Metal squeaking in gear box when getting on first gear???
Old Aug 16, 2009 | 11:15 AM
Fr33zy's Avatar
Fr33zy
Hey guys
When I'm getting off first gear, I always hear this metal squeaky noise in the gear box area where the shifter is.
Not sure if this is a problem or normal or worse.. a sign of something bad is happening..
btw, I have an O3' MCS.
Any ideas?
Old Aug 19, 2009 | 01:23 PM
cmc-nick's Avatar
cmc-nick
Happens when you are accelerating in 1st gear, changing to 2nd gear or?
Old Aug 20, 2009 | 04:55 AM
Fr33zy's Avatar
Fr33zy
accelerating in 1st gear on the initial 1000 rpms.
Old Aug 21, 2009 | 08:50 AM
Fr33zy's Avatar
Fr33zy
anyone?
Old Aug 28, 2009 | 01:35 AM
Jephen19's Avatar
Jephen19
I'm guessing you're referring to the "chewbacca" noise. If you run a search you'll find several threads describing something similar. Somewhat a common fault with the manual R53 mcs.
From what I've read, some people had to change out a flywheel and/or clutch. For some that fixed it for good, others only temporarily.
Others just left it as it is and learned to live with the sound. Mine does this from time to time, more frequent when parked in the cold overnight. I would get it once about every other week. It would go away after 1st gear is engaged for the first time. I even got it once when revmatching and letting the clutch slip a bit to long in higher gears.
Seems to be a glazed flywheel issue, from what most people are reporting is the culprit. It doesn't harm the car if left untreated from what I've been hearing. Hope that helps.
Old Aug 28, 2009 | 05:47 AM
Fr33zy's Avatar
Fr33zy
man, I can thank you enough for the info. I thought it was something bad to come, (which it maybe) but now at least I can pinpoint the issue.
eliseo1981
Jan 28, 2021 02:45 PM
blackie
Jan 18, 2017 09:56 PM
Mini-Hype
Aug 17, 2015 06:32 AM
