Is 220 degree water temp typical for 2007 MCS?
Old May 14, 2009 | 05:02 PM
jeffm5150's Avatar
jeffm5150
Hi all--
I've got a 2007 MCS with ~ 9000 miles. I've had no problems with the car until yesterday. The CEL was set yesterday due to P2187 (system too lean @ idle) then the CEL was set today due to P0420 (catalyst efficiency too low).
During a 30 minute highway drive in 100 degree ambient temps today, the P0420 code was set. I got home 6 miles later and scanned the car. I cleared the code, then checked the operating parameters, and the coolant temp was at 220 degrees .
Is that normal operating temp for these cars? Without a water temp gauge, I'm a little unclear as to what's 'normal'.
Oh, and the car has both a turbo-back exhaust and aftermarket intake. It's possible that one or both of these is responsible for the CEL, but not sure about the coolant temp.
Thanks for any input.
Jeff
Old May 14, 2009 | 05:21 PM
Oxybluecoop's Avatar
Oxybluecoop
According to the MINI TIS 170-240 are normal operating temps.
Old May 14, 2009 | 06:17 PM
iwashmycar's Avatar
iwashmycar
ive hit that in 30 degree weather just stuck still in traffic. i could see it in 100 degree weather definately. Never been over 122 though
Old May 15, 2009 | 09:01 AM
Browser_23's Avatar
Browser_23
I have an 09 MCS and regularly see 220 on my scan gage
Old May 15, 2009 | 12:12 PM
pilotart's Avatar
pilotart
220f (104c) is what my MCa regulary runs also.
Old May 19, 2009 | 11:07 PM
ThumperMCS's Avatar
ThumperMCS
Yup...
Mine stays between 220-225....unless the A/C is put on high, then it shoots down to 165-175 ish.
Old Jun 2, 2009 | 03:32 PM
jproz's Avatar
jproz
After just finishing my water temp gauge install (stewart warner w/ cravenspeed hotlink), I'm also seeing higher temps... A spirited drive (no A/C) I was running 230-240...
Old Jun 2, 2009 | 06:35 PM
Mach V Dan's Avatar
Mach V Dan
Mine runs around 230 according to my PLX digital gauge. I think I read somewhere that the water thermostat is supposed to open at 230.
That's very hot compared to a lot of older cars. I assume this is new, higher-pressure cooling technology...
--Dan
Mach V
Old Jun 2, 2009 | 07:07 PM
old81's Avatar
old81
M6
Thank you, I asked about this elsewhere in the Rev. discussion.
You all confirmed what I see in Rev. 219-223 with the Plex Wifi sending the data.
So, 220 would be ok and it appears others are seeing 230. I suspect the spirited drivers.
Old Jun 2, 2009 | 09:35 PM
ThumperMCS's Avatar
ThumperMCS
Not exactly sure what temp the aux cooling fan kicks on but I have typically seen it kick on above 230, and then the temps go back down at which point it shuts off. If you're seeing temps as high as 240...seems oddly high to me...
Old Jun 28, 2009 | 12:32 PM
masterd78's Avatar
masterd78
MANIAC
I also run in the 220-225 range, and when it hits 230 the fan kicks in and cools it down pretty dang quick.
Old Jul 8, 2009 | 01:48 PM
Ottoman_FD3S's Avatar
Ottoman_FD3S
Jeff
most deffinately..
if the exhaust has removed the oem cats and is catless.. or the current cat on it is not effecient enough
it can deffinately throw a code
Old Jul 8, 2009 | 01:57 PM
jproz's Avatar
jproz
After several weeks of having the gauge on .. 220-225 (never above 230) is my standard. I must have misread the gauge initially.
Old Jul 8, 2009 | 04:28 PM
slinger688's Avatar
slinger688
Originally Posted by Ottoman_FD3S
most deffinately..
Jeffm5150,
Ottoman_FD3S is quite right about the source of your CEL code. The CEL code may hve nothing to do with the running temperature.
Some aftermarket vendors have had trouble with their turboback throwing CEL codes, catless or with aftermarket cat. I think you may have installed one of those down pipes. There has been some fixes tried but the code seems to comes back eventually. Another vendor, Riss, seems to be working on an o2 sim that seem to correct the code. However, only time will tell.
Did you lose power when the CEL code comes on?
I think it is quite unlikely that the CAI is the problem.
Old Jul 8, 2009 | 06:23 PM
Robin Casady's Avatar
Robin Casady
Usually runs 222F. Occasionally up to 225, but for brief periods. Measured with a ScanGaugeII.
Old Jul 13, 2009 | 09:52 AM
unclemeat's Avatar
unclemeat
I saw 220 on the '08 MCS and currently see 220 on the '09 JCW. -Scangauge
I wonder if it is because cooler EGTs from direct injection require the engine to operate hotter than the average car?
One thing and as just a precaution; make sure your fan fuses arent popped.
Old Jul 17, 2009 | 01:39 PM
Roberth891's Avatar
Roberth891
BullyDog WatchDog
I have the same concerns about an engine running at 220 with no coolant temperature gauge. I found a device that connects to the OBD connector under the instrument panel that reads the serial data stream from the PCM. It is user configureable and shows 4 different sensor readings at the same time. It even shows the boost from the turbocharger. You can see it on sale at Autoanything.com right now for 239.99. It's very simple to install and configure.
Old Jul 17, 2009 | 06:22 PM
Robin Casady
The ScanGaugeII will do all that for $169.
220 F is a normal operating temp for the MINI.
Old Nov 15, 2009 | 04:05 AM
ChrisNJ's Avatar
ChrisNJ
I am running at 220 degrees using ScanGuageII.
Old Feb 7, 2010 | 06:40 AM
netma1000's Avatar
netma1000
Mine is staying between 220 and 225.
Old Feb 7, 2010 | 07:46 AM
sequence's Avatar
sequence
Scangauge II has dropped down to $159
Old Feb 11, 2010 | 01:22 AM
Thegasteck's Avatar
Thegasteck
2008 Cooper S, Scan Gauge II, 220 - 235. VERY Spirited driver.
Old May 23, 2010 | 04:01 PM
rtwerk222's Avatar
rtwerk222
I'm running from 222 to 227, never seen it higher but then summer has not set in and I'm not running my AC.
yet. I'm using the Insight CTS from Edge
http://www.miniutah.com/album.php?al...tachmentid=189
Cereall
Sep 5, 2019 06:05 PM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
mini-medic
Aug 18, 2015 09:13 AM
tylewis
Aug 18, 2015 06:53 AM
bleonard1401
R60/R61 Stock Problems/Issues
Aug 10, 2015 02:15 PM
