Bent rim--problem?
Old Aug 5, 2007 | 03:00 PM
Wolfshiem's Avatar
Wolfshiem
Bent rim--problem?
I was poking around my MINI today and came upon this gem. The rim on the inside rear passenger wheel is bent. As far as I know it has been there for a long time. Assuming no air is leaking, is this a problem? How about when I go to buy new tires, will this cause any issues?
I'm not sure what could have caused it as there seem to be no scrape marks or impact points, but I presume it would not be a warranty repair. What's the going rate for an S-Lite these days?
Thanks!
Attached Thumbnails Bent rim--problem?-p8050005.jpg   Bent rim--problem?-p8050006.jpg   Bent rim--problem?-p8050008.jpg
Old Aug 5, 2007 | 03:09 PM
PGT's Avatar
PGT
if it's not leaking and it's not causing balance issues, it's ok for now. keep your eyes out for a single replacement wheel....should be less than $100.
Old Aug 5, 2007 | 03:10 PM
Robb's 07 Red MCS's Avatar
Robb's 07 Red MCS
Would probably replace it because it's now out-of-round. Have a tire shop put the litmus test on my rationale, but it would be better to replace it becuase the tire/rim contact area has been compromised.
Hope this helps,
Robb
Old Aug 5, 2007 | 03:17 PM
Wolfshiem's Avatar
Wolfshiem
After looking more closely at the pictures, I notice a line from a black marker...probably indicating the issue...so I am guessing it has been there for some time.
It looks like I'll be shopping for a new/used S-Lite.
Old Aug 5, 2007 | 04:17 PM
JAB 67's Avatar
JAB 67
I doubt that any reputable tire shop would agree to install a new tire on that wheel in its present condition.
Old Aug 5, 2007 | 04:41 PM
Wolfshiem's Avatar
Wolfshiem
That was my assumption too.
Anyone have any guesses as to why someone would mark it? Unfortunately, it's only speculatation, since I bought it used.
Old Aug 5, 2007 | 04:49 PM
chadtoolio's Avatar
chadtoolio
I have noticed a mark on almost every bent wheel where the rubber puts a mark on the rim at the bend point. It's almost easier to see than a bend.
LostDenverite
Feb 10, 2016 04:59 AM
09R56
Oct 12, 2015 09:04 PM
Fordgt4
Oct 10, 2015 10:42 AM
The Rossness
Sep 17, 2015 03:06 PM
