Window issue
Old Nov 30, 2007 | 07:30 PM
Phillip's Avatar
Phillip
Window issue
Ok, My drivers side window hisses when going above about 60MPH. The window appears to have a little flex against the rubber sill the window rolls up against. Does anyone have any idea or suggestions on how to fix this. The passenger side window seems "tighter" when all the way up, as it doesn't hiss or move when you apply a little pressure against it. thanks everyone.
Old Nov 30, 2007 | 07:46 PM
Eric_Rowland's Avatar
Eric_Rowland
Does the window still do the little up/down dance when you open and close the door? I assume the last upward dance helps seal it.
Old Nov 30, 2007 | 07:55 PM
lotsie's Avatar
lotsie
The windows can get out of wack. Roll them both down all the way and hold the toggles for a 10 count, release, then roll them back up, this may fix it. If it is not doing the little up-down dance when closing the door, it won't seal properly.
Also if the window is not rolled ALL the way up it won't do the dance. I have done this
Mark
Old Dec 8, 2007 | 10:11 AM
Phillip's Avatar
Phillip
Thanks for the info, I will try the holding all the way down thing. It does do the the little dance, which freaks people out the first time they see it.
Old Dec 8, 2007 | 10:55 AM
joey1320's Avatar
joey1320
if that doesn't take care of it you can adjust the glass to "push" it upwards against the seal.
Old Dec 8, 2007 | 10:57 AM
lotsie's Avatar
lotsie
There are also adjustments inside the door that may be out of whack, dealer should do this for you under warranty.
Mark
Old Dec 8, 2007 | 08:00 PM
Phillip's Avatar
Phillip
The hold the switch down for 10 sec, it works. No window movement since. Thank god since I dont have any warranty left.
woodstudio
Mar 15, 2020 08:28 AM
Dec 23, 2015 10:36 AM
johntotah94
Electrical
Aug 21, 2015 01:52 AM
clintmeister
Aug 12, 2015 11:11 AM
