Excessive carbon build-up in engine
  #326
Old 09-20-2010, 12:31 PM
jeanet2001's Avatar
jeanet2001
jeanet2001 is offline
The car should still qualify under the used car lemon law since I bought the car in 09 and the issue occured for the first time within the 1st 18 months of ownership. In California, used cars are covered as long as they are still under original warranty and the problem started within 18 months of purchasing the car. I'll have to do more research to see how many repairs is considered a "reasonable" number of attempts to fix the problem. I wish they could just fix the rough idle/carbon build up problem! I really don't want to go through the lemon law but this is totally unacceptable for a car with only 38k miles.
Originally Posted by clutchless
An 08 probably no longer qualifies for lemon law status in many states. Usually a lemon law covers problems in the first year or 18 months. Also you will need a lawyer, Mini is not just going to roll over when you demand they buy back the car. The states with good lemon laws provide for lawyers fees, so it will not cost you anything and there are lots of lawyers who are eager to evaluate your case for free and take it if there is a valid case. Just Google lemon law and your state name to learn more and probably find a zillion ads for lemon law attorneys.
  #327
Old 09-20-2010, 06:24 PM
davidtobin's Avatar
davidtobin
davidtobin is offline
Adding to the thread: about two weeks ago my engine light came on (09 mini clubman s with 22k miles) so I took it in. Was running fine tho. They said code called for replacement of the HP fuel pump which they did under warranty. Week later light came on again and i took it back. car still running fine. code says carbon build up. It's at the dealer now and they say they are going to clean off the carbon. Asked me about what gas I use, how i drive, and recommend shell, italian tune up, and dealer carbon cleaner.
  #328
Old 09-21-2010, 11:39 AM
tvrgeek's Avatar
tvrgeek
tvrgeek is offline
David,
As we know, what gas or additives do not get in contact with the valves, so this dealer is an idiot.
  #329
Old 10-11-2010, 07:23 AM
davidtobin's Avatar
davidtobin
Recurring yellow engine light
My 2009 Clubman S has consistently run great, has 25,000 miles on it, but recently my yellow engine light came on. First they replaced the high pressure fueld pump. Fine for a week then yellow engine light came on again. Then they said it was misfiring and serviced for carbon build up. Fine for 2 weeks. Now engine light has come on again. Again, it's been running fine, no cold start problems, no breakdown, no noticeable misfiring, etc. I've looked through the threads and in all cases the replacement of the fuel pump or the computer diagnosis of misfiring due to carbon buildup has noticeably affected performance. The computer does not seem to suggest the catalytic converter. Any thoughts, ideas?
  #330
Old 01-18-2011, 08:04 AM
AXO's Avatar
AXO
AXO is offline
Originally Posted by tvrgeek
David,
I would think twice about bringing my Mini to that dealer for service
  #331
Old 02-22-2011, 06:53 PM
CooperSJohn's Avatar
CooperSJohn
CooperSJohn is offline
Any updates for this problem? Anyone know if the 2011 have this problem?
  #332
Old 03-01-2011, 02:27 PM
CooperSJohn
Originally Posted by Calz
Here is a couple pics of a Cylinder head Re&re for the carbon problem....
http://sizeminiclub.freeforums.org/o...rs-t99-10.html
The updates are new programming for N14s that Hopefully will reduce the possibility of carbon build up..
and the N18 now has a completely different PCV system. One that doesnt have a pipe aiming the Crankcase pressure right at the ht intake valves like in the N14
hopefully there wont be anymore problems with carbon build-up
  #333
Old 11-16-2012, 02:21 PM
golgo13's Avatar
golgo13
golgo13 is offline
https://www.northamericanmotoring.co...d.php?t=244114
  #334
Old 12-08-2012, 04:44 PM
sp_clark's Avatar
sp_clark
sp_clark is offline
Done & Gone
Just traded my '07 S today.
After 6 weeks' research (liked Ford's C-Max Hybrid a lot but after the 1st-year-build issues w/ my S I'm not gonna go there! 'Cides it's more money...) and nearly a month with my S in the shop for the Check Engine Light once again (about 9 times in just over a year) it's not gonna be an issue anymore.
Traded with 97,341 miles on the clock, the dealer gave me a very generous trade-in so I took one of their inventory 2013 Clubman's home. I'd wanted one back in '07 but they weren't available when I NEEDED a new MINI.
SM explained the S's have had 'issues' until the 2011 builds when some mods were done. Threads here point out the N18 updated engine over the N14 I had & suffered with for 5-1/2 years. There's a programming bug maybe too whereby the post-CAT O2 sensor signals a failure when in fact it's the pre-CAT that's wonky. HP fuel pump was changed out early on, 4 (!) pre-cat sensors, HP pump again last week + the post-cat sensor (all on MINI'S nickle) but I declined the suggested decarboning as that woulda been on my nickle & I had no plans to continue driving it at that point....
Oil separator bits in the valve cover'd gone bad some many miles back too, allowed oil into the pre-heater and thence into the engine wiring harness. Not good news, and NOT something I'd want to spend $$ on to repair when the extended warranty company said uh-uh, not covered.
  #335
Old 02-02-2016, 09:04 PM
Chuck W.'s Avatar
Chuck W.
Chuck W. is offline
Just finished reading 14 pages of this posting and decided to bring it back to life. My wife has a 2007 Mini Cooper S with an auto she bought brand new. It now has 35,500 miles on it and a blown engine. Three of the cylinders are at under 50 PSI and one is at 130. The indy Mini mechanic says the engine is loaded with carbon and the rings are a mess. I have always changed the oil every 5,000 miles with Mobil One 0w40 and always Shell Premium gas. I will have it repaired... and sell it. What a shame.
  #336
Old 02-03-2016, 06:16 AM
clutchless's Avatar
clutchless
clutchless is offline
If you are going to spend all that money to rebuild the engine, why not keep it for a while afterwards as you will then have a new engine!
Considering the age, I would check the resale value with and without the engine to see if it is worth the investment. I would also look into a used engine as it may be much cheaper.
My cousin blew the engine on her MINI (forgot to change oil) and got a used engine that they installed for her at the junkyard, Brandywine Used Auto Parts, which is a huge operation outside Washington, DC.
07-16-2020 12:54 PM
eatsleepautox
10-30-2015 06:46 AM
Zettinger
08-25-2015 04:04 PM
bc219
08-10-2015 11:22 AM
marendt428
08-09-2015 06:54 PM
Quick Reply: Excessive carbon build-up in engine
