High RPM Engine 'Buzz'
Old Aug 12, 2009 | 08:10 PM
rrcaniglia's Avatar
rrcaniglia
I DO NOT know that I have a problem. Would like to know if this is abnormal or not. When the engine crosses 5500rpm heading for 6k, I get buzzy feedback from the wheel and foot feed. She accelerates smoothly through 5k and then builds a buzzzzzz, a high freq vibration.
Power is not affected. Good pull throughout. Just a buzzzzzzz in the range described. Not noticed in any other rpm range.
MC has 1900 miles and I coddled her during break-in. Seldom go above 4 or 4.5k rpm, so I have little knowledge of what is normal up there.
R
Old Aug 15, 2009 | 02:53 PM
grodenglaive's Avatar
grodenglaive
My R56 did a similar thing when it was new - but only when the AC was on. Strangest thing. The sound went away after I fixed some other rattles in the dash. Also, there was a plastic cowling under the bonnet near the break fluid reservoir that was not installed properly. I had fixed that around the same time, so it could have been that that was vibrating.
Old Aug 15, 2009 | 03:00 PM
rrcaniglia's Avatar
rrcaniglia
Appreciate the thought. Will check out the a/c link and look for other items you noted.
R
Svejk
Feb 24, 2019 12:18 PM
David.R53
Sep 1, 2015 06:49 PM
DWooderson
Aug 20, 2015 04:31 AM
stellaherself
Aug 14, 2015 05:28 AM
wind715
Aug 11, 2015 07:56 AM
