Bad Clutch?
Old Aug 1, 2007 | 04:11 PM
  #26
MattMan's Avatar
MattMan
Coordinator :: Minis Under the Arches (Oct 25-28)
Surprisingly, I've seen plenty of Mini's serviced with all sorts of mods, some very heavily. But this is talking about stock items, things that we haven't altered, and we're getting dinged for a car company's poorly made part, when we're being told that the powertrain is included in our warranty. Sad to say it, but I wish my buddy hadn't bought his Mini. $2500 out of his pocket due to some small print.
Old Aug 1, 2007 | 04:12 PM
  #27
MattMan's Avatar
MattMan
dbl posted
Old Aug 1, 2007 | 04:17 PM
  #28
Keysersozeh's Avatar
Keysersozeh
Getting hit with an expense like that with a fresh car, would really ruin that car for me. (New Car Experience, The Mini Love, and the idea of possibly modding) I would be scared to do ANYTHING with that car.
Old Aug 1, 2007 | 05:58 PM
  #29
bazarus's Avatar
bazarus
Originally Posted by Keysersozeh
They shouldn't charge you anything, unless they start taking things apart and find out it's wear and tear.
Bazarus, where you located?
Utah....
Old Oct 23, 2007 | 03:12 PM
  #30
mini552's Avatar
mini552
I read all the posts in this thread, and didn't see exactly the issue I have with my 2006 MC clutch. I've never had one engage so late - i.e. at the very end (top) of pedal travel. In addition, it sometimes feels as though its going to stall if you don't sort of "feather" the engagement at the end, and if you have the a/c/ going it almost "chatters." Mentioned it to service advisor on first service, and he said "can't adjust, it's hydraulic" - sort of a variation on the "they all do that" answer. Love driving the car, but hate the clutch action. I've had numerous manual tranny cars and never had trouble with smooth engagement before.
Old Oct 23, 2007 | 10:01 PM
  #31
GOLDRUSH's Avatar
GOLDRUSH
Originally Posted by bazarus
I was driving up the canyon this weekend and at the very top on the steepest heel I had to stop and then go again (the car had 3 passengers and some cargo) and the car wouldn't go. I can start moving the car on any heel with hand brake or without, never had a problem. In this case it looked like the engine wouldn't pull the car up. The clutch would be fully released and my gas was fully floored and the car would stutter and wouldn't move up and finally stall. It took 3 attempts of stalling and trying to move again. Now I’m concerned and looks like my clutch is slipping when I shift in 4th and 5th. I can't tell if it started slipping before the accident or just after. May be it is not slipping at all and it is my imagination. Any ideas? What should I do take it to the dealer? What should I tell them?
I know this may be a rudimentary explanation for this, but have you checked you air filter recently, this problem could be caused by the car not being able to breath, or get the air out quick enough.
Old Oct 29, 2007 | 05:21 PM
  #32
rideM3's Avatar
rideM3
Yeah I got a quote from the mini dealer in concord for $2200.00 and my jaw fell to the floor. I than had my clutch replaced at eastbay mini and it cost me around $1750.00. Come to find out the reason that it cost so much is because you have to drop the front subframe out of the vehicle. The service advisor was nice enough to take me out ot the shop and showed me everything that needed to come off in order to replace the clutch, which was way beyond my mechanical skills. I recommend going to Eastbay Mini becuase the experience i had was great.
Old Oct 29, 2007 | 08:39 PM
  #33
BAT's Avatar
BAT
weird clutch
This is a slighty different tangent- I have a '04 S w/28K (of course, the warrantee is out- in San Francisco: think hills and lots of parking brake/clutch scenarios) weird squeeking sound as the clutch engages in first when cold, but fine once warm. Perhaps clutch is just worn and ready? Perhaps related (or not) once warm, in neutral at stop, clutch out, weird knocking sound. Kinda like with my 1960 Morris Mini- needing its valves (tappets) adjusted sound. This knocking sound is not consistent. Would this be the clutch as well? Perhaps a warped plate? BAT SF
Old Oct 29, 2007 | 11:09 PM
  #34
im1hapa's Avatar
im1hapa
My partner has an early 05 build MCS JCW (July 04) with 27K on the clock. His clutch started squeaking when engaging the clutch at about 25K. He took it in to MINI SF, and they told him that his clutch was going to be needing replacing soon, but that MINI will be more likely to kick clutch issues back if the car has under 30K miles on them. They said that since it is still working, they would say that they lubed some part on the pedal for the time being, and then just bring it back in at 30K, where it would be replaced without question under the maintenance plan. Sounded fishy to me, but we agreed. Now we have to worry about his clutch going out on the streets of San Francisco at any time. More recently, his clutch seems to be getting worse as the squeaking noise has increased and it isn't grabbing smoothly anymore. I dunno if we are going to make it to 30K.
I have a May 05 build with 30K, mainly freeway miles. I haven't had any major issues yet. However, with all the problems that my partner has had with his (other things besides the clutch), it makes me worry about keeping mine past 4 years/50K (we both got the extended service plan).
Motoringfile.com just released a buyers guide today for the R50/R53, and one thing that was suggested to look out for across the board was flywheel/clutch issues. Check it out here at http://www.motoringfile.com/mini-r50r53-buyers-guide/
Old Oct 29, 2007 | 11:11 PM
  #35
im1hapa's Avatar
im1hapa
That is how my partner's 05 MCS JCS started. It would squeek when cold, and then go away once the car warmed up. Now it just squeaks all the time, and it doesn't engage smoothly anymore. Keep a watchful eye out.
Old Oct 29, 2007 | 11:40 PM
  #36
ScottRiqui's Avatar
ScottRiqui
I could pay the $300 for the new clutch and all the labor would be covered due to the bulletin for the flywheel needing to be replaced. OR I could try to claim everything with the possibility it could be kicked back in which I would then be on the hook for the $2000+. I'm not a betting person, but I like my odds with the $300 versus the $2000+.
That really sounds like your dealer is making a veiled threat (trying to get you to eat the $300 for the new clutch by making you think that you'll be on the hook for $2000 if MINI declines it).
Why not hold off on the flywheel replacement until you get a ruling from MINI on the clutch? If they approve it, you're not out-of-pocket for anything. If they decline it, you should still be able to get the same deal they're already offering (you pay $300, and they replace the clutch when they replace the flywheel per the bulletin).
Old Oct 30, 2007 | 04:47 AM
  #37
THE ITCH's Avatar
THE ITCH
Would anyone know exactly what the bulletin says the problem is with the flywheel?
Thanks, Steve
Old Nov 5, 2007 | 09:29 AM
  #38
BAT's Avatar
BAT
weird clutch
I'll be taking the car in next week I'll post an update. The knocking sound is louder, and the the squeeking has not healed it self.
BAT
Old Nov 5, 2007 | 11:08 AM
  #39
geowit's Avatar
geowit
Well, I've got 108K on my original clutch and it still does not slip and that is definitely not all highway driving. I've had other things go out (i.e throttle body, power steering fan and pump) but the clutch has not been an issue.
Old Dec 8, 2007 | 04:32 PM
  #40
10851CS's Avatar
10851CS
Spoke to the dealership yesterday.
They are replacing the flywheel because they have a bulletin about it. When they removed the tranny they said the clutch needs to be replaced. He said from what he saw it looks like the clutch had seen above normal amount of action. He gave me an option.
I'm not thrilled about the $300, but it's better than more than that.
I asked the tech, is it common for Mini clutches to blow this early. He mentioned that he has seen clutches come back at 1,000 , 5,000, and even 100,000. Which really didn't tell me a whole lot.
I'm not exactly thrilled with the out come, but I'll happier than what it could be. I appreciated the tech phone call and thanked him. This conversation could have gone very differently.
My throw out bearing went out at 30,000 miles and the dealership replaced it at no charge. The said if I wanted a new clutch disc they would do it at no additional charge. I looked at the old one, which looked as good as new, (I had worked many years in auto/truck parts and have seen a lot of them) and I did not even ask how much -- just told them to put it back.
I now have over 118,000 miles and it is still going.
Earl
Old Dec 8, 2007 | 04:57 PM
  #41
lkbindustry's Avatar
lkbindustry
I think I have been extremely lucky... 95k on my original clutch...
and its been beaten to who knows what!
I did here that www.GrassRootsGarage.com charges $650 for clutch + flywheel install....
Old Dec 8, 2007 | 08:17 PM
  #42
Rich.Wolfson's Avatar
Rich.Wolfson
...I could pay the $300 for the new clutch and all the labor would be covered due to the bulletin for the flywheel needing to be replaced. OR I could try to claim everything with the possibility it could be kicked back in which I would then be on the hook for the $2000+. I'm not a betting person, but I like my odds with the $300 versus the $2000+....
The FACT is that Mini USA takes the word of its dealers as to what they cover or not. That is why some dealers cover things that others don't. I know this because when I had an issue I drove over to Mini central here in NJ and got to a person high in the chain. His quote to me is "that is what we train them and pay them for". In your case if the flywheel is covered under the TSB then if they put the clutch in there too they could only deny that (which they wouldn't as it wore under the 36,000 mile maintenance warranty) and the worst you would be out would be the $280 list for the clutch an plate. I think the line they gave you was unconscionable. Care to say what dealer it was?
That said as someone who has been driving a stick over 40 years, you should work a bit on your technique as if you were on a hill and starting smelling your clutch, whatever technique you were using was not great.
Rich
Old Dec 8, 2007 | 10:53 PM
  #43
sandersonc2002's Avatar
sandersonc2002
Wow 95k on your original clutch!?!? My 03 Cooper's clutch got replaced at 15000 miles and my 06 Cooper S that I have now is starting to squeal when engaged at 10500 miles with hardly any hard driving and no track use. You are extremely lucky. I'm scared to go to the dealer cause I don't want to get stuck with a $2000 charge. My first one got replaced free of charge, but not before they tried to make a case that I was abusing the car.
patsum
26
May 29, 2021 06:29 PM
Quixotic1
Sep 11, 2015 11:15 AM
marc0011
Sep 10, 2015 10:04 PM
wildwestrider
Sep 4, 2015 06:25 AM
Sep 3, 2015 02:06 PM
