Problem discovered during first oil change
Old Feb 26, 2008 | 01:20 PM
MJohnson81's Avatar
MJohnson81
So Thursday I bought a used 2004 MCS and yesterday I was changing the oil and what do I find...a nice big wet spot of oil on the bottom of the block. So I cleaned off all the oil and sprayed it with brake cleaner to get rid of the oil; I look today and theres another spot of fresh, clean oil ( the same kind I just added to my car) on the bottom of the block. From what I can tell it's coming from where the block and the tranny case meet.
Upon further looking I also found oil around the valve case near the drivers side and alittle on the back ( not from changing the oil because I didnt spill any ). I guess my only option is the take it back to the dealer and see if they will fix it. Under CT state law I have 60 days to have it fixed for free but its an audi dealer so I dont know if they will fix it themselves or take it about an an hour away to the Mini dealer.
I love the car...but this is not the way to start off a good relationship.
Old Feb 26, 2008 | 02:04 PM
miniconcarne's Avatar
miniconcarne
Valve cover leaking? Hopefully it'll be an easy fix. Good luck.
Speaking of DIY have you checked your air filter? I was stunned with how dirty mine was.
Don't think the previous owners ever changed it!
Old Feb 26, 2008 | 03:04 PM
MJohnson81's Avatar
MJohnson81
No, I havnt. I have an appointment next Tuesday with the dealership, hopefully after that when the problem is fixed, I'm going to put a pulley and a Dinan intake on the car.
Old Feb 27, 2008 | 08:51 AM
sequence's Avatar
sequence
could be the oil pan gasket, they are crap and had to have mine replaced at 24K.
Old Feb 28, 2008 | 05:33 PM
Some Guy's Avatar
Some Guy
Mine had/has both of these problem. The stuff under the engine was indeed a bad oil pan gasket and that was fixed under warranty. There was stuff around the valve cover on the passenger side, that said it looked pretty old so I dont think it is an actual problem right now... In the end that has yet to be fixed (if there is an actual problem).
Kimolaoha
Jul 5, 2023 01:04 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
FLYM1N1
Aug 16, 2015 01:17 PM
ludedude
Aug 10, 2015 07:16 PM
