coolant issues
Old Nov 29, 2009 | 05:01 PM
proppjones's Avatar
proppjones
coolant issues
I've bee loosing antifreeze - no-apparent leaks around the expansion tank seams-
I filled up the tank to the correct marks and started her up. no leaks around the thermostat housing as best as i can tell. I started up the car, looked under the car and noticed drips of fluid dripping around the power steering pump and fan area. As the car warmed up the dripping stopped - Any ideas? Now I'm concerned that I've put the power steering pump and fan in jeopardy. Any ideas?
Old Dec 6, 2009 | 11:18 AM
proppjones's Avatar
proppjones
Leak fixed
I took LiL MIN - to the dealer to have the problem checked out - I knew it wasn't the expansion tank. But was concerned it might cost $$$$. Matt Page of Patrick Mini said they would take a look and see what they cold find. It turned out to be a problematic thermostat and gasket. Plus I got my oil changed and break lines bled. No charge- the Service Department @ Patrick Mini (Schaumburg IL.) has been great. and I'm back on the road.
Old Dec 7, 2009 | 06:37 AM
Bajanmini's Avatar
Bajanmini
Not to hijack this thread,is Redline water wetter worth it to add to your coolant,or is it just a gimmic,doing a rad flush and refill this week. Thanks
Old Dec 7, 2009 | 09:18 AM
kazlot's Avatar
kazlot
Coolant Issues
Originally Posted by Bajanmini
....is Redline water wetter just a gimmick?
No, it's not a gimmick.
Hope this helps...
Old Dec 7, 2009 | 04:54 PM
Bajanmini's Avatar
Bajanmini
Fine it's not a gimmick,but i would love to know what it will do that a gallon of Zerex G-05 will not.
Old Dec 7, 2009 | 05:24 PM
not-so-rednwhitecooper
You can read more about it here or here.
Old Dec 9, 2009 | 05:14 AM
Bajanmini's Avatar
Bajanmini
Thanks for your informative reply.
Old Dec 19, 2009 | 08:21 AM
BRG06's Avatar
BRG06
Thanks to this forum I started checking by coolant level in the expansion tank just to see if I was losing any before my warranty period ended. About a week before the 3yr/36000 was up I noticed a drop in the reservoir level. I couldn't see any obvious leak and called the dealer to make an appointment a day before my 3 yrs was up. They took it in replaced the thermostat/gasket with an upgraded part and were at least honest enough to admit there have been coolant problems with these models. While I do appreciate the honesty, it would have been great if they issued a recall and replaced the units before a possible major engine issue occured. Thanks for all the good information posted on this board!
Old Jan 23, 2010 | 12:58 PM
ngi0811's Avatar
ngi0811
Crack in Thermostat
My 02 MC with 60K has been losing coolant. Brought to dealer and need to replace cracked thermostat....only $450...such a deal.
Old Jan 23, 2010 | 01:51 PM
ZippyNH's Avatar
ZippyNH
I really hope you had other work done.....it is a pretty simple job.....and the parts are pretty cheap.
Kimolaoha
Jul 5, 2023 01:04 PM
speedyg56
May 18, 2020 08:52 AM
W0TM8
Dec 19, 2019 07:50 AM
Steffen.Johnson
Aug 23, 2015 08:30 PM
tylewis
Aug 18, 2015 06:53 AM
