Vibration only under acceleration
Old Jul 17, 2010 | 05:19 AM
  #26
HoustonCoog's Avatar
HoustonCoog
Well I think the motor mount was my problem. I replaced the lower with the BSH Race Mount, and the upper with an OEM (couldn't get the TSW) and VIP Engine Stabilizer. WIth this setup it seems to have solved my wobble problem. I will get a better idea in the next week or two if this in fact really cured it but initially it seems to have really gotten rid of the problem. FYI I took out my lower mount and it was complete shot, before I removed it I push on the engine some and it was way too easy to move.
Old Jul 19, 2010 | 03:24 AM
  #27
FlipSmini's Avatar
FlipSmini
My lower was shot too... Hmm migh have to replace the top one...
Old Jul 19, 2010 | 02:16 PM
  #28
koyama's Avatar
koyama
Late last year I had a vibration that was related to acceleration. really noticed it passing on the freeway. Bad vibration under throttle, that would almost disappear when I let off the gas to return to cruising speed.
Long story short, replaced each front axle half-shaft. Turns out my left one was bad; the splines that engage it with the driveline were worn, so under acceleration it would cause that vibration. Since it's been replaced, no vibration.
If you've looked at everything else, including tire balance and such, have your mechanic check the axle.
Brian
Old Jul 19, 2010 | 02:20 PM
  #29
CRoth's Avatar
CRoth
Exactly what I said in a previous post.
Old Jul 19, 2010 | 03:12 PM
  #30
FlipSmini's Avatar
FlipSmini
My axels came in today so I'll be changing them this week. Hopefully it fixes it so I can take a video around the nürenburgring soon!
Old Jul 19, 2010 | 03:23 PM
  #31
CRoth's Avatar
CRoth
Very nice! Good luck with the install. It's a little time consuming but not very difficult.
Old Jul 24, 2010 | 11:36 AM
  #32
FlipSmini's Avatar
FlipSmini
Ok I got my new Axels in... I should of took pictures for a write up, but I'll just do a text one....
Shizzam, my car is runnin like a champ again. My passenger one was way jacked up there was no grease in the inner cv joint and it had a slot of play. The carrier bearing was also shot.
I'll be doing a write up soon I figured out some great tips I can pass along!
Old Jul 24, 2010 | 11:38 AM
  #33
FlipSmini's Avatar
FlipSmini
It's flipin sweet to have my mini back again! Tomorrow is the nürenburgring
Old Jul 24, 2010 | 11:43 AM
  #34
CRoth's Avatar
CRoth
God job! The only sticky parts for me were removing the axle nut (had to use an impact gun) and starting the three bolts on the carrier bearing due to the lack of working space.
Were those any problem for you?
Old Jan 30, 2015 | 03:45 AM
  #35
CoopeR50's Avatar
CoopeR50
G'Day everyone,
Just thought I would share my experience here. Recently we had a problem with our Mini Cooper where this strange vibration manifested itself in the front end of our car. Whilst the Mini was in the garage for repair I googled this problem which led me here to this forum thread.
The information I found here helped the garage diagnose the problem which turned out to be the CV joint on the lefthand driveshaft. After inspection of the CV joint, the mechanic discovered a dent inside the casing where one of the bearings had stopped rotating properly and as a result a dent or groove formed inside the casing. This is what was causing the strange vibration under acceleration. So, once the whole lefthand driveshaft was replaced, gone was the vibration. Hope this helps someone experiencing the same symptoms.
Cheers, CoopeR50
See pics:
Old Mar 24, 2015 | 10:56 AM
  #36
tragedybysyntax's Avatar
tragedybysyntax
Axle eh? I had my passenger side done in the winter and changed left / right mount. having the same problem as you guys had with acceleration on hwy, let off gas and problem goes away. I was thinking it was clutch related since the clutch is slipping and needs replaced. hmmmmmmm
Old Oct 23, 2015 | 06:11 AM
  #37
daviday's Avatar
daviday
Having the same issue.
I just checked under the car, is there supposed to be any play in the driveshaft, to and fro the case? There's a few mm of play back and forth.
Plan on doing the LCM and sway bar bushings this week. The inner and outter tierod ends have been done. After the bushings I'm not sure what else there is? I hit a nasty pothole and had blow out recently, noticed the camber is a little too positive on the drivers side even after an alignment. Wheel bearings seem to be OK. No play.
What a pain in the ***. As soon as I come off the throttle, smooth as can be. Looks as if after this all the mounts need replacing.
Old Oct 23, 2015 | 08:31 AM
  #38
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Did this all occur after you hit the pothole?
888.280.7799 | 6am - 5pm PST
Old Oct 23, 2015 | 09:58 PM
  #39
daviday's Avatar
daviday
Not immediately, but yes, all the symptoms are post pothole.
Old Oct 24, 2015 | 12:25 PM
  #40
daviday's Avatar
daviday
Just brought it to a more competent shop. Hard finding those open on the weekends...
They straightened out the alignment but said the mounts do need to be replaced. The vibration is still there while on the throttle, not as violent, but still pronounced enough.
Something else odd developed (of course), there is a squeak that's coming from what seems to be the same corner only while the clutch is engaged. If I press on the clutch it goes away. I'm guessing it's the cv axle as it's the only thing that would make sense.
Cheapest I found the mounts were for $300. I knew they were going to need to be done at some point I guess. Has anyone done the powerflex inserts? At least they look like inserts.
Old Oct 26, 2015 | 08:57 AM
  #41
PelicanParts.com
Vendor
Are you talking about the engine and transmission mounts? If so, we have them here for way less than $300. We also have a great DIY here. As for the noise, you sure it's not coming from the clutch area? It going away makes me think it's possibly your throwout bearing...
Old Oct 26, 2015 | 09:47 AM
  #42
daviday's Avatar
daviday
Thank you. That would make some sense and really really suck. I had the transmission replaced less than 20k miles ago along with a new clutch.
Thank you for the link also.
Old Oct 26, 2015 | 09:57 AM
  #43
daviday's Avatar
daviday
Edit.
Old Nov 4, 2015 | 03:54 PM
  #44
daviday's Avatar
daviday
Just to post a little update regretfully. I got the car back last night and I've replaced essentially the entire front end at this point including updating LCA bushies to powerflex. The cv's were replaced about 18mos ago when I replaced the transmission, I believe they're aftermarket but will confirm tomorrow. What I forgot to mention was the fact that my car is lowered on coils. Not super low but there's minimal wheel gap, I was never a "stance" guy but the car really looks great and felt even better for the ~1000 miles I drove it prior to this issue. I'm afraid this is going to be very difficult to correct the way I had hoped after reading everything. It seems as if once you alter the geometry of these cars all bets are off.
I know this is probably the wrong section as this is stock problems and this isn't a stock problem anymore but I'm really at a loss. I had another alignment after the LCA bushies and was really hoping I'd get my fun little car back.
If anyone has any insight as to how to correct this the right way I'd be very appreciative. I'd rather not replace the axles just to have them wear out again in a short time. I'm in this car for the long haul at this point.
Old Nov 4, 2015 | 10:10 PM
  #45
gpwpat's Avatar
gpwpat
If you are lowered nor than an inch, it changes the geometry and the axle will wear faster. My guess is you have the cheapest axles in there and they wore out quick with your ride height.
Old Nov 12, 2015 | 03:05 PM
  #46
daviday's Avatar
daviday
Unfortunately or fortunately I was wrong with what was in there. They were actually the original axles. For some reason I had thought they were replaced when the trans was replaced. Replaced the left side with a new one this week and the car has felt perfect. Finally.
Thanks again guys.
Old Nov 14, 2015 | 08:08 AM
  #47
gpwpat's Avatar
gpwpat
Glad you got it sorted out. I ordered axles and they had to be made. My axles won't be here for another week. I can't wait for the violent shakes under acceleration to be gone. By the end of next weekend I will have new brakes, bearings, axles, and all of my leaks will be sorted. My bushings and ball joints have already been replaced, so it should feel like a new car.
Old Nov 14, 2015 | 11:14 AM
  #48
daviday's Avatar
daviday
Thanks man. I'm assuming you went with the driveshaftshop guys. I looked at that but couldn't justify it. What really surprised me was how quickly it went from a slight vibration to barely drive-able. You're gonna love your car again when you get them in there if it's been behaving anything like mine was.
Old May 4, 2024 | 05:36 AM
  #49
Conrad66's Avatar
Conrad66
Vibration
Vibration
Old May 4, 2024 | 05:45 AM
  #50
Conrad66's Avatar
Conrad66
I have same issue with my mini. Mine is a 16 countryman all4. I get a vibration only during acceleration. Let off gas and gone. Seems to be coming from the rear. I don't really feel it in the steering wheel. I tried to move the drive shafts on both sides and no movement. I don't get it
