Bad news: Apparently, 2010s also suffer from cold start rattle
Old Sep 8, 2009 | 04:36 PM
  #26
bssiesmth's Avatar
bssiesmth
I got the rattle today again.i was able to record 10 seconds of it. Ill clean up the recording a bit And upload it.
Old Sep 8, 2009 | 06:03 PM
  #27
bssiesmth's Avatar
bssiesmth
Originally Posted by sequence
You mean R56 issues, I believe. Engines between the two are completely different. I had an R53 and while the Tritec engine was rock solid, everything else that surrounded it was crapola.
Next time U park nose-up and do the 3K shutoff bump as described above and see if that helps. Shoot try it nose-down and see if that helps as well.
No, I had a 2005 R53 which had both driveshafts destroyed and its gearbox, too.
That one spent 3 months or so at the dealer the two years I owned it. The story is around here somewhere, actually.
Old Sep 9, 2009 | 05:40 AM
  #28
sequence's Avatar
sequence
yeah I had major problems with my 05 S's CV joints and axle shafts, more reasons why it had to go.
Old Sep 9, 2009 | 05:41 AM
  #29
sequence's Avatar
sequence
Originally Posted by 10Zero
I know...just being a smart ***.
Too bad NAM doesnt have a "smart ***" simile...
Old Sep 10, 2009 | 05:53 AM
  #30
Robin Casady's Avatar
Robin Casady
Originally Posted by budoboy
I thought they had a fix for this in mid '09? I think my late '09 model does it too but actually it doesn't really bother me.
It should bother you. It needs to be fixed. It will damage the timing chain, and could eventually destroy the engine. Anyone who has this start-up rattle (sounds like a chain being dragged over metal, and changes with rpm) should get it fixed ASAP. Until you do, try to keep it below 2,000 rpm until the rattle stops.
My 2007 had it on rare occasions. MINI of Mountain View fixed it without charge, and gave me a Clubman to drive for the week they kept it.
Old Sep 10, 2009 | 06:19 AM
  #31
bssiesmth's Avatar
bssiesmth
I've been parking the car nose-up and the rattle is gone.
PRoblem is, the audio I recorded doesn't show a thing. I need to start parking the other way around...
Old Sep 30, 2009 | 08:36 AM
  #32
punkgeek's Avatar
punkgeek
Will I know if I have the rattle?
So just how obvious is this rattle? I have a 2007 MCS that I purchased used (so I'm a bit of a noob). It has about 21K miles on it, and I don't hear a rattle.
I'm I just one of the rare lucky ones? I just hear a slight sewing machine sort of noise from the valves as the engine idles - a bit more pronounced than when warmed up but nothing dramatic.
Am I right to assume that if/when my car develops the rattle it will be _obvious_? Or do I need to be a bit attentive to hear it.
Old Sep 30, 2009 | 10:08 AM
  #33
grodenglaive's Avatar
grodenglaive
no, the sewing machine noise is the direct injection and is normal. The cold start rattle is a loud horrid thing that you can't mistaken for anything else. Mine only did it a couple times, but I was lucky enough to get the timing chain and tensioner replaced anyway.
Old Sep 30, 2009 | 07:25 PM
  #34
skimmilk's Avatar
skimmilk
So from my understanding the cold start rattle is loud enough to hear from the inside? I opened my windows this morning and my engine sounded rougher than when I drive it in but I never paid much attention to it. But compared to the youtube videos, it doesn't seem at all simlar.
Old Sep 30, 2009 | 07:49 PM
  #35
Benibiker's Avatar
Benibiker
I think a lot of people are confused with the engine noise they're hearing. Most may be normal...
Old Sep 30, 2009 | 08:16 PM
  #36
Robin Casady
Take a bicycle with a really loose chain, hold the rear wheel off the ground and pedal it really fast. Now hold an enpty gas can against the chain. That's what it sounds like.
The sound increases with rpm. If you have the radio going when you start up and weren't paying attention to the engine, you could miss it. If you listen to the engine for the first minute of driving, you'd notice.
Old Oct 2, 2009 | 06:15 AM
  #37
sequence's Avatar
sequence
Yes it is-- open yr glovebox next time it happens and hear for yrself. If U record the sound, do it inside, too much ambient noise outside, bonnet up, with all the DI noise as well...
RC's description is accurate. Mine would be taking a ball-peen hammer and smacking it against something metal.
Old Oct 11, 2009 | 08:55 AM
  #38
bssiesmth's Avatar
bssiesmth
I got a clear recording of it and I burned it into a CD.
Something I've noticed - the noise is getting louder everytime. First it was barely audible - now it's really noticeable and bothersome.
Then again, I'm still waiting for an appointment from Mini. I think I'll just drive by tomorrow and drop the car off and tell them to fix it immediately.
sevin
May 2, 2026 06:11 AM
iggi
18
Feb 9, 2026 01:00 AM
Melvinyip
Apr 17, 2020 09:28 AM
TREX
Nov 2, 2019 07:31 PM
alistaircookie
Oct 8, 2015 10:52 AM
