AC is not getting cold and hissing sound
Old Jul 8, 2008 | 12:39 PM
greenmonster's Avatar
greenmonster
I finaly turned on the AC this week (I live in Maine) and we have no cold air.
1. Check Fuses and relay, All good
2. Check compressor, I can hear it running but the engine doesn't rev up
3. Checked and filled AC
I'm still getting warm air and now I have a hissing sound from under the driver's side dash when the AC is turned on. The sound stops if the AC is shut off.
Any thoughts?
Old Jul 8, 2008 | 07:34 PM
im1hapa's Avatar
im1hapa
My dash also has been making a hissing sound from under the driver's dash with the AC on...although mine is still blowing cold air. The dealer told me that it was 'normal,' saying that the pipe works for the AC are quite narrow for a small car, which causes the hissing. I feel that it is a hissing time bomb (to AC failure...not to a Mini Kaboom!).
Sorry I don't have any really useful info about your dead AC, though. I hope it's a simple fix.
Old Apr 25, 2015 | 04:58 PM
jkg2010's Avatar
jkg2010
Hopefully reviving this. Has anyone else had this problem, know the cause and had it fixed? This issue (same symptoms as the original post) just started on my 2010 MCS. The low side pressure is about 35psi while running the ac in this condition.
Old May 10, 2015 | 10:37 AM
jkg2010's Avatar
jkg2010
Apparently there's a tiny leak somewhere in my AC. Over 5 years the refrigerant leaked out but the system still holds pressure. Had it evacuated, dyed, topped off and it runs fine. They couldn't find the leak visually, nor with a sniffer but the dye will reveal it someday.
lweaver
Sep 17, 2024 08:22 AM
Colt45Magnus
Aug 27, 2024 05:03 AM
tylewis
Sep 6, 2015 01:07 PM
jesterofatlas
Sep 4, 2015 11:23 PM
wildwestrider
Sep 4, 2015 06:25 AM
