. I am sure that all of these issues that were not covered under warranty were a function that BMW NA said there was no oil and this equates to lack of owner care. Which I know is not the case here as we drive MINI's and not Cobalts. Further to this is the lack of gauges which should have been installed in the first place: Coolant temperature, oil pressure, turbo boost
With this information at hand, the oil gets checked every two weeks from now on. When we first bought our 2010 MINI Clubman, I could not wait for the (what I would consider excessive) first oil change as suggest by BMW, so I had it done at 6,000kms and will continue to do so, but not at a dealer as I simply cannot afford their rates.
Thank you for all of your insights.
Regards,
AttieCdn
Regards,
AttieCdn
#90
That's definitely a rocker arm. By your description of what your brother said when the failure occurred is that he very likely shifted into the wrong gear while going WOT (wide open throttle) and caused a mechanical over-rev. Very easy to happen if you are unfamiliar with the gearbox/transmission or not paying attention to your shifts.
Scenario (1) he was trying to upshift from 2nd to 3rd and instead shifted into 1st.
Scenario (2) he was trying to upshift from 4th to 5th and instead shifted into 3rd.
or
He was trying to downshift to a lower gear to accelerate (like when you want to overtake/pass) and instead he went into a much lower gear i.e. from 6th to 3rd or 1st.
All of the above described actions can most definitely result in an engine over-rev that will can and very often does lead to a mechanical break.
FYI, the rev limiter in your car cuts fuel (and some cut spark) only. The rev limiter does not and can not impede the rotational momentum of the valvetrain. Doesn't matter what car or engine - it's physics.
So again, my opinion is that you have the result of a driver caused mechanical over-rev.
-Arthur
or
-Arthur
#91
#92
Hummmm, sounds like regular maintenance to me. Who would have thought?
#93
Update
I got a call back from the dealership yesterday saying they were inspecting the head and will get back to me today.
Call today said they are working on the car. Cylinder head, head gaskets, valves...are being ordered and may take about 10 days or so for the car to be fixed. MOST IMPORTANT NEWS: all work being covered under warranty!
I'll keep you all updated.
#96
#97
They are different. A lifter is a part that pushes the pushrod. The pushrod sits in the lifter which moves up and down as it rotates against a camshaft. The push rod then hits the rocker arm which then opens and closes the valves.
Go to this website and it will explain it much better than I can describe it.
http://www.samarins.com/glossary/dohc.html
#98
#100
Randy
M7 Tuning
