Does your car weep?
Old Aug 17, 2007 | 09:49 AM
  #76
rattmobbins's Avatar
rattmobbins
Mine seems to have stopped weeping completely. Even the back wiper, which was weeping profusely for a while there. The stuff coming out of my wipers didn't stain my stripes either. Guess I should count myself lucky.
Old Aug 19, 2007 | 06:27 PM
  #77
kevinminict's Avatar
kevinminict
Yeah I noticed today mine are doing it as well. Both left and right washer nozzles!!!
Old Aug 20, 2007 | 05:12 AM
  #78
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
add me to the list, mine leaks all over the hood
I'm giving it another 2 weeks, if it's still leaking I'll start doing the warantee run around
makes me wish I bought used
Old Aug 20, 2007 | 07:36 AM
  #79
minimk3's Avatar
minimk3
here's link to another discussion.
https://www.northamericanmotoring.com...d.php?t=102529
Originally Posted by minimk3
is this how it looks?
i used goo-gone and paper towel to remove the cosmoline. It came off easily.
the result...
Old Aug 20, 2007 | 08:41 AM
  #80
MrBlah's Avatar
MrBlah
that's a different issue, the windshield washer nozzels are leaking wiper fluid, not cosmoline
Old Aug 20, 2007 | 09:42 AM
  #81
rattmobbins
Not so. Read the entire thread, and you would see that people are not exactly sure WHAT is leaking, just that something IS leaking. Could be cosmoline, could be washer fluid.
Old Aug 20, 2007 | 09:45 AM
  #82
MrBlah's Avatar
MrBlah
ohh
well I guess I should start another thread, mine is only leaking washer fluid
if anyone cant tell the difference between cosmoline and washer fluid, well, they need help
Old Aug 20, 2007 | 10:08 AM
  #83
Kasey's Avatar
Kasey
ohh
I need help!
Seriously, I thought mine were leaking washer fluid, but I never saw any dripping out, I just found these little dry trails down the hood. Only happened while the car was parked.
It stopped after I drove for 20 minutes through a torrential rainstorm, so now I'm thinking it was cosmoline trapped between the jet fixture and the hood and the storm washed it away.
I'm not questioning yours is something different, just pointing out I couldn't tell the difference. And I'm glad it stopped.
Old Aug 20, 2007 | 10:18 AM
  #84
MrBlah's Avatar
MrBlah
water spots wipe off, that's what I get on my hood from the washer nozzels lal the way down, I suspect the water boils or expands in the washer lines, and has no where to go but out
cosmoline is like tar, it's sticky gooey crap, mine leaks it aorund the wheel wheels and down the front of the bumper, it's hard to wipe off
Old Aug 20, 2007 | 10:24 AM
  #85
Arnbut's Avatar
Arnbut
I think that there's two separate but connected conditions.
My yellow car used to run very hot. Hot enough that the fluid would heat up in the lines and squirt out ---- you could witness it coming out in a little stream.
My new green car doesn't do that. And I've never actually seen fluid coming out of the jets, per se. But I do have trails from time to time. And they wipe off pretty easily, unlike cosomoline.
I use the windshield washer as little as possible now.
Old Aug 20, 2007 | 10:29 AM
  #86
Kasey's Avatar
Kasey
This is very interesting. The trails on my hood came right off with a spray detailer. This makes me think it was washer fluid and not cosmoline.
That would make the timing with the storm and the trails stopping coincidental.
I wonder why it stopped? Resevoir level? I haven't refilled it yet.
Old Aug 20, 2007 | 10:57 AM
  #87
MrBlah's Avatar
MrBlah
spray detailer, like wax remover? if so, that will instantly remove cosmoline, it wipes off like water after you hit it with a wax remover, when my car was being delivered they missed some, amanda my sales rep hit it with some of that wax remover and the stuff wiped right off, then they put on some spray wax back over what was removed
I was thinking it was the washer lines themselves, so once it leaks onto the hood it wont leak again until you use the washers, which "re primes" the lines
a simple fix would be to eliminate the check valve in the washer pump system, if that is possible, but if you do that, you'll have to hold the wash button a few seconds before washer fluid will come out, BUT, no streaks down the hood
Old Aug 21, 2007 | 07:10 PM
  #88
nigillian's Avatar
nigillian
I'm way late in this whole but my car definitely weeps washer fluid now and then. I know its washer fluid because I've already repalced teh factory stuff with green summer rain-x stuff, and when I wiped it off it was green.. before this is was deep blue I think. Not too worried about it.. hard enough to keep the damn wheels clean!
Old Aug 22, 2007 | 11:23 AM
  #89
Xray'dit_Mini's Avatar
Xray'dit_Mini
i think you nailed it right on the head! My car never wept in the last 4 months. but, yesterday I used the washer jets for the first time and what do you think happened shortly thereafter???? thats right you guessed it they wept.
There would be a couple of options to fix this:
1 move the washer fluid bottle
2 insulate the bottle and all the lines
3 remove the check valve
removing the check valve would be annoying because you would have to hold and prime the lines each time......but I would rather do that then clean the hood each time. I'm sure it would be the easiest fix aswell.
Old Aug 22, 2007 | 12:13 PM
  #90
greylight's Avatar
greylight
Yeah, I'm wondering if the folks that had weeping, then stopped, just might not have used their sprayers in a while.
(So after reading this, they all go out, try their sprayers, come back and realize: "Now why did I do that?! It's gonna start leaking again!")
gl
Old Aug 22, 2007 | 05:53 PM
  #91
crump500's Avatar
crump500
Zoey just back from service today with a leaky washer jet issue, they could not repair it on the spot and had to order a new washer jet. They are also going to install a check valve to keep the fluid from seeping up and out. It appears the jet was not sealed properly. So I am waiting on parts...
Old Aug 24, 2007 | 02:37 PM
  #92
Ex-Pat Brit's Avatar
Ex-Pat Brit
Cosmoline versus Jif(peanut butter)
And the winner is ....... peanut butter
Looks like it will take a few treatments, and then wow or back to black, but yes peanut butter removes cosmoline from plastic trim
Old Aug 24, 2007 | 02:55 PM
  #93
korby's Avatar
korby
I was at Irvine Mini this week , its been pretty hot for a while and all the cars on the lot were dripping cosmoline all over the place .No way there going to sell those cars looking like that .
Old Aug 24, 2007 | 03:15 PM
  #94
MrBlah's Avatar
MrBlah
please post if this fixes it
If It does I'll bring mine in for the same fix
Old Aug 24, 2007 | 04:36 PM
  #95
Xray'dit_Mini
The dealer gives the cars a Kerosene bath to remove the Cosmoline......which may be a bit less messy
Old Sep 3, 2007 | 06:24 PM
  #96
aem421's Avatar
aem421
Picked mine up on 8/31. No weaping yet. Does everyone have this check valve on theirs? It's right in the middle of the hood...
Old Sep 3, 2007 | 08:53 PM
  #97
Xray'dit_Mini
have you used the washers yet? It seems that it only happens for a day or two after I use them, and then nothing.
Old Sep 4, 2007 | 04:17 AM
  #98
aem421's Avatar
aem421
Yeah, I was wondering that too. I think I've used my washers twice in about 20 years . I hate those things. Maybe I'll have to use them to see if they really weap or not. I'll let you know.
Old Sep 4, 2007 | 05:56 AM
  #99
Arnbut's Avatar
Arnbut
I just stopped using my washers too.
No more weeping.
And it only runs hot if I drive the car; if you don't drive it, there's no problem.
Duh.
Old Sep 5, 2007 | 12:34 AM
  #100
alicecooper's Avatar
alicecooper
I wrapped my washer lines with Renyolds Alum wrap and drilled two 1\16" holes in the resevoir cap, to release the pressure from the heat build up in the resevoir. It has not wept since.
It previously left some small etch marks in my uncured clearcoat.
