Replacement battery options for MC
#126
I went to dealer and he is asking $300 battery and installation that a rip off in my books.
Went to Costco and got "group 47 batteries" which according to manufacture should fit my MC 2006.
Now is it simple as pulling the battery and replacing the terminal or something special with MC?
Someone said about charging it lighter plug to my setting in place.
I have replace battery in Toyota cars and it was a breeze..
Any help will be appreciated.
If you want to keep the charge during the swap via the lighter plug, you'll need to keep the ignition
at least partially on so that power goes to (and from) the lighter plug.
This would prevent you from having to reset the clock or losing your trip odometer miles or your
dash light brightness setting. This is optional in my book.
Radio settings don't seem to be affected by disconnecting the battery.
#127
Not all group 47 batteries are a direct fit for the 1st gen MC. See post 2 for a summary so far.
if it just radio, trip odometer and least imp thing, then I don't need to worry.
Thanks for good info
#128
The engine adaptation might be reset if you have the battery off long enough, but if so,
it will re-learn that quickly. If so, driveability might be slightly different for the first 1/2 tank after the reset.
There is some controversy over whether this is true or not. I think it's bullcrap.
You could lose some fault codes in the OBD, so they say to read them before disconnecting.
I've only had to reset the clock and the brightness on the dash, and remember what the trip odometer was before
disconnecting for mileage calculation purposes. The radio doesn't lose its presets or go into safe mode as it does
on some other cars (VW for one).
If you disconnect the battery right before emissions testing, I can imagine
that the obdii might not be "ready" for them to read until it's driven for a bit,
whatever constitutes a full drive cycle, but that's just conjecture on my part.
#129
One more thing about disconnecting the battery, you have to re-initialize the
window motor, or it won't drop 1/4 inch on opening the door properly untiil you do.
Just put the windows down, then put them up while holding the switch until
they're fully up for 5 or 10 seconds, then let go of the switch. Done.
Just noticed my door was opening and closing with some difficulty after my
thermostat gasket and housing was changed the other week (this involves
removing the battery tray and ecu to get to it).
#130
This really ties it together for me. Just yesterday I noticed that my window was not "dipping" and found the reset cure in another thread.
Your post ties that together with the fact I just changed out my battery.
And a related question/comment. I assumed it best to reset the window while sitting in the car with the door closed. I mean, if you did it with the door open, it would have to "know" that and dip the window after the reset in anticipation of closing. But if you do it with the door closed, it will (should) activate when you pull on the door handle.
Any idea if this is necessary?
#134
It's a Kirkland Signature Battery. 7yr warranty. It's made by Johnson Controls who also makes Duralast, Interstate, NAPA, and a bunch of others.
#136
This battery battery fit perfectly.
Read all the posts. Then went out and looked at most of the options.
I purchased and installed a INTERSTATE MEGA-TRON PLUS (MTP-47/H5) battery in my 2006 Cooper S. The only tool needed was a 10mm wrench. Fits perfectly. Has the vent tube hole in the exact position needed and the specs on the battery are better than the original battery. Cost $152 with tax and trade-in. This battery also has an 85 month warranty.
#138
Apparently, you didn't real all the posts.
This thread is about batteries fitting the regular MINI Cooper, not the S.
Some fit both, some fit one, but not the other, so I feel compelled to be irritatingly pedantic here again.
#139
Dear Cristo, Sorry for my confusion. I was so happy to get a battery that fit with out resorting to modifying brackets I lost my head. I have to complement the customer service people at Interstate battery who knew exactly what I needed and even found me a dealer that stocked the right battery 5 min from my house. Also the ABS and tire sensor lights have stopped going off now that my MC-S has a new power source.
#143
My 2nd battery suddenly died, and the shop put in an
Interstate MT-47 Mega Tron II
- it's a little wide for the bracket - it will fit if you have one side of the
bracket pinch the raised edge and ride up about 3/8 inch from fully tightening the bracket.
The cover fits if you do that.
Specs: 590 CCA, 740 CA, 29.6#, 51 Ah, 612 Whr, Reserve 85 minutes at 25 A.
6.88 W x 9.63 L x 7.00 H
#144
Hello,
I joined just so I can contribute to this thread since I found it via Google and it helped me out today.
My 2005 Cooper OEM batter went belly-up (maybe I should say belly-out as it was all bulged out - totally gone).
I was originally going for an Optima red top but they don't make one that fits our plain vanilla Coopers.
Anyway, I can confirm that for me and my '05, the Batteries Plus Rayovac RayMax battery (SLI47H5M 12V 47 RAY MAX 3/65 647MF, L2/47-E108) was a direct, no-modification, drop-in replacement. It even had the vent hole in the exact right spot. I set the two batteries side by side and they were identical in all measurements, the only difference being the color (black vs white for OEM) and the nifty handle which made dropping it in a piece of cake.
Purchased on 4-1-2012. No, this is not an April Fools joke. I think the joke was on me for having to buy a new battery.
Hopefully this helps others out like it did me.
#145
Hello,
Actually, the battery is the first thing I had to change when I bought mine back in Aug. 2011.
#146
Installed a Autozone Duralast Gold H5 DLC battery in my 2005 Mini Cooper today. Exact fit, no issues. The newest ones have a handle on them (they had two on the shelf, one with and one without a handle). For the ones with the handle, be sure to get the yellow post cover that comes with it, as it contains a plug that you need to insert into the vent hole you won't be using (the one nearest the fire wall).
#147
Me too
Thanks for posting!
...............Gary
#148
This is a non-S thread. The 'S' thread is here: https://www.northamericanmotoring.co...s-for-mcs.html
Anyway, glad you got some helpful information.
#149
#150
Canadian replacement battery
Great thread! For readers in Canada, I used the suggestions/measurements/pictures here and checked out the batteries available at local Costco, Wallmart, NAPA, PartsSource etc (no Batteries Plus or Autozone up here). Found that the Motomaster Eliminator (Product #10-4785-4, 650CCA/780CA, Group 47/L2/H5, $119.99) from Canadian Tire had the right dimensions and shape so picked one up for my daughter's 2006 Cooper (she'd left the trunk partially open overnight, had to get a jump in the morning, and then found that it was still barely starting a week later). It dropped right in, perfect fit, vent hole in the right place, bracket fit fine. Looks like this battery is readily available here north of the 49th!
