Urgent!!:: Car Won't Start...Lights Don't Even Come On
  #26
Old 08-11-2022, 06:46 AM
Pubkrawl's Avatar
Pubkrawl
Pubkrawl is offline
Same problem - Any suggestions?
My 2007 is doing the same thing. Did you fix your problem? What was the solution?
5E14, 5E15, 5E16 OK now what??????
My Mini will power up when the key is turned to position 1 just before cranking, then all electrical power is loss when I attempt to start the car. The battery is new, I attempted to Jump Start and nothing. The ignition switch has been changed. No other trouble codes. The power doesn't return until the battery is either disconnected and reconnected. Or randomly returns with the key out of the ignition.
docsigns[/QUOTE]
  #27
Old 10-11-2023, 06:58 PM
Hoemr's Avatar
Hoemr
Hoemr is offline
Under
tHe hood next to the fuse box should be a box with a bolt look inside for the main fuse it might be blown
Wohnson89
06-10-2020 04:53 AM
Alkaidovich
08-10-2015 08:20 AM
Dashdog
08-10-2015 06:17 AM
tippin
08-05-2015 08:43 AM
Quick Reply: Urgent!!:: Car Won't Start...Lights Don't Even Come On
