Climate control problem
Old Dec 27, 2008 | 02:15 PM
Wetworth's Avatar
Wetworth
Im having a problem with my climate control ('05 S; auto A/C) that I can't find a thread on. About 3 weeks ago I noticed that air would only come through the dash vents, even when the defrost mode is turned on. It was irritating at first but downright dangerous when I had to drive through freezing rain with no defrost . Has anyone else experienced this?
Old Dec 27, 2008 | 02:43 PM
daflake's Avatar
daflake
Have you swapped the radio recently? It is not uncommon for the controls to get blocked when people do this.
Old Dec 27, 2008 | 03:27 PM
Wetworth's Avatar
Wetworth
Uh... yeah i did just put in a new radio. What can I do to correct it?
Old Dec 29, 2008 | 12:40 PM
frenchie's Avatar
frenchie
Follow this link for a discussion on the diagnostics and error codes.
Old Dec 29, 2008 | 02:05 PM
Wetworth's Avatar
Wetworth
What link?
Old Dec 29, 2008 | 03:21 PM
daflake's Avatar
daflake
Pull the radio back out and make sure that you didn't push the bundle down to far so that it hits the controls that are back in there. It is tight and not uncommon for things to get cramped. There are moving parts back there.
Old Dec 30, 2008 | 11:05 AM
frenchie's Avatar
frenchie
Originally Posted by Wetworth
What link?
Oops! Here it is now
https://www.northamericanmotoring.co...e-problem.html
Old Jan 1, 2009 | 08:51 PM
Wetworth's Avatar
Wetworth
lol Thanks a lot.
Old Jan 1, 2009 | 09:09 PM
not-so-rednwhitecooper
What controls to get blocked? Its auto AC, there are no direct mechanical connections.
Sounds to me like something is broken in the HVAC unit itself. All electronic units are set to fail in defrost for obvious reasons.
Old Jan 2, 2009 | 04:18 PM
daflake's Avatar
daflake
There are servos back there that control the vents. If something is hitting them then it will keep it from closing properly.
Old Jan 2, 2009 | 05:03 PM
frenchie's Avatar
frenchie
The servo motors are connected to the doors via links and gears located inside the box at the base of the center console; one of my links broke such that air would only flow through the face level vents, I got nothing at the foot wells or the defrost; I engaged the diagnostics mentioned above and could hear the servos running but did not get any errors. The sensors that feedback the motion of the servo motors are located internal to the servos and not on the actual doors; as far as the system was concerned all was well.
The entire dash has to be removed to replace the broken link. I purchased the kit from MINI which contains all the links, doors and gears inside the box. I replaced all of them. The kit was around $50.
Occasionally I engage the diagnostics to recalibrate the position of the doors, as they tend to not close or open all the way over time because of worn links.
eatsleepautox
Oct 30, 2015 06:46 AM
kyungmanpark
Aug 23, 2015 07:26 PM
ludedude
Aug 10, 2015 07:16 PM
2manyhobbies
Aug 9, 2015 06:02 PM
