Armrest Fix?
Old Dec 30, 2007 | 06:34 PM
  #26
runningerin's Avatar
runningerin
That trick with getting it onto the track didn't work for me, either. I think one of the two rear plastic pieces that fits in the track is broken on mine. I am wondering how a new top (armrest) will work or will I still have the same problem? Switching out to a Euro looks pretty complicated from the very nice detailed description and pictures on one of those websites (minspeed or outmotoring, can't remember!) After all, I'm a girl!!!!!
Old Dec 30, 2007 | 06:39 PM
  #27
runningerin
On the outmotoring.com site, you can click on "How to" at the top of the page, and for Gen 1 Minis, you can see step-by-step how to install the OEM armrest. I assume you need to do that in reverse to install the Euro, and then screw in the "feet" at the rear of each front seat.
Old Dec 30, 2007 | 07:04 PM
  #28
carla99's Avatar
carla99
I had this problem of the "opening armrest" too. Took mine to dealer b/c for some odd reason one day my armrest decided not to open at all. Service guy got it open, said it's a defect, and ordered me a new clip. Said to come in to get it repaired/installed but haven't gone back yet. Will post an update on whether the new clip keeps the armrest closed better than the original.
Old Dec 30, 2007 | 09:12 PM
  #29
shokk's Avatar
shokk
7th Gear
Surely we can find a gallant person nearby to help. Are you anywhere near NJ?!!?
Old Dec 31, 2007 | 06:16 AM
  #30
Arnbut's Avatar
Arnbut
The problem is universal.
http://www.mini2.com/forum/2nd-gen-i...5-armrest.html
I have the Euro; it's nice but doesn't flip up and out of the way far enough for me...
Old Jan 1, 2008 | 01:59 PM
  #31
runningerin
The EASIEST fix!
Originally Posted by notmestl
Here is my Fix, it works for me the arm rest NEVER opens on its own unless I open it. It is a little tricky, but once you get a feel for it - it works. Quoted from this thread: https://www.northamericanmotoring.co...d.php?t=109466
I had the same frustration with the armrest and after messing with it for about a week, sliding open, sliding shut..etc.... ARG!
I finally figured out the trick!
When you open the top the back end of it actually slips off of the track.
You can actually feel the back end of the top of the armrest when "closed" and feel how it is not quite "snapped" shut.
In order for the armrest to stay closed do the following:
Open the top, grasp the back of the top and slide it shut so that it grabs the track properly. You have to actually lead the back end of the top into place on the track.
Once it is seated properly it NEVER slips open again. Until you manually open it that is, and then once again you need to follow the same procedure.
Seeing as I never open it, I never have to worry about this once I have it closed properly!
This is actually VERY good information! The service guy in Atlanta told me basically the same thing--that when the top is slid back, it comes out of the tracks. When it gets pushed back in, you have to make sure both sides move into the tracks. What is happening is that one side will line up and the other will not. Then when you rest your arm on it--!crack!-- you break a rear clip. Presto! The top will no longer stay closed.
I bought a new one (just the cover) at the dealer for $104, and replaced it. Works perfectly!
To remove the old one, you slide it back all the way open, flip it up so the front is up and the back is down, and then squeeze it on each side so that the plastic comes out of the track on one side. The other side will just release. Reverse the process to install the new one. Then, be very careful every time you close it to make sure the rear clips are engaged in the tracks. Good luck!!
Old Jan 6, 2008 | 11:32 AM
  #32
shokk's Avatar
shokk
7th Gear
My attempt at a fix with electrical tape didn't do it. I have my tire rotation and oil change coming up at 9k miles in about a month, so I'll have to mention this to them as well.
Problem is, I rest on that side of the car any time I'm at a light or stopped in traffic, so I'm likely to break it again.
Old Jan 6, 2008 | 12:44 PM
  #33
runningerin
If it's closed correctly, it will be fine and it won't break. It is SO worth it! Out of habit now, I still look down to see if it's open or casually reach over to close it. But it's CLOSED! YEAH!!!
Old Jan 16, 2008 | 02:55 PM
  #34
Tess's Avatar
Tess
I'm having my armrest replaced next week under warranty, because the lid popped off and they couldn't get it to go back on. I'd much rather have one of the Euro armrests, but I'm sure there is no chance of getting that instead without paying for it.
Old Jan 16, 2008 | 03:54 PM
  #35
daffodildeb's Avatar
daffodildeb
I think I'll "tough it out" until my oil change--first anniversary will be 2/21. Wonder how soon I can bring it in.
I've got 15,000 on the clock, and the count down meter still says 6,000. We have, of course, changed the oil (twice).
Old Jan 16, 2008 | 05:16 PM
  #36
Tess's Avatar
Tess
you need to take it now at 15,000 because the service advises a 15k oil change.
I scheduled for service ahead of time when I knew I'd be near 15k, I drove up to my first service with 15267 miles, and according to the car still had 3600 miles to go before I needed service. If I'm not mistaken you need to get an oil change at your dealer within 1000 miles of hitting 15k (under or over) or it may invalidate your warranty?
Old Jan 16, 2008 | 07:56 PM
  #37
daffodildeb
Interesting--we were told we had to wait until the countdown, or 1 year, whichever came first. And it was that way on a BMW we bought new--they would NOT do it before then. But I'll call tomorrow...
Old Jan 17, 2008 | 05:25 PM
  #38
daffodildeb
Okay, I called. My SA said positively, definitely, absolutely, that it goes by the computer OR the anniversary date of purchase, which is February 21, for me. The computer says 6000 left, and she said that it often does. Apparently they can read the key, and if there's a difference between it and the OBC, they go by the key. But, usually the OBC is correct.
This is what happened to us with our BMW in '01--couldn't get a free change until the computer said, although as I recall, the computer time was a whole lot shorter.
Old Mar 8, 2008 | 05:05 PM
  #39
Copywrites's Avatar
Copywrites
I had the same problem on a different car. My ultimate solution was to remove the spring in the hinge, so that it would not leap open even if the latch released. That solved the problem.
Old May 30, 2008 | 01:16 PM
  #40
boostednorm's Avatar
boostednorm
Originally Posted by MINI_Bee
If you currently have the OEM sliding armrest, you need the parts below to do the Euro armrest install. If you have the standard center console with NO armrest, all you need is the Euro armrest, a torx socket and about 1/2 hour of time.
The Euro armrest is available at Minspeed. I know he has them because I was in his store a few weeks agon and saw them there.
http://minspeed.net/MAR.htm
Parts:
CENTER CONSOLE
Part #51-16-7-130-767 (in panther black)
(If you need a different color console the part number will be different)
TRIM RING, PARKING BRAKE CONS. CHROME
Part #51-16-7-127-912
(If you need a different color trim ring the part number will be different)
BRACKET, HANDBRAKE CONSOLE
Part # 51-16-7-131-830
CLICK HERE FOR PART DIAGRAM
Keep in mind the parts I'm showing are for an R52. These parts may vary for R50 and R53. Use RealOEM.com to search the parts for your MINI.
I'm trying to deduce exactly which parts are needed to switch my R56 OEM Sliding Armrest to the Euro Fliptop one. I also have the chromeline interior and no Nav. Looking at the diagram for the R56 at RealOEM.com it would appear I would need the following... please correct me if I'm wrong:
BRACKET, HANDBRAKE CONSOLE, REAR
51-16-2-752-947
CUP HOLDER, HANDBRAKE CONSOLE, REAR
51-16-2-756-167
TRIM RING, DRINK HOLDER, REAR
51-16-2-756-172
It appears I'm just replacing items 3, 16 & 17 with 2, 14 & 15. There are no references to black panther which, btw, is the coolest name for a color.
CLICK HERE FOR R56 PART DIAGRAM
Old Jun 14, 2008 | 03:37 PM
  #41
boostednorm
Just received the parts and installed them and it was indeed the correct parts. Here are the prices I paid at my local dealer:
R56/Chromeline interior/No Nav
51-16-2-752-947 $20.99
51-16-2-756-167 $21.99
51-16-2-756-172 $18.99
Removal of the old armrest and installation of these new parts was very easy. About 20 minutes taking my time.
Awaiting the euro armrest to come in - which should be even easier to bolt in since it uses the existing seat bolts.
Old Feb 15, 2010 | 05:56 AM
  #42
JHB141's Avatar
JHB141
Looking at doing this mod, how did yours go with the euro?
Old Jun 15, 2013 | 08:04 PM
  #43
dennetman's Avatar
dennetman
If anyone still cares about the slippy/sliddy armrest issue, this is how I got it to stay shut. I just purchased an 08 hardtop from a friend and this was the only issue with it. Following notme's instructions, I opened it all the way and pulled up thinking I would be setting it back in its track. Instead the lid released (as in separated from console) in my hand. I could see a broken detente on the back (plastic looks like its been broken a long time). I noticed a self adhesive felt runner along both edges of the lid to give the lid a tempered feel when opening/closing I suspect. With a knife, I lifted about a 1/4 inch of the sticky felt near the back end of the lid. I found a rubber ring in my tool box - much like a gasket that goes with the threaded end of a garden hose. With a knife, I cut two little semi circles out of it. I found this to fit exactly under the lifted felt (I installed the semi circles on each side of the lid). Once sure of the fit, I super glued them in place. I re-installed the front (upper guides) and then lined up the double guides over the recanular opening on the console. The pastic tabs proved strong enough to not to break while being forced back into the console. Once in, I shoved the lid forward until the bulg made contact - and now all is well. The the lid has enough drag at the end of its guide channel to firmly remain closed, yet still can be opened.
Old Jun 17, 2013 | 07:00 AM
  #44
nrfitchett4's Avatar
nrfitchett4
didn't know you could swap it out with the euro version. Think I will just superglue mine shut until I can do the swap. Mine is functional, properly on its track, but slides open occasionally and it really is too small for any real storage. Apparently you can buy a kit for an iphone that fits in there, but my note 2 will not come close to fitting (actually sits nice under the parking brake)
Old Jun 17, 2013 | 07:41 AM
  #45
If you are converting to the Euro Fliptop armrest those three part are here. #51162752947
http://www.ecstuning.com/Search/SiteSearch/51162752947/
Cup Holder For Rear Section to match the other trims rings of your interior.
#51162756167
http://www.ecstuning.com/Search/SiteSearch/51162756167/
Trim Ring For Rear Cup Holder - Chrome #51162756172
http://www.ecstuning.com/Search/SiteSearch/51162756172/
Trim Ring For Rear Cup Holder - Silver #51162756171
http://www.ecstuning.com/Search/SiteSearch/51162756171/
Trim Ring For Rear Cup Holder - Carbon Black #51162756169
http://www.ecstuning.com/Search/SiteSearch/51162756169/
The Euro flip top armrest is here and mounts to the near the seat rails. Comes in a color close to carbon black.
http://www.ecstuning.com/Search/SiteSearch/52160429935/ES250438/
And if you just want to replace the factory armrest pad. Part # 51162753341
http://www.ecstuning.com/Search/SiteSearch/51162753341/ES81901/
Thanks and hope that helps.
Old Oct 24, 2013 | 03:34 PM
  #46
vetsvette's Avatar
vetsvette
Moderator
Mine just slides completely off the rear of the console. Not accidentally, but when I open it. I have the cradle for my iPhone so I don't want to go with the euro version. Guess I'll need to spring for a new cover. Looking at the picture above and comparing it to mine, I seem to be missing most of the tabs shown.
Thanks for the link ECS.
Old Oct 25, 2013 | 06:00 AM
  #47
You are welcome. Glad I could help.
Old Oct 25, 2013 | 06:09 AM
  #48
Swimbaxter's Avatar
Swimbaxter
Cheap Fix
Saw this and thought it might be a good solution or at least a decent Band-Aide https://www.northamericanmotoring.co...01-post22.html
Parts Order info:
http://www.shear-loc.com/onequarter.htm
Just goes to show, MINI owners are a creative bunch and some of the solutions are inexpensive!
Old Apr 11, 2014 | 09:52 AM
  #49
NYTransplant's Avatar
NYTransplant
Different Approach
I know this is an old thread, but here is how I "fixed" mine on the cheap. You can buy
these these
types of bumpers at Lowe's, Home Depot...etc.
I just stuck one on each side of the armrest frame, and they stay there for a few months until they finally give up the ghost and fall off. If you pull up slightly as you close the cover, they actually do last for a while. Since you buy a whole sheet of them, you always have more.
Here is how they look installed. You can see they are a bit misaligned, as they have been on there for six months or so and are starting to become unstuck, so it's time to replace them. I've never had the lid slide back since installed, and you don't have to reach back to turn a wing nut. Just remember to keep upward pressure on the lid when you close it.
67morris
Dec 1, 2015 12:53 PM
molala
Oct 2, 2015 01:53 PM
Olenska
Sep 21, 2015 12:36 PM
asmasm
Sep 21, 2015 08:23 AM
Norton70
Sep 7, 2015 05:06 PM
