Noise!
Old Dec 6, 2007 | 01:49 PM
ruftec's Avatar
ruftec
Noise!
Hello my fellow Mini group.
I have noticed a noise that seems to be coming from the front wheels.
It sound like a coat hanger hitting metal. "tick" "tick" "tick"
It happens on slow start in the first gear under 10mph. Noticed it when in indoor parking garages. Real annoying sound cause I'm always listening for it. Any clues? I removed the front wheel, nothing out of place or caught.
My car is a 2006 MCS-JCW.
Thank you,
Joseph
Old Dec 6, 2007 | 01:53 PM
sideshow's Avatar
sideshow
It could be a nail stuck in the tire.
Old Dec 6, 2007 | 01:58 PM
ruftec's Avatar
ruftec
noise
Hi there.
I checked for that too. The tires are nail free.
Old Dec 6, 2007 | 04:15 PM
BBCooper's Avatar
BBCooper
Really hard to pin down noise issue over the web... But with a few question/answers we might be able to narrow it down...
....Does it change with RPM or wheel speed??
....Does it only happen at first start up and or after a drive??
....During Acceleration or Braking (or both)?
I know with mine- I hear the lifter/cam noise when I am very close to walls (like protected on ramps or tunnels)..
Maybe this helps??
Old Dec 6, 2007 | 05:23 PM
usaaus's Avatar
usaaus
Do you have two-piece wheels, others have posted on NAM about those ticking.
Old Dec 6, 2007 | 05:37 PM
ruftec's Avatar
ruftec
noise
It only happens at low speeds 5-8mph.
I have 1pc wheels.
(Enkie Light weight wheels)
Old Dec 6, 2007 | 10:14 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Just as a test to try to narrow down the options, rotate the tires front to back and see if the noise moves.
I had something like this when I had my s-heavies with dust sheilds on. Removing the dust sheilds, although they had clearance, solved the issue. But the most likely situation is something in the tread, my mom's car had alot of rocks in the tread and it makes a lot of clickity sounds at low speed till the tire noise drowns it out.
Old Dec 10, 2007 | 12:15 PM
Ancient Mariner's Avatar
Ancient Mariner
Just in case, check this thread out:
https://www.northamericanmotoring.co...ad.php?t=18230
Mine started out pretty much the same way, then grew into the "playing card on bicycle spokes" version. Just a thought.
scfiveo
Sep 27, 2019 02:27 PM
unxpectederror
Oct 22, 2015 12:16 PM
Qik420
Oct 4, 2015 08:19 PM
Qik420
Oct 1, 2015 12:02 PM
Miniwaukee
Sep 29, 2015 09:22 AM
