Stalled...
Old Nov 2, 2007 | 07:23 PM
Beijing66's Avatar
Beijing66
Stalled...
This morning I was able to start the car and back it out of the garage, then I turned off the engine and went back to the house to get something. After I came back the car would start but kept stalling. After numerous attempts I called MINI Roadside Assistance who took the car to the dealer. The dealer couldn't figure out anything wrong with the car and somehow the problem miraculously went away. ??? Does anybody know what this is?
I have only had 1500 miles on this MCS and now this? My condifence is shattered. Maybe I shouldn't have traded in my 2006 MC!
Old Nov 2, 2007 | 07:32 PM
r56mini's Avatar
r56mini
Switch the gas brand. Too much ethanol in the gas will do that to your car.
Old Nov 2, 2007 | 07:35 PM
Beijing66's Avatar
Beijing66
Lately I have been buying gas from Mobil. Theirs is not good enough?
Old Nov 11, 2007 | 11:42 AM
n1tr0's Avatar
n1tr0
look on the pump, it should have a little sticker stating their ethanol blend, just posted about this in another thread, many states have a winter oxygenated fuel program. Even if you're in a state that doesn't have a mandatory program, many of the gas stations may still be using the blended fuel, sometimes all year long.
"Oxygenated gasoline" is a mixture of conventional gasoline and one or more combustible liquids which contain oxygen ("oxygenates"). At present, ethanol is the most common oxygenate in the United States. The government requires gasoline to be oxygenated during the winter in areas that have a carbon monoxide pollution problem (cold weather and atmospheric inversions worsen carbon monoxide pollution). Oxygenated gasoline helps engines run leaner, which helps engines, particularly older engines, produce less carbon monoxide.
it also cuts power & fuel economy slightly.
Old Nov 12, 2007 | 10:08 AM
Beijing66's Avatar
Beijing66
Thanks, so I suppose I should stay away from Oxygenated gasoline?
Old Nov 12, 2007 | 01:16 PM
Bhatch's Avatar
Bhatch
Up to 10% Ethanol is fine, make sure you fill up with 91 octane.
Old Nov 12, 2007 | 01:59 PM
daffodildeb's Avatar
daffodildeb
I don't use anything less than Premium--93 octane. I think it runs best on this. I usually use Shell, or Texaco. Unfortunately, it does have 10% ethenol, unless I go to one of outlying counties that have no air pollution restrictions.
Old Nov 12, 2007 | 02:57 PM
Beijing66's Avatar
Beijing66
I get Premium 93 octane too, should I be checking what's in it from now on? I mean the content might be different between various brands?
Old Nov 12, 2007 | 03:08 PM
daffodildeb
I don't use junk brands--Sams, etc. I know people who have had terrible performance from them (on non-MINI cars). The better ones have cleaning additives.
Old Nov 12, 2007 | 07:15 PM
n1tr0's Avatar
n1tr0
different brands & different locations, eg. a chevron station in the city vs. a chevron in the 'burbs may have different ethanol levels.
remotecontrol
May 9, 2011 09:19 AM
whyme26
Sep 4, 2009 05:19 PM
