Strange clutch sound
Finally before a week ago I changed the clutch and flywheel together. The flywheel was in bad condition, the surface was worn. The sound has gone and the pedal is smoother than before. As I told before I changed the clutch without changing the flywheel and that was a mistake. So now I am very happy to not hear that sound.
I hope I answered all your questions folks??
This is a well known issue with the first generation MINIs. I had my flywheel/clutch replaced at 25,000 miles. Now that I am at 55.430 I have not had it come back and am happily motoring along. There are several posts on this, just do a search on "clutch noise" and you will see you are not alone.
The dealer should change out the flywheel/clutch without any fuss, if they do I would contact MINI USA and tell them the dealer is balking at properly repairing a known problem.
So it will be better to change both at the same time.
I had that same noise and it was vibration from the clutch disc I went to a stage 2 spring hub disc and it went away and I got rid of the stock dual mass flywheel and went to a 13LB flywheel huge difference
Powershift
Aug 16, 2015 05:14 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
