Cracked Valve cover
Old May 5, 2010 | 08:42 AM
  #26
empire0007's Avatar
empire0007
This was done from the GT28RS Turbos. I think i will have to get the heated coating on the turbo and headers to prevent it. Also got the Thermo covers for it for now.
Originally Posted by MiniCobra
WOW empire007 you must have had some kind of heat.
Old May 5, 2010 | 09:06 AM
  #27
newbs49's Avatar
newbs49
That's some hot temps if you melted one!!!!!!!!!!!!!!!!!!!!!
Old Jul 5, 2010 | 10:52 PM
  #28
AVM's Avatar
AVM
Cracked valve cover
Hi, anybody have any leads as to where I can get a used valve cover for an R53, in good, non-leaking condition?
I boneheaded and cracked my cover replacing the coil pack. I have done much more complicated things, and I looked at it and said to myself, "how hard can it be?" So, I neglected to do the basic stuff like reading the instructions... :-(
To those who have used JB Weld to mend the crack, how is that working out long term? Would you consider that a permanent fix?
Thanks in advance.
Alex
Old Jul 6, 2010 | 04:51 AM
  #29
newbs49's Avatar
newbs49
Call Chad @ Detroit Tuned or Waylon @ Way Motors
Both are sponsors here on NAM
Old Jul 6, 2010 | 08:15 PM
  #30
AVM's Avatar
AVM
Thanks!
Old Jul 7, 2010 | 08:31 PM
  #31
newbs49's Avatar
newbs49
Hope they can help.
Old Aug 19, 2010 | 08:43 PM
  #32
skippyfish71's Avatar
skippyfish71
Originally Posted by George Hinkel
It looks like what you ordered is everything you need to do the job, and then some. I did not use the blue loctite on my bolts, the coil bolts have rubber rings that go both top and bottom on the bolts, be sure and reuse them!!!!. they will help keep the bolts in place. Also, the valve cover gasket does not call for any sealent to be applied, I have checked for leakes after putting mine back on and have found none. As for the 9-ft.lbs. of torgue, when you remove the cover bolts, check to see how easy it is to remove them, and try and only use the same pressure to put them back on. 9-lbs is not that much.
George,
Like everyone else, I did the same thing with my MSD coil pack. Luckily it was only about an 1" to 1 1/4" long hairline crack, but still enough pressure to spray oil all over the place. Short term fix, I used similar product too (Plastic Welder) and it seems to be working well. However, I'm still waiting for the excess oil (hopefully not new) to burn off. You mentioned the rubber rings on both TOP and Bottom of the msd coil pack, but the instructions for mine only reference the bottom ones. Are you saying that you re-installed the top rubber rings as well? If so, that might be the reason why mine cracked, because even though it seemed like the bolt was all the way in, it still felt really loose. So, wondering if it really was because I did NOT use the top rubber rings. Thoughts?
Old Aug 23, 2010 | 06:20 AM
  #33
George Hinkel's Avatar
George Hinkel
Skippy, I just went out to the garage to check and "Yes" I did put rubber rings on both the top and bottom of the coil. On the top their is the rubber ring, a steel washer and the bolt head. With "slight" torque on the bolts, the back pressure from the rubber rings keeps the bolt from backing out. I bought the extra rubber rings at Ace Hardware and they worked great. Geo.
Old Aug 24, 2011 | 07:12 AM
  #34
cybermini's Avatar
cybermini
I made the same exact mistake. Torqued the bolts too tight and "POP". no oil leak. Then i had a header installed and the mechanic did the same thing with a different MSD bolt and "POP". now there is a minor oil leak. priced a new valve cover ($350). I have a horizontal hair line crack about 2" long, midway up the back of the valve cover. Since the cover is its plastic is there any way to seal the crack?
09R56
Nov 16, 2022 10:49 AM
schwac2
Sep 11, 2015 11:13 AM
PaulWalliDumali
Aug 21, 2015 04:46 PM
OutMotoring
Aug 6, 2015 09:32 AM
eliseo1981
Aug 6, 2015 05:00 AM
