Low Speed Fan Resistor - we need solution
Old Jul 22, 2019 | 01:55 PM
  #1501
USNAE2's Avatar
USNAE2
Veteran: Navy
I went to 2M school in the Navy, 5 weeks from repairing holes in boards, laying traces and soldering the whole 9 yards. Had a B level certification...was funny my Dad was an A and an instructor when he was in the Navy (ETCS 20yrs) and when he was a civilian. He used to keep me certified RIP Dad.
Old Jul 22, 2019 | 03:44 PM
  #1502
Cruztpirate's Avatar
Cruztpirate
Sweet baby jebus
Despite my doubts, it works
Old Jul 23, 2019 | 07:04 AM
  #1503
Andy_S's Avatar
Andy_S
Originally Posted by pnwR53S
No kidding. Like the 737 Max.
Soldering workmanship spec. There ought to be a GA equivalent of this.
Or this: https://nepp.nasa.gov/docuploads/06A...STD-8739.3.pdf
Old Jul 23, 2019 | 07:45 AM
  #1504
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
It is not about if it works or not. It will work unless you buy a undersized resistor. The point is what implication is the hack that you are so in love with down the road, for yourself and worst the next owner. Exposed high current 12V wiring is a major hazard
WRT soldering and wiring workmanship specs, most derive or cite MIL-STD_2000 and most if not all technical training schools use and refer to it for their training and certification courses.
FAA has EWIS but it deals more in the design rather than technical workmanship that is carried out in repairs and manufacturing.
Even if you are not doing something in aviation there are many pertinent good workmanship practices from the said specs that you can benefit. For the low speed fan resistor, I would rather buy a $15 communist made replacement instead of doing my own hack.
Old Jul 23, 2019 | 12:33 PM
  #1505
USNAE2's Avatar
USNAE2
Veteran: Navy
I am supremely confident in my abilities as a Journeyman Aviation Electrician. I have expert soldering skills and currently solder components as small as 201 (SMT) under a high powered microscope. I used 14AWG wire and is rated to 32A (should be more than enough). Soldering is more secure than mechanical connections and I have high temp heat shrink over both ends of the resistor (which are also soldered). Been doing electrical/electronics for over 30 years have a little bit of talent and knowledge.
Old Aug 3, 2019 | 12:19 PM
  #1506
Mereco's Avatar
Mereco
I have 2005 mini Cooper s with automatic climate ac button lights up but no power at
Low speed fan , ac system not low on freon should I jump the AC pressure switch or replace the coolant temp sensor ?
Old Aug 3, 2019 | 01:12 PM
  #1507
ChiggerPepi's Avatar
ChiggerPepi
Check the compressor clutch coil resistance first.
Old Aug 14, 2019 | 04:03 PM
  #1508
tej98's Avatar
tej98
So my 2005 R53 had the burnt out low speed fan resistor issue, so I ordered this:
https://www.amazon.com/Amico-Aluminum-Chassis-Wirewound-Resistor/dp/B008MLKUCC/ref=sr_1_1?rps=1&ie=UTF8&qid=1455378622&sr=8-1&keywords=100W%20Watt%200.33%20Ohm&refinements=p_85:2470955011&tag=vglnkc6797-20 https://www.amazon.com/Amico-Aluminum-Chassis-Wirewound-Resistor/dp/B008MLKUCC/ref=sr_1_1?rps=1&ie=UTF8&qid=1455378622&sr=8-1&keywords=100W%20Watt%200.33%20Ohm&refinements=p_85:2470955011&tag=vglnkc6797-20
Installed it using 16 Gauge wire. Everything seems to work fine, but the resistor gets very hot to the touch. After the fan running on low speed for about 2 minutes (resistor has not been mounted anywhere just yet, just testing for now) I can't touch the resistor for more than a second without getting burnt.
Does this sound normal? Should I just bolt it up to the transmission mount on the driver's side of the engine bay and not worry about it? Do I need to add the thermal paste under the resistor before I bolt it to the mount?
Thanks!
Old Aug 14, 2019 | 05:19 PM
  #1509
SupeR53's Avatar
SupeR53
Definitely use thermal paste, with the amount of current running through the resistor, it WILL heat up (that's a fact of electrical resistance), keeping it thermally shorted will increase the life of the resistor. I bolted mine to an aluminum plate and the plate to the front aluminum chassis just behind the grille, so I've got airflow across the heatsink fins as well as a large thermal sink.
Old Aug 14, 2019 | 08:57 PM
  #1510
tej98's Avatar
tej98
Thanks! I added the thermal paste (found some laying around from previous project) and bolted it down to my transmission mount. I'll do some more testing to make sure it doesn't burn anything down or cause any issues.
From reading this thread it seems the green Amazon unit I purchased is not as good quality as the gold Arcol units from a few years ago. Does anyone know where I can still buy the gold Arcol units? I'd like to keep a spare resistor around in case my green one goes out.
I am also thinking about finding some heat sinks I can stick on the outside of my green resistor to help dissipate some of the heat. I'll keep the thread updated with the heat sinks I buy so maybe we can continue to reliably use the green Amazon resistors since they are easier to find.
Thanks again!
Old Aug 15, 2019 | 07:04 AM
  #1511
SupeR53's Avatar
SupeR53
Try Allied Electronics or Mouser Electronics, they're not cheap, but they usually have everything either in stock or a couple of days out.
Old Aug 18, 2019 | 07:37 PM
  #1512
tej98's Avatar
tej98
Thanks! I'll keep an eye out..
Old Sep 7, 2019 | 05:25 PM
  #1513
Mereco's Avatar
Mereco
done
Old May 3, 2020 | 05:53 PM
  #1514
mr.r50's Avatar
mr.r50
Fixed mine and i thank everyone who posted solutions
Everyone should fix these before they blow
Old May 4, 2020 | 05:37 AM
  #1515
ewgoforth's Avatar
ewgoforth
What are these?
Old May 4, 2020 | 02:13 PM
  #1516
shrevemini's Avatar
shrevemini
Top Answer: 1
Next to the radiator fan on the passenger side. You need to out car into service mode to get to it. Mine was all busted up..
Old May 4, 2020 | 10:04 PM
  #1517
mr.r50's Avatar
mr.r50
Originally Posted by ewgoforth
What are these?
it’s what this whole thread is about, the easy way to fix a working fan , by replacing the resistor
Old Jun 4, 2020 | 07:44 PM
  #1518
james77515's Avatar
james77515
Tapping relay does not turn off fan
Is this still the problem with the fan if tapping it does not turn off the fan?
Old Jun 4, 2020 | 08:09 PM
  #1519
james77515's Avatar
james77515
If the fan does not turn off after tapping the relay is this still the most likely reason for it running?
Old Jul 20, 2020 | 08:41 PM
  #1520
jnelson25's Avatar
jnelson25
Hi still have my 2006 R53 with the low speed fan resistor fix outlined by Chris Lamb and it is still working perfectly. I think it has been about 8 years since I did the fix.
Old Jul 21, 2020 | 04:19 AM
  #1521
nd-photo.nl's Avatar
nd-photo.nl
I found that the brand Blue Print also does the exact same part under partnr: ADB111402
Fortunately, Blue Print is readily available in the EU, which is good news for me
Old Oct 23, 2020 | 09:44 AM
  #1522
Teke14's Avatar
Teke14
I found the answer
Old Nov 24, 2020 | 04:03 AM
  #1523
nd-photo.nl
I replaced mine just yet, I already ordered the "old style" resistor. Mine was also shot (2006 model).
Old Jun 9, 2021 | 06:59 AM
  #1524
Teke14's Avatar
Teke14
This maybe a silly question and I think I know the answer but in the resistor replacement in post 867 does it matter what side of the resistor each one goes to?
Old Jun 9, 2021 | 07:44 AM
  #1525
LordOfTheFlies's Avatar
LordOfTheFlies
It does not matter which direction.
