weird clutch issue...
Old Feb 10, 2010 | 03:49 AM
m3456y's Avatar
m3456y
My GF was using my Mini for the last few days....she owns a manual shift boxster, so she drives a stick all of the time. Coming home from work, she noticed difficulty shifting into first and second and last night, when she stopped to fill up the tank - she could not get the car in gear. She shut the engine off, and then could engage first, but not with the engine running...so I figure clutch something...maybe master cylinder?
Anyway, I drove to pick her up, got in the car, started it and it was perfectly fine....all the way home and driving it later that night.
Any idea what might have caused this? She's afraid to drive it now - thinking it may happen again.
Old Feb 10, 2010 | 11:48 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Your MINI was jealous......and probably just missed you.
Old Feb 10, 2010 | 01:30 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Check the slave cylinder, these are the most common problem with the clutch hydraulics. It could be leaking and bleeding off pressure. Pop off the lower engine cover and pull the boot off the slave to see if fluid runs out.
Old Feb 10, 2010 | 02:04 PM
m3456y's Avatar
m3456y
Thanks for the insight....I'll check that. If leaking, would the clutch suddenly work fine again?
unxpectederror
Oct 22, 2015 12:16 PM
Sep 23, 2015 12:59 PM
Sep 23, 2015 12:52 PM
Sep 22, 2015 02:05 PM
Sc00terbum
Sep 11, 2015 07:17 AM
