Auto up windows quirk.
Old Jul 1, 2008 | 09:41 PM
zooki's Avatar
zooki
Ok, here's something for you. I get in my MINI with the windows down and start it up. I hit the auto up switches to roll up the windows and also turn the AC fan on high. The windows immediately reverse themselves and roll back down. Could this be a voltage drop problem? Maybe too much pull on the alternator? But if I turn on the fan first, the windows operate correctly. Strange...
Old Jul 2, 2008 | 06:01 AM
pilotart's Avatar
pilotart
I have noticed that it takes a few seconds (ten maybe) after starting before the alternator comes on line, so voltage could be low.
I have always had A/C left on from last run and have not raised windows immediately, so never saw what you mention.
I HAVE Noticed what sounds like a little 'Belt' squeal on inital start and will turn A/C off for next start to see if it makes a difference. I will then do windows before A/C and see what happens and report if I see this.
My old Chrysler would wait ten seconds from start before A/C Compressor would come on line, never noticed if its Alternator did the same.
Wonder what $$$ replacement of that A/C & Alternator '100K' belt might run?
Old Jul 2, 2008 | 07:30 AM
matty125's Avatar
matty125
Gee, LUCKY!!!! I wish I had AUTO UP!
Old Jul 3, 2008 | 08:27 PM
joenzy's Avatar
joenzy
I noticed that if I hit the auto-up for the passenger side window and try to close the sunroof, the window will stop at the half way point, no rhyme or reason...
Old Jul 3, 2008 | 09:46 PM
pilotart's Avatar
pilotart
Tried what zooki mentioned and A/C had no effect on AutoUp of both Windows. Did not hear belt squeal
Have many times done auto-up of both windows and sunroof operation without issue.
My sister has a Volvo and if you try to operate both power windows at the same time, it blows the fuse. Her Volvo Dealer says that is normal.
Moshu-Clubman
R55 :: Clubman Talk (2008+)
Jul 13, 2016 08:54 AM
boholio
Nov 9, 2015 03:50 PM
Vaderm34
Sep 27, 2015 09:25 PM
3L6
Sep 21, 2015 06:21 PM
ir0nhid3
Sep 18, 2015 07:52 AM
