Same ol' cracked reservoir, air, overheat, bleed issue
Old May 20, 2010 | 08:57 AM
ingrdo's Avatar
ingrdo
Tater is a '06 MCS Convertible that is experiencing the same ol' cracked coolant reservoir, air, etc issues that seem to prevail. As a short-term attempt at fixing myself, the guy at the local shop suggested I attempt a coolant bleed myself by running in idle, adding coolant as needed until air is out.
Is that a kosher thing to do?
Thanks!
Ingrid
Old May 20, 2010 | 08:59 AM
ingrdo's Avatar
ingrdo
Follow-up question--does the reservoir need to be replaced entirely or can I use a special epoxy to seal the seam?
Old May 20, 2010 | 09:25 AM
Fatherdeth's Avatar
Fatherdeth
You need to replace the tank for reliablity issues. There are also some aftermarket tanks on the market as well. A quick way to bleed the system is to run the car at idle with the bleed screw open until a steady flow of coolant runs out, then close it. The bleed screw is located on the upper radiator hose in the front of the engine bay.
Old May 20, 2010 | 11:09 AM
Gerldoc's Avatar
Gerldoc
Or, you can do this - I put this together for us grrrls:
https://www.northamericanmotoring.co...g-coolant.html
Melanie
Old May 20, 2010 | 06:43 PM
Fatherdeth's Avatar
Fatherdeth
Melanie
Do we even know if the OP is a grrrl?
Old May 20, 2010 | 07:11 PM
gear-head's Avatar
gear-head
Agreed. There's too much pressure in it to try an epoxy repair, it needs to be replaced. I've done it twice, next time I go metal!
sevin
May 2, 2026 06:11 AM
Etrain
16
Aug 5, 2024 04:37 AM
Kimolaoha
Jul 5, 2023 01:04 PM
Indimanic
Aug 19, 2015 11:08 AM
kwijmbo
Aug 5, 2015 09:00 PM
