Front Passenger side Knocking/Clunking when car is cold
Old Dec 10, 2009 | 01:13 PM
  #26
Davidf's Avatar
Davidf
I changed the CAB's thinking that was the culprit and the fact that the dealer said they were bad (when in for warranty work). BTW, changing the CAB's made absolutely no difference. Right now the car is in the shop as I hit a curb hard and ripped out the front suspension...$2600 + in damages. I am betting I took out the noisey part(s) in the process....
Old Dec 10, 2009 | 10:03 PM
  #27
drftobin's Avatar
drftobin
I did my inner ball joint to see if that was it NOPE!! Mini's sleeping for the winter in March going for CAB's and oil leaks in the front of the motor
Old Mar 30, 2011 | 03:54 PM
  #28
drftobin's Avatar
drftobin
The saga continues Still Clunking bad when cold 15min in gets 75% better, control arm bushing done, both ball joints done, swaybar links done sway bar bushing seem fine I'm at a loss????? Maybe my Helix camber plates went bad???
Old Jun 25, 2011 | 06:44 PM
  #29
drftobin's Avatar
drftobin
SWAYBAR BUSHINGS!!!!!!!!!! Damn swaybar bushings! Finely ran out of ideas so I said screw it drop the sub frame and change them. POOOOOOF like magic noise gone. They seemed good in the car they looked fine out of the car but changed them did it front end feels more stable to?
Old Feb 6, 2012 | 05:12 PM
  #30
GoThingNC's Avatar
GoThingNC
Thanks for posting the solution.
I am having the same noise when cold.
I am planning on replacing the LCA bushings this spring while I replace the oil pan gasket and will take care of the sway bar bushings too,
minicoclub
Aug 25, 2015 09:07 AM
cm.d
Aug 19, 2015 08:51 AM
Minibeagle
Aug 13, 2015 10:00 AM
quality_sound
Aug 7, 2015 09:36 AM
