6 speed throws
Old Nov 17, 2007 | 02:14 PM
GregO's Avatar
GregO
6 speed throws
'06 MCS
Especially when cold, getting the gearshift into any gear can be a *&@!! Once the car is warmed up, the throws seem fine, although a little clunkier at times than I would like. Is this normal or can this be adjusted in any way?
Thanks. Greg
Old Nov 17, 2007 | 07:42 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
It happens to my '03 MCS. Especially if it's left out in the cold during winter.
Old Nov 18, 2007 | 08:24 AM
GregO's Avatar
GregO
gearbox bump
Any others with information? Thanks.
Old Nov 18, 2007 | 08:26 AM
Kimberely's Avatar
Kimberely
I have problems when it is cold also. I have to be really careful with him from 1st to 2nd.
Old Nov 18, 2007 | 08:28 AM
lilruffcat's Avatar
lilruffcat
I thought it was just me.. but from 2nd to 3rd its clunky almost as if third has disappeared and i have to hunt to find it..
Old Nov 26, 2007 | 07:38 PM
verveAbsolut's Avatar
verveAbsolut
How many miles do you have on it?
I recently changed the transmission fluid on my 04/2003 S (45k miles) and it made a world of difference on cold shifting. Before, smoothing shifting only came after 15-20 minutes of driving. Now, it's from the get go, and only gets better.
- Matt
Old Nov 26, 2007 | 08:48 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Originally Posted by GregO
'06 MCS
Thanks. Greg
There is no adjustment but Redline MTL is great and smooths out the box a lot in cold weather. I consider it an absolute necessity. It is really easy to change the fluid in your Mini. One suggestion is to make sure you loosen the fill plug before you remove the drain. It's a just in case procedure.
Rich
embiggenedmini
Oct 15, 2015 12:36 PM
Gremothra
Sep 9, 2015 08:42 PM
tylewis
Sep 6, 2015 01:07 PM
Sep 3, 2015 02:06 PM
Ntety
Sep 2, 2015 08:39 PM
