Acelerator vibration
Old May 5, 2009 | 01:16 PM
Dan Mini 21's Avatar
Dan Mini 21
I have an 03 MC CVT....My accleerator has a pretty mean vibraton coming from the pedal..The vibration is pretty constant under torque or not (downhill)...What can i do to stop it..it is very annoying ..Do i need to replace the whole assy or is there some rubber part that wore out or?...Help...
Old May 5, 2009 | 07:09 PM
herbie hind's Avatar
herbie hind
try to eliminate things like have wheel balance checked ; look real good at tires to be sure there are no bubbles on sides or split chords ; then try going to nuetral to see if it's coming from cv's and not powertrain . put in clutch . try different things to see if you can narrow it down .
Old May 10, 2009 | 09:33 PM
Dan Mini 21
Accelerator pedal vibration
Well I have been trying to eliminate it...I don't think it is tire balance and it goes away when i rev it in neutral...It is a very fine vibration and very annoying...I might have to go to the dealer and see if they can check the whole accelerator unit...I think it is coming from the post behind the pedal and not at the base..Any more ideas ?....
Old May 11, 2009 | 06:54 AM
herbie hind
so in neutral no vibes? when going down road vibes? if you depress clutch while going down road and rev?...... it sounds like u eliminated the engine as the culprit , and since the throttle is electric and not cable or rod there's none there from engine , sooooo my guess is tranny to rest of power train like output shaft or inner cv or outer cv or lower control arm bushing .
Old May 11, 2009 | 10:21 AM
Dan Mini 21
Acellerator Vibration
Yes going down the road is when it Vibs...In neutral no vibs..Remember i have a CVT trans not a 6 speed...The Vibration comes and goes which makes it difficult to diagnose..I am going to find out if its the addelerator post or at the base of the pedal..I am still trying to find out what it is..thanks all....
Old Mar 31, 2011 | 11:51 PM
Dan Mini 21
Accelerator vibration 03 R50 CVT
Well i am still trying to narrow this vib in the accelerator down...I did the top hydraulic mot mount and tomorrow i am doing the lower motor mount from WMW OEM part...I hope this fixes this.If not i plan to pull the accelerator and then the mount plate and bolt and investigat whats going on there...Maybe a rubber washer under the bolt will fix it..I hate this vib in the pedal it Sux...Thanks Dan
Filmy
15
Jun 6, 2023 06:27 AM
minieater
Oct 28, 2015 02:15 PM
BlueCooperS
Sep 25, 2015 10:06 AM
gpwpat
Sep 15, 2015 11:58 AM
Suspension Products
Sep 10, 2015 11:46 AM
