Strange clutch sound
Old Mar 20, 2009 | 01:16 PM
Luys's Avatar
Luys
Hi Everyone,
Before 3 month ago the dealer changed my clutch because it was very stiff when I push it. Also it has strange sound (rururururu) only when I accelerate. After it was changed the clutch come better plus no sound. Now after 2K miles the sound come back again. The dealer told me that sound come from the flywheel need change. Can that be from the flywheel? moreover the sound come more and more while I am using it. I can take a video for it.
Thanks.
Old Mar 20, 2009 | 01:20 PM
ClubmanS's Avatar
ClubmanS
When the flywheel is replaced, the clutch kit (Pressure plate, discs and throw out bearing) must also be replaced.
If they replaced your clutch and left the original flywheel they did it wrong. Demand to have the clutch kit and flywheel replaced again.
Old Mar 21, 2009 | 10:20 AM
Luys's Avatar
Luys
OMG, do I need to change the clutch again?..
Old Mar 21, 2009 | 02:44 PM
chadtoolio's Avatar
chadtoolio
Not neccessarily...How bout that video clip of the noise and explain what you are doing to make it happen.
Old Mar 21, 2009 | 10:15 PM
howsoonisnow1985's Avatar
howsoonisnow1985
The best way I can describe it is it sounds like "Chewbaca" from Star Wars.
Old Mar 22, 2009 | 03:06 AM
Mini-Morgan's Avatar
Mini-Morgan
LOL! Thats weird sound then! If it was a nocking rythem I could understand or vibration.
Old Mar 22, 2009 | 01:09 PM
Luys's Avatar
Luys
That's right. It sounds like "Chewbaca" . I will try tomorrow to post the video.
Old Mar 25, 2009 | 03:06 PM
ignote's Avatar
ignote
Mine makes that sound too...
Old Apr 9, 2009 | 09:23 AM
Luys's Avatar
Luys
Hi everyone, here is the video of the strange clutch sound. Need comments. http://video.google.com/videoplay?do...40288616414106
Old Apr 9, 2009 | 11:15 AM
Mini-Morgan
Wow now that is bad! Are you sure its not completely worn out! Metal on metal!
Old Apr 9, 2009 | 12:20 PM
Luys's Avatar
Luys
I changed my clutch. I don't think it is metel on metel.
Old Apr 10, 2009 | 05:34 PM
Luys's Avatar
Luys
bump
Old Apr 10, 2009 | 05:41 PM
GregO's Avatar
GregO
clutch
Originally Posted by Luys
bump
Sounds like the well known, classic "chewbacca" sound we all know and love. Had my '06MCS clutch/flywheel replaced at 12,000 miles. Sound began at 3,000 miles and car now has 25,000 miles on it.
Greg
Old Apr 10, 2009 | 05:50 PM
Alerious's Avatar
Alerious
Yeah... that's a similar sound I had a while back. Just be careful, if you happen to notice it often when starting from a standstill, you could have a defective throw-out bearing, like in the case I had, and you want to get that fixed ASAP. My throw-out bearing failed and started to chew into the input shaft for my transmission. End result, the small issue I thought I had set me back a replacement transmission, as I found out the hard way that MINI does not sell transmission components separately.
GotMINI
Old Apr 11, 2009 | 04:48 AM
Luys's Avatar
Luys
GotMINI
That's mean, I have to change the flywheel with clutch as soon as possible?
Old Apr 11, 2009 | 05:50 AM
skillet's Avatar
skillet
Mine is doing the same thing. I'm glad to were able to shoot a video of it. Now I don't have to A friend of mine told me his Mustang's clutch was making the same sound right before it crapped out, and he ended up replacing the clutch/flywheel... Let us know when you replace the flywheel, and what that does for you
Old Apr 11, 2009 | 11:10 AM
Alerious's Avatar
Alerious
That depends on how often you are hearing the problem. If it's only something you notice a couple times when you move your car after it has sat for a while, it's probably safe to hold off on a replacement. On the otherhand, if you notice it occurring after your car has ran for a while, then I'd recommend changing it much sooner.
GotMINI
Old Apr 11, 2009 | 11:26 AM
MrCooperS's Avatar
MrCooperS
Moderator
I've had that sound for more than a year now. But for me it only makes that noise after it had rained or when there's a lot of moisture outside. My clutch pedal is also very rigid when depressed. Instead of a smooth glide when depressed, it has a rigid and rubbery feel to it. Either way, I have a aftermarket clutch and flywheel getting ready to be installed.
Old Apr 11, 2009 | 02:51 PM
Luys's Avatar
Luys
Tell us the difference after you install it. I see about 5 persons have the same problem
Old Jul 8, 2009 | 08:18 PM
Montana Miniac's Avatar
Montana Miniac
Yup, me too. Had a new rebuilt 6 speed transmission put in a few thousand miles ago, with a new clutch kit and t/o bearing. Didn't replace the fly wheel as it looked good. The noise occurs when the car has sat for a few days, and stops after being driven a few miles.
Old Jul 9, 2009 | 10:55 AM
Montana Miniac
So, has anyone has resolution of this problem yet? What was replaced?
Old Jul 9, 2009 | 04:18 PM
Montana Miniac
Thanks for the video. I tried to tell my mechanic about the "Chewbaca" sound, and all I got was a laugh. Of course, my car wouldn't make the noise when I talked to him. I made a CD of your u-tube video and left it on his desk later in the day. Now I don't feel so silly.
Old Jul 10, 2009 | 02:38 PM
derekj4's Avatar
derekj4
Mine does the same thing. It used to only happen after it had sat for a time, maybe overnight. Once it had warmed up, it stopped.
But now, for about a year, it "chirps" like that every time. If I start out really slowly (which bogs the engine sometimes), it does not do it.
Old Jul 10, 2009 | 04:00 PM
Montana Miniac
I am thinking "flywheel", as this is the only component that wasn't changed out. The car has to sit for a few days, to make any noise. This has me baffled.
Old Jul 10, 2009 | 07:40 PM
k_h_d's Avatar
k_h_d
Man that is really loud in the video. My car made the chebaca noise a while ago but it was never that loud and really only when conditions were right (damp and cold)... The clutch is however stiff and gritty at the end of travel in hot weather. Its really smooth in 70 degree or cooler weather.
