Yellow Engine Light - Full engine power no longer available
Old Jan 5, 2008 | 03:47 PM
Twin Turbo's Avatar
Twin Turbo
When I started up my 07 MCS Automatic at -20 C or -4 F the yellow engine light came on (Full engine power no longer available). The car sounded fine at this time so I started to drive out of the parking lot but the car had no power, it was moving at an idle speed only. As I continued to idle along in stop and go traffic the car started revving up and down like it was going to shut off. When I would take my foot of the break the car would jump fwd at first but after 5 minutes or so the car did not want to move at all until I hit the gas peddle, the engine would then make a terrible noise like it was going to cease up solid. During this I could smell something burning like sugar. After this I pulled into a parking lot to call the dealership to come pick up the car because it would not go any faster that 10Km/hr and I was afraid I would cook the engine(new with only 2500Km.After I stopped the car and shut it down I restarted it to see what would happen and everything was fine, no yellow engine light. Once I arrive home I looked under the bonnet to see if I could see anything wrong but there was nothing except for the smell of gas after I remove the oil cap.
The dealership will not be able to take a look at the car for 6 more days so I’m concerned if I should continue to drive.
Does anyone have any ideas on what the problem may be?
Old Jan 6, 2008 | 01:47 PM
second to none's Avatar
second to none
See if you smell gas when you retract the dipstick. If there is any second thought there is fuel in your oil, I would wait for the dealer to take the car. Had a similar problem with a VW g60.
Let the warranty take care of it, before the dealer tells you its your fault, and tries to rape you.
Old Feb 6, 2009 | 04:09 PM
bettehead's Avatar
bettehead
Seems to be a frozen throttle valve. I just had this problem! See this thread; it also has a YouTube video in it of the problem occurring:
https://www.northamericanmotoring.co...ailable-6.html
mini yellow-haa!
Aug 13, 2015 11:18 AM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
Lt. Dan
Aug 10, 2015 08:23 AM
