Timing Chain Tensioner Replacement COST??
Old May 16, 2011 | 07:25 PM
  #26
eric0919's Avatar
eric0919
I am pretty pessimistic concerning the chain tensioners on these cars just so you know. That being said, from what I've read and experienced first hand if you own a 07-09 S that hasn't had the Oct. 2010 revision of the SIM done there is a good chance you have a problem even if you don't know it.
There are to many problems and the difference between the 07 and 2010 tensioner to large for the problem not to effect almost all MCS's.
Old May 16, 2011 | 08:09 PM
  #27
nicknbecka's Avatar
nicknbecka
Originally Posted by chinisimo
my 07 cooper s was starting to make noise like that too. so I took it in. the service manager checked the oil and it looked a little low. kinda hard to tell with the way the dipstick is. so he added a quart of oil and so far the noise has gone way.
this post is making me a bit nervous as i am just over 46k miles and the warranty is about to run out. I'm debating rather I should buy the extended warranty.
for $3k to extend it for another 2 years. is it worth it?
For me, at the beginning of the rattling, it would be much more noticeable if I was a tad low on oil or if it was a day below 40°. If it were me, I'd pressure them to do the SIM 11020 test and measure for timing chain stretch. If the service manager is reasonable, I'm sure they would recognize that dealing with the problem now would be much better than having a very angry customer in 10K miles. It would be better if you could get the car to rattle again with the oil level full. Usually parking nose down for a night or two and starting on a cold morning will be the worst case.
Old May 16, 2011 | 09:28 PM
  #28
IMAMINI's Avatar
IMAMINI
Had my tensioner and chain replaced last moth at 15,000 miles with just 4 months remaining on the warranty. Chain length was out of spec. so SA advised he would replace it as well. Car actually runs smoother and feels faster. MPG actually went from 28.3 to 30.6 using same gas and same driving route. Bought an extended warranty for 5 year/100K. Now I am good, I hope.
Old May 17, 2011 | 03:56 AM
  #29
doubledown808's Avatar
doubledown808
Originally Posted by eric0919
That doesn't seem too bad. How did you know you did not need the "full monty" replacement?
Old May 17, 2011 | 09:11 AM
  #30
eric0919's Avatar
eric0919
I didn't. But I don't have the ability to do the full deal so I didn't do it. I figured the new tensioner was better than nothing.
Old May 18, 2011 | 12:27 PM
  #31
rockridge's Avatar
rockridge
Mine started to make noise. Just got it fixed last week. Glad it was still under warranty.
Old Jun 16, 2011 | 04:09 AM
  #32
minister07's Avatar
minister07
In my '07 Cooper S - I have a sputter and oil puff problem that only happens under heavy acceleration. My dealer replaced the high pressure fuel pump (no change in performance, but hey, thanks!) and then the timing chain tensioner (a little less frequent and less severe but still there). I check the oil all the time now...
Does anyone else have this problem under acceleration? It momentarily loses power and then seems like it has less until I let off the accelerator and put my foot back down again. Wondering if I need another round of timing chain tensioner - plus a new chain this time?? My tensioner was done less than a year ago.
Last edited by minister07; Jun 16, 2011 at 04:10 AM. Reason: identify the year and model of car
Old Jun 17, 2011 | 02:25 PM
  #33
shill147's Avatar
shill147
Whopping Timing Belt/Tensioner estimate
I am having the same issue with my '08 Mini S with 51,000 miles. Loud rattle upon acceleration. Dealer just quoted me $2500 to replace timing belt & assembly. After I picked myself off the floor, I inquired if Mini would help with the cost since the car is just 1,000 past warranty. Keep your fingers crossed for me. I may be looking for a Honda soon.
Old Nov 19, 2011 | 06:27 PM
  #34
rashtchr's Avatar
rashtchr
$1959 for timing chain replacement for 2008 MCS - 4 months out of warranty.
Old Nov 19, 2011 | 06:30 PM
  #35
Phx JCW's Avatar
Phx JCW
They didn't give you any goodwill? That is a lot of money right out of warranty for a known problem.
Old Nov 19, 2011 | 09:17 PM
  #36
doubledown808
Yeah, I would fight with the dealer, ask for goodwill. I Was lucky and got it.
Old Nov 24, 2011 | 06:30 AM
  #37
travowen's Avatar
travowen
Just picked mine up from the shop
After catastrophic failure, the guide rails exploded and the gear lost a tooth I finally got my car back from Greenville Mini. A big thanks to Nick since my car was out of warranty. Used my mini motoring discount 10% (ie. alliance mini, and from here). Then he split the labor with me plus a valve cleaning with those walnut husks or whatever. $1675 total repair. I spoke with the tech while he was working on my car, unfortunately he says my water pump could be next. Also showed me where to tack weld the turbo oil line so to avoid the turbo failure problem some folks have. Highly recommended a catch can as well. On the way home traveled the speed limit on the hwy for 50 miles then took the long way home while flogging the crap out of her.
Old Nov 26, 2011 | 08:12 AM
  #38
supereek's Avatar
supereek
Hi travowen,
Can you tell me more about tach-weld spot for turbo oil pipe? Why does it need?
Thanks,
Old May 18, 2012 | 07:30 PM
  #39
Minishirk's Avatar
Minishirk
Goodwill as they did it for free, or Goodwill as they gave you a good discount
Old May 18, 2012 | 07:41 PM
  #40
Sumini's Avatar
Sumini
All minis have this issue? I'm thinking about buying a mini because I just had to spend about 5k to fix my tensioner problem :( I'm ready for a gas saver and don't want costly maintenance. I'm considering a 03 jcw at the moment..
Old May 18, 2012 | 07:54 PM
  #41
minister07's Avatar
minister07
I got my dealer to goodwill a full timing chain and tensioner assembly install at 60k. I had been complaining of rattling since somewhere around 25k or 30k, and had the guides replaced already. I was told that when the guides were done, the chain measured in spec. Now being that I was a long time Saab 900 enthusiast, I thought the whole reason to put a timing chain in a car instead of a belt was to have a near-lifetime chain life... Guess not.
Old Aug 7, 2013 | 10:19 PM
  #42
just another guy's Avatar
just another guy
I don't own a mini but my girlfriend owns a 09 and for some reason her speedometer when coming to a stop ticks down to 0 then on the way up ticks till about 20mph before it smooths out.mi don't know much about minis but anything helps
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
Svejk
Feb 24, 2019 12:18 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
