Squeaky . . . headliner?
Old Oct 5, 2010 | 08:34 AM
ash5's Avatar
ash5
So as winter comes rolling into DC, I notice a bit of a squeak from the headliner just in front and to the right of my sunroof. I hear it on bumps and some turns. If I press the area, it is easily reproducible. It seems like it may be an area of sticky glue underneath that's not holding right. Or maybe an unclipped clip? Any thoughts or quick fixes?
Old Oct 5, 2010 | 10:52 AM
sequence's Avatar
sequence
mine did it early on, it's some kind of toggle wiring that's loose, dealer can fix it OK
Old Oct 5, 2010 | 06:00 PM
Chris G's Avatar
Chris G
My headliner/sunroof rattles and squeaks A TON. I took it to the dealer many times - seemed they fixed it each time and then it would come back in a different spot
Old Oct 14, 2010 | 01:08 PM
stouf63's Avatar
stouf63
Hi,
I got the same thing on mine. It made me sick, it was really annoying. I thought it was the sunroof but in fact, it was the headliner that hits the sunroof gasket.
I just remove the trim of the sunroof, and put some foam between the headliner and the roof. 15/20cm * 3cm, and 1mm thin.
Now, it's all quiet.
Old Oct 20, 2010 | 07:22 PM
Chris G's Avatar
Chris G
Yeah, I should probably get around to doing that on mine - I'd imagine sticking foam all around the sunroof between the headliner and the sunroof gasket would cure all of my damn rattles.
Old Jan 14, 2011 | 05:37 AM
JimRoberts12's Avatar
JimRoberts12
Originally Posted by stouf63
Hi,
could you give pointers on this. How do you get the black halo off from around the sunroof? and likewise replace it?
ToyCar
Nov 19, 2023 05:20 AM
asmasm
Aug 18, 2016 09:34 PM
jeri534
Nov 6, 2015 01:40 PM
FatherG
Sep 27, 2015 05:12 AM
IFIXEM2
Sep 18, 2015 08:47 AM
