Anyone remove the A/C from your street car?
Old Jun 5, 2008 | 06:41 AM
Partsman's Avatar
Partsman
Legion_of_Doom
If you did, how did you keep the radiator fan from running all the time?
My car now has no A/C and we tried several different things to return the fan to normal operation, but none of these worked...
1) ground the A/C connector from the harness
2) 12 volts to the same connector
3) jumped the pressure switch connector from the harness
with no ground to the compressor connector
4) jumped the pressure switch connector from the harness
with a ground to the compressor
5) pulled both A/C relays from the box underhood
6) pulled A/C fuse from same box
Obviously, the DME is seeing the A/C as being "on" with nothing plugged into the compressor harness and with no pressure at the switch.
I've never seen a MINI from the factory without A/C, but they offer this to replace the compressor...
...which I have installed, so I wonder if there is a DME flash for vehicles without A/C?
Anybody? Any input? Thanks.
Old Jun 5, 2008 | 07:26 AM
62minimn's Avatar
62minimn
I have that part on my car
I purchased a salvage mini and putting it back together I decided on the pulley rather that trying to replace the system. There was a sensor or relay that was located in the air box corner that I had to replace to get my fan to stop running. My car is getting tuned today so I do not have it to look at what I replaced. I can let you know this weekend if you do not get it solved.
Old Jun 5, 2008 | 08:01 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Thanks for the reply.
I think you may be referring to the pressure switch that is underneath in the general area where the air box sits.
That's all you did, was plug the switch back in? The fan cycles normally now?
I haven't tried that yet, the switch is still on the line which is up at the shop.
Thanks again for your input.
Old Jun 5, 2008 | 09:26 AM
62minimn's Avatar
62minimn
Yep
I plug that back together and zip-tied it to something. I have not had problem since.
Old Jun 5, 2008 | 09:33 AM
62minimn's Avatar
62minimn
High Speed
I had read somewhere that first speed was for engine cooling and high speed was when AC was on. Figured something was not shutting off the high speed setting.
Old Jun 5, 2008 | 09:52 AM
Partsman's Avatar
Partsman
Legion_of_Doom
Wow, and the fan functions as it's supposed to?
Old Jun 5, 2008 | 06:37 PM
Partsman's Avatar
Partsman
Legion_of_Doom
To answer my own question...yes it does.
I plugged the pressure switch back in and the fan functions normally now. Kicks on at 220 just like it always did. Nice.
maestro39
Oct 27, 2015 02:38 PM
rckrzy1
Aug 11, 2015 06:06 PM
Red Raven
Aug 11, 2015 04:48 AM
xpunisherx
Aug 10, 2015 10:50 PM
quality_sound
Aug 7, 2015 09:36 AM
