Mystery Part Help
Old Jun 5, 2010 | 01:31 PM
pyromanfo's Avatar
pyromanfo
Mystery Part Help
Can anybody help me identify what the part is here that is damaged? I've circled it in red.
No, I did not do this, but the person who did isn't working my car anymore, obviously. I'm trying to figure out if it's okay just to bend it back. Right now my car shakes somewhat when it starts up, like things are out of balance. Nope, not planning on driving it again till I can fix this.
It's a 2004 Mini Cooper S. Thanks for any help or info you guys have!
Old Jun 5, 2010 | 01:34 PM
JAB 67's Avatar
JAB 67
Its simply a heat shield. It frequently gets bent when trying to remove the oil filter, which is right next to it.
Old Jun 5, 2010 | 06:08 PM
pyromanfo's Avatar
pyromanfo
Oh ok, so it should be fairly safe to bend back then? The weird behavior on startup is what sent me looking under the hood.
Old Jun 5, 2010 | 06:13 PM
JAB 67's Avatar
JAB 67
Yes you can bend it back, but you need to look elsewhere for an explanation for your 'weird behavior on startup.'
Old Jun 5, 2010 | 06:33 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
I would pull the plugs and change what I circled.....the PCV valve. It can only be obtained from a MINI parts dept. I think they are around 20 dollars, and it comes with it's own built in bracket.
The PCV valve is very important and something even MINI Service Dept doesn't replace. And it's not because they list it as a "life time part". Merely a frequent maintenance item completely overlooked....
Old Jun 6, 2010 | 07:21 AM
chadtoolio's Avatar
chadtoolio
I think he might mean that when he starts it up, due to the firewall heat shield hitting the engine header heat shield it is rattling...
Old Jun 6, 2010 | 10:05 AM
pyromanfo's Avatar
pyromanfo
Yeah the noise went away after bending it back, thanks!
bobbiemartin
Jan 20, 2016 05:28 PM
ryGuyMCS
Oct 20, 2015 02:24 PM
Ryephile
Aug 25, 2015 06:51 AM
Super Coop
Aug 17, 2015 05:09 PM
