AC Odor problem
Old Jun 23, 2008 | 01:29 AM
muladesigns1's Avatar
muladesigns1
AC Odor problem
Does anyone have, or had, a problem with a musty smell coming from the AC vents?
The smell lasts for about 1 minute, if that, but is a damp musty smell. I checked and cleaned the fresh air filter under the glove box, which was fairly clean to begin with. is there another filter?
What could cause this and what is the recomended service to such a problem.
thanks in advance for anyones help
Old Jun 23, 2008 | 04:22 AM
GP0256's Avatar
GP0256
I had this problem, bought a new charcoal filter and got some spray from the BMW Dealer. Put in the new filter but did not use the spray yet because the odor is pretty healthy. I would suggest doing the same. The new filter seemed to help. The BMW guy also suggested a product called Fridgey Fresh?AA??A?A?A I have never heard of it but it goes in your vents and washer fluid and on your filter to kill all of the bacteria that might arise.
Old Jun 23, 2008 | 06:43 AM
Xymox's Avatar
Xymox
https://www.northamericanmotoring.co...d.php?t=144393
Check out this thread. Get yourself a new carbon-activated filter for $8.
Old Jun 23, 2008 | 07:33 AM
muladesigns1
so basicly what you guys are suggesting, is that the odor is more then likely the filter? I did inspect it and it had a little dust on it so i blew it off. come to think of it the car has 45K and the filter should be changed anyway. i bought it with 38K and dont know if it has ever been changed.
thanks for the link to the filter distributor. I ordered it today.
Old Jun 23, 2008 | 07:40 AM
Xymox's Avatar
Xymox
I think replacement is 12,000 miles/ 12 months if you decide to go with the TYC cabin air filter in the link I sent you above.
Old Jun 23, 2008 | 11:33 AM
DanSeals's Avatar
DanSeals
My filter is brand new and I still get a smell like dirty socks when using the A/C. The thing is, it's not consistent.
Old Jun 23, 2008 | 10:10 PM
J Marshall's Avatar
J Marshall
I get that smell too, but its only when I have the AC on and have the window down. I never smell it when the windows are up, which is 99% of the time.
Old Jun 24, 2008 | 05:41 AM
fishey72's Avatar
fishey72
I had a really dirty OEM filter. Replaced it with a standard spun filter and get that smell...I was cheap....need to get charcoal filter....
Old Jul 1, 2008 | 11:31 AM
CaliCoop44's Avatar
CaliCoop44
Well I have been having the odor problem for a while. I have a 2006 Mini Cooper S. The dealership says it is the condensation left behind when you run the air conditioning and if it doesn't dry out it creates a bacterial buildup that then puts off that aweful mildew smell. They say it is not a warrenty item and that they can try to clean out the system for $240.00 but it does not guarentee anything. What do you think? I personally think there is a defect somewhere in the system. I hate to say it but the odor is getting worse and making me a little sick. I love my Mini so I don't know what to do.
Old Jul 1, 2008 | 11:33 AM
muladesigns1
Only "whole" i have in that dealers theory is, I live in the Desert! No condensation here!, car sits in the sun most of the time too.
I would go to a regular AC shop to evac the system and fill with fresh stuff. they even have a scent to install through the lines. Before I would let the dealer over charge me for the same work.
Old Jul 1, 2008 | 11:44 AM
CaliCoop44's Avatar
CaliCoop44
That is interesting because they are trying to tell me that it is because of the elements of where I live the smell happens. (Bay Area California). And that if I live some where like the desert it wouldn't happen. Errrr. Frustrating. Did you try the carbon filter? And if you did, did it help?
Old Jul 1, 2008 | 11:46 AM
muladesigns1
put one in a week ago but still have a little odor, could be mold residue left behind. im planning on removing the first bit of ductwork and cleaning it with simple green
Old Jul 1, 2008 | 12:03 PM
CaliCoop44's Avatar
CaliCoop44
Hopefully that will work. Good Luck. Thanks for the info. I am going to try to get ahold of some A/C companies and see if they can do anything. I am still going to bug Mini though. My husband just bought a 2008 Mini S and we want to make sure the same problem doesn't occur in his.
Old Jul 4, 2008 | 11:16 PM
CaliCoop44's Avatar
CaliCoop44
Well had Mini Service clean out the A/C. They waived the $240.00 charge. It worked quite a bit. Smell is not very bad any more. I will let you know as time continues if it comes back.
Old Jul 4, 2008 | 11:30 PM
Ancient Mariner's Avatar
Ancient Mariner
Check at your local Checker Auto Parts in the A/C section. There is a small pressurized can of A/C cleaner/deoderizer that you spray into the vents that may help get rid of the odor.
Old Jul 6, 2008 | 06:53 AM
muladesigns1
ive heard of it, bit i didnt realize it was avail, at checker. thanks!
UncDeo
Nov 4, 2019 04:08 AM
CardinalsRule
Jun 11, 2016 04:34 PM
tylewis
Sep 6, 2015 01:07 PM
Manny_cooper
Sep 3, 2015 05:48 AM
Sep 2, 2015 09:05 AM
