2 problems already :(
Old Dec 11, 2007 | 01:19 PM
MiniS04's Avatar
MiniS04
2 problems Already :(
Hi all .. Just bought my mini and posted in the 1st gear forum a few days ago ..
Been driving it like mad and have noticed a couple of noises I didn't hear at first was wondering if you all could possibly point me in the right area ?
First :
When at a slow roll I hear a pulsing wearing type noise coming from what seems to be the back wheel area. (thinking warped rotor?)
Second
Sometimes but not always when driving on the freeway and taking a slight right turn I hear a rapid knocking coming from the passanger front wheel area. but only for a few seconds not on every turn and if I move the wheel even teh slightest bit it stops ( I have no idea on this on)
Well if anyone can help it would be much appreciated .. I have it going to Mini of San Antonio tomorrow .. I would just like to have some kind of idea before they charge me a ton of money :(
EDIT : its an 04 with 34,200....
Old Dec 11, 2007 | 01:54 PM
SRICHS's Avatar
SRICHS
Congrats on the car....
First problem -- You probably have s-lites with Eagle RSA's on them? By your discription, it sounds like the tires have been run flat before and now you hear the aftermath... the pulsing / rubbing type noise.
Second problem -- sorry, no idea....!!!
Old Dec 11, 2007 | 02:02 PM
goaljnky's Avatar
goaljnky
Second problem - check your wheel lugs. Make sure they are torqued. Do you have camber plates?
Old Dec 11, 2007 | 03:20 PM
MiniS04's Avatar
MiniS04
ok you have to forgive the stupidity
what are camber plates ?
Old Dec 11, 2007 | 03:23 PM
goaljnky's Avatar
goaljnky
Used on top of your front shocks/spring to allow greater camber adjustment. But I would say you don't have them since you are asking.
Old Dec 11, 2007 | 03:27 PM
MiniS04's Avatar
MiniS04
ok looked up camber plates .. going to check ..
Nope checked no camber plates
planeguy's Avatar
planeguy
issue #1 does the car have runflats? If so the tires are known to be noisy.....I have the same exact noise you describe...had it a couple of times, to test just swap the tire to the front, the noise moves with the tire then its the tire, if not it could be a wheel bearing but I bet its the runflats
Old Dec 11, 2007 | 03:47 PM
MiniS04's Avatar
MiniS04
going out to buy new tires .. I just quoted the runflates from goodyear
335 a piece there has to be a better option .. what tires do most of you all use .. I have about a 600 dollar budget :(
Old Dec 12, 2007 | 04:52 AM
Freedog's Avatar
Freedog
I understand why Mini offers run flats but I don't think I would be running them personally. They're expensive and noisy and there are better options out there.
Old Dec 12, 2007 | 06:28 AM
MirthScout's Avatar
MirthScout
Non-runflats plus a small air compressor, tire slime and maybe a plug kit.
nabeshin's Avatar
nabeshin
Functioning Lunatic
Check tirerack.com for loads of options. If you have the stock s-lites, then your tires size is 205/45/17.
Old Dec 12, 2007 | 05:24 PM
MiniS04's Avatar
MiniS04
Tires fixed both my problems ..
Thanks for everyone's suggestions !!!!
UncDeo
Nov 4, 2019 04:08 AM
tylewis
Sep 6, 2015 01:07 PM
mikeandtricie
Sep 4, 2015 01:42 PM
mimaal
Sep 4, 2015 09:09 AM
Sep 2, 2015 09:05 AM
