Window not going down?!
Old Aug 6, 2010 | 08:38 PM
  #26
fishey72's Avatar
fishey72
Originally Posted by Brownshoe
So I looked on the Autozone website and it looks like they can get me a window motor assembly a lot cheaper than anybody else can. Is it a bad idea to buy it from them and try doing it myself?
From what I have read window motor is something you cannot do yourself, but I have no first hand experience. search is your friend.
It seems window not functioning can be 1 of 2 things:
1 window motor
2 BC1 module which is the computer that basically controls everything but the engine.
If you notice any other electrical gremlins it may be the later.
Link lists what the BC1 communicates with:
http://forum.minicooper.org/showthread.php?t=9924
Old Oct 17, 2010 | 07:22 AM
  #27
Dibz's Avatar
Dibz
I have to say, I absolutely love this site. My passenger window stopped working yesterday, and I just found this thread today. I went and gave it the Fonzie whack, and it worked like a charm after the 6th attempt.
Thanks to all.
Regards
Dibz
Old Oct 17, 2010 | 08:57 AM
  #28
Eric_Rowland's Avatar
Eric_Rowland
Thanks to all.
Regards
Dibz
It took you six tries? Were you wearing your leather jacket, with your hair slicked back?
Old Oct 17, 2010 | 09:11 AM
  #29
Dibz's Avatar
Dibz
The Fonzie Manuver
LMFAO..... That is what I did wrong, I tried in the Steve Erkel mode....
Old Dec 20, 2015 | 01:16 PM
  #30
TheyWho's Avatar
TheyWho
Explanation and no-cost FIX for the Fonzie Method
I was tortured by the "window not going down" problem on my 2003 and I did not want to pay for two new window motors. The thing that always bothered me about all of the different fixes (including new motors, new tracks, sanding commutators etc) was that the window ALWAYS went up, it just would not go down. If it was electrical, it would be stuck in the down position 50% of the time. Mine always locked up in the UP position.
The Fonzie method would sometimes work temporarily, but I could never predict when my windows would fail. I considered this a serious safety hazard because my son drowned when his car slid into the water after hitting a moose, so having windows that would not allow an easy escape made me a tad nervous.
One time I was poking around inside the door again to try to solve the problem when I actually found what has been torturing us all this time.
The problem is track alignment and it can be fixed in less than a minute.
On the underside of the door there is a bolt head that holds down a stepped wedge on the inside that keeps things positioned correctly. Slamming the door can cause the wedge to move one notch towards the passenger compartment and this little bit of misalignment will keep the window from going down.
THE ONE MINUTE FIX:
Use a socket wrench and loosen the bolt head 1/2 turn. Lower your window (it will magically work) and WHILE THE WINDOW IS DOWN snug the bolt back up. I have not had to use the Fonzie method ever since and I avoided the $1200 per door cost that the dealer wanted to have me pay.
It is logical, it is easy, it is free, and it lasts a long time. You are welcome.
Now since my method replaces the Fonzie method (and lasts longer), do I get to name it? Can it be called the "Derek method" (after my son) when you spread the word to other web sites? He would have liked that.
Let me know if this works for you (it will)
USNAE2
16
Jun 17, 2022 07:17 AM
bahman
Feb 14, 2016 10:29 AM
vulkandino
Oct 31, 2015 08:29 PM
semibreve42
Oct 2, 2015 09:06 AM
rt808
Sep 25, 2015 01:59 PM
