CVT Fluid Change
Old May 31, 2007 | 05:53 AM
StillK's Avatar
StillK
CVT Fluid Change
As I try and maintain my vehicle per manufacturers recs - I called to schedule a routine fluid change on my 2003 Mini CVT. The service rep stated that the fluid change was not necessary - that in early 2003 the fluid specs from Mini had changed and the newer 2003 and on Cooper CVTs (including mine) came with a lifetime fluid. As the change is relatively expensive am I wasting money by doing this - and also has anyone else received the same info from their service reps? Recommendation that came with my Mini definitely recommended a change at specific intervals.
Old May 31, 2007 | 06:07 AM
welshmenwillnotyield's Avatar
I guess you COULD get a "second opinion" from another MINI dealer if you are in doubt. I can't speak for myself, as my '03 Cooper is an early model. I already got the fluid change, and yes, it IS expensive.
Old May 31, 2007 | 08:22 AM
blue_rocket2's Avatar
blue_rocket2
After I had my second CVT fluid change (Inspection II) I started having tranny/bearing noises with my MINI. I wonder if MINI is changing its tune on the CVT fluid changes to avoid "issues".
Old May 31, 2007 | 08:48 AM
I had some leakage probs [at about 4k] when I first got my MC, so when it came time for a fluid change, I was all for it. Given the cost, however, I'm not sure I'll be doing THAT again anytime soon, unless the leakage problems resurface. That said, I'm certain they are a thing of the past, as the car has run fine ever since they were corrected. My MC has 33k.
Old May 31, 2007 | 11:25 AM
caminifan's Avatar
caminifan
And just biting the bullet on the transmissions that fail before the warranty period is out....
whosurgaddy
Aug 29, 2015 09:50 AM
Aug 25, 2015 09:33 AM
HaveATank
Aug 24, 2015 10:26 AM
sprp85
Aug 22, 2015 06:16 AM
FLYM1N1
Aug 16, 2015 01:17 PM
