07 MC Engine Replacement @ 5k miles
Old Dec 17, 2007 | 07:37 PM
  #26
Bhatch's Avatar
Bhatch
Originally Posted by richi0207
instead of going into 4th it went into 2nd i tried to catch it before it over-revd but it was too late, engine shut off and got the oil light. The dealer says they wont replace the engine because of a misshift but arent gearboxes suppose to stop you from shifting into a gear thats too low, I remember my old car had that.
No limiter or electronic device and stop you mechanically linking the car at a high road speed to a high gear speed. Once you let that clutch down, the engine will try to match the wheel speed and will just keep reeving until it can't anymore. The fuel or spark cuts have nothing to do with the forces at work.
Sorry for your loss, if your dealer does not pick up the damage (and i don't see why they would) your insurance will.
Old Dec 17, 2007 | 08:06 PM
  #27
healey67's Avatar
healey67
It all depends on how much you B*tch and how high up the food chain you go. Just realize that once you start to B*tch don't expect much favors or help again....
Old Dec 17, 2007 | 08:14 PM
  #28
tazio's Avatar
tazio
This should come as not surprise to anyone. The R56 has a Peugeot engine, after all.
Old Dec 17, 2007 | 08:17 PM
  #29
PGT's Avatar
PGT
Originally Posted by SeaJayAre
I was told the replacement will take 3 days if that means anything...
I've watched a Subaru tech pull a flat six motor in 45 minutes. The MINI is a bit more complicated due to compact packaging, but I'd guess 3 days is for the inevitable snafus that come up.
Old Dec 17, 2007 | 08:54 PM
  #30
richi0207's Avatar
richi0207
ahh thx for the reply I am trying my hardest will have an update tomorrrow =)
Old Dec 18, 2007 | 04:56 AM
  #31
SeaJayAre's Avatar
SeaJayAre
You will never get a RMFD engine from the dealer, all engines are factory. They will stop producing factory engines at one point, then only parts of the motor/car for 10 years after last car produced after that is it jobber parts only or RMFD. RMFD come from places that specialized in RMFD parts, usually this is normal when you get a rebate for core part. Like a Master cylinder or alternator, calipers ect.
I had a friend got his ITR motor changed at 60,000 km for buring oil. Last year of honda factory B18c5 short blocks, lucky him.
So explain why thats on the paperwork (RMFD) if dealers are not installing them.
I have one installed... you think it's a typo? Maybe that all the computer had been set up for is RMFD and they couldn't change the printout...and I really have a factory new.
Old Dec 18, 2007 | 05:11 AM
  #32
Mach V Dan's Avatar
Mach V Dan
I have been driving stick for years and I dont know how but on the highway, instead of going into 4th it went into 2nd i tried to catch it before it over-revd but it was too late...Hmm what should I tell the dealership.
You want the dealership to PAY for this? You mis-shifted and over-revved the car! No manual trans car will stop you from doing this. I agree with the poster above -- call your insurance company. Otherwise, please don't threaten the dealership with a lawsuit. This is your mistake, and has nothing to do with warranty service, any more than it would if you drove your car into a tree.
(Sorry to be harsh, but this is the way I see it.)
--Dan
Mach V
Old Dec 18, 2007 | 09:13 AM
  #33
pimpedout97x's Avatar
pimpedout97x
my moms 06 lexus gs300 just had the engine replaced, we had it at lexus 3+ times for the same problem previously, and the last time they had it for over a month.
can you say lemon? hehe
i think they're going to replace the car though for us, so we dont have to go through the lemon law crap
Old Dec 18, 2007 | 10:01 AM
  #34
medilloni's Avatar
medilloni
Originally Posted by healey67
No I have not replaced any due to this noise I hear so much about.
The 2 I replaced, 1 over rev... 17yr old kid decided to hot rod around and missed a gear. Hit 8887 rpms in the little black box. Bent the entire exh side of the valve train and damaged the exh cam. This was a Manual Trans.
2nd one was similar but an Automatic engine. Broke the head off a valve on the #2 exh and shot a hole thru the top of the piston. Needless to say, done. These Eng do not come apart on the bottom end easily at all..
I've seen the oil pan bent trying to remove it. No rebuilding.
Ouch!
Thanks for the reply Healey.
And for those mis-shifting...
If you hit a kerb and trashed a wheel and suspension, would you complain to the dealer? Sorry, but that seems a bit unfair on the dealer.
Old Dec 18, 2007 | 10:02 AM
  #35
Mr.GBMiniGirl's Avatar
Mr.GBMiniGirl
a lot of parts from the dealership are re manufactured. If its warranty work, chances are it'll be a Reman part. Warranty still covers it. When we replace engines at the customers nickle they have a choice of NIB or Reman. This is BMW and MINI!
Old Dec 18, 2007 | 12:05 PM
  #36
SeaJayAre's Avatar
SeaJayAre
So which is better NIB or RMFD?
Old Dec 18, 2007 | 12:33 PM
  #37
Loony2N's Avatar
Loony2N
I'd be happy that the dealer plans to replace the engine, rather than rebuild it.
Old Dec 18, 2007 | 01:46 PM
  #38
MINIdave's Avatar
MINIdave
Well, since it's going to be on the OP's nickel (or his insurance co's nickel) I'd opt for the new one, especially on a 5k mile car.
Gotta watch those downshifts.........
Personally I don't understand how someone can miss a shift and not know it when they start to let out the clutch. All you have to do is push the clutch in again, put it in the right gear and no harm/no foul.....but I know other's have done this........my nephew for example, used to catch first when he was going for third.........had to spend a little time with him training.........
I'm not saying you can't miss a shift once in a while, I've done it too, but I always know because of the way the car reacts when I start to let out the clutch and just re-clutch and get the right gear......
Old Dec 18, 2007 | 02:22 PM
  #39
MotorMouth's Avatar
MotorMouth
The dealer called back. It turns out my engine is blown, I have been driving stick for years and I dont know how but on the highway, instead of going into 4th it went into 2nd i tried to catch it before it over-revd but it was too late, engine shut off and got the oil light. The dealer says they wont replace the engine because of a misshift but arent gearboxes suppose to stop you from shifting into a gear thats too low, I remember my old car had that. Hmm what should I tell the dealership. I told them that if they cant fix it ill take it all the way to court so now they have a regional manager analyzing the car. I miss Charlie(fermale =P)
ouch.. so what is the price since you are definiately going to have to pay for this one. There's not a snowball's chance in **** of this being covered under warranty.
Old Dec 19, 2007 | 08:40 AM
  #40
healey67's Avatar
healey67
Ha ha... a snow ***** chance in hell..... Guess it snows in FLorida.....
Old Dec 19, 2007 | 10:32 AM
  #41
Loony2N's Avatar
Loony2N
+1
Old Dec 19, 2007 | 10:49 AM
  #42
glangford's Avatar
glangford
Would insurance cover this??
Old Dec 19, 2007 | 11:03 AM
  #43
misslindsey's Avatar
misslindsey
I was telling my bf the other night (after he got 4th going for 2nd) that I've never mis-shifted in Lewis. And I just learned a manual before I got him. There have been a few times that I went for 5th and didn't get it quite all the way engaged - but just put the clutch back in when I heard and felt the grinding.
Old Dec 23, 2007 | 05:15 AM
  #44
SpitfireMkI's Avatar
SpitfireMkI
I can see how you got 2 and 4 mixed up, the MINI shifter is far from precise.
My old '88 Mustang GT has better shift control, and back in the day when '88 was new, the magazine reviews hated its shifter
I thought R53 and R56 had rev limiters ? I could swear i read that somewhere.
Mike
Old Dec 23, 2007 | 06:48 AM
  #45
misslindsey
I don't have that much experience driving a manual, but I've found the shift gate to be pretty crisp.
There are rev limiters, but they only work on the way up. Nothing can stop the clutch from trying to engage when the engine revs are too high.
Old Dec 23, 2007 | 08:40 PM
  #46
dewhastme's Avatar
dewhastme
Some cars lock out the lower gears based on speed.... Saabs for example, Audi's too I believe. Most, if not all, manual transmissions lock out reverse with any forward motion. But this is a mechanical function in the shift mechanism and has nothing to do with the engine.
Old Dec 28, 2007 | 08:19 PM
  #47
richi0207's Avatar
richi0207
ok...nevermind looks like im going to be building the engine, from the block up with performance parts...anyone here already have an existing built r56?
Zettinger
Aug 25, 2015 04:04 PM
JPMontes3
Aug 23, 2015 01:26 AM
Aug 12, 2015 01:24 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
