FS:: R56 part out!
Old 03-15-2016, 01:15 AM
johntotah94's Avatar
johntotah94
johntotah94 is offline
R56 part out! PERFORMANCE MODS! METH, INTAKE, WHEELS, EXHAUST!
Price: $3
Location (Region): Midwestern
PARTING OUT R56
Unfortunately due to an accident....
1)R56 Floor Mats - $40 SOLD
2)R56 Cargo Lid/Shelf - $80
http://new.minimania.com/part/G2NMI7...Mini-Cooper--S
3)5MM Hub Centric Wheel Spacers - $20 SOLD
4)NM Engineering Intake N18 UPGRADE - $180
5)NM Engineering Intake with Pipe and JMTC Silicone for Turbo Upgrade - $350
6)DevilsOwn DVC-30 Meth Injection Kit - $300 SOLD
(Meth Pump, Meth Controller with boost line, add a circuit for switch, Check Valve, DO7 Nozzle)
*Need to extend harness or buy new harness and need to purchase 1/4” tubing, I had to cut harness and tubing upon removal*
http://www.alcohol-injection.com/en/...-stage-2a.html
7)R56 Black Headlight Rings - $65 SOLD
https://www.waymotorworks.com/black-...ght-trim-ring…
8)R56 Map Sensor - $10
http://www.eeuroparts.com/Parts/6589...or-0261230253/
9)DevilsOwn Meth Electric Solenoid - $40
http://www.alcohol-injection.com/en/...-solenoid.html
10)R56 MAF Sensor - $100
http://www.eeuroparts.com/Parts/3637...or-0280218205/
11)NM Engineering Boost Sensor Tap - $20 SOLD
http://www.nm-eng.com/nm498856-nm-en...ensor-tap.html
12)Team Dynamics Pro Race 1.2 Wheels 17x7 et45 4x100 with TPMS Sensors - $700 SOLD
http://www.outmotoring.com/mini-coop...-pro-race.html
13)My Custom CravenSpeed Intake Manifold Spacer - $250
(4 DevilsOwn DOT2 Nozzles with 4 way splitter for Direct Port Injection)
*Complicated install with the nozzles in place, Some modification required*
http://www.cravenspeed.com/the-koala...nifold-spacer/
14) iPod Media Cable w/ Lightning Adapter BMW 61122344300 -$50 SOLD
http://parts.seattlemini.com/p/Mini_...122344300.html
15) MINI OEM Catted Downpipe - To be determined, Email me
16) MINI Second Cat - To be determined, Email me
LOCATED ELK GROVE, CA
EMAIL ONLY
jtotah94@icloud.com
Attached Thumbnails R56 part out!-12841313_10208321278096815_395989443568491508_o.jpg   R56 part out!-12829409_10208321284096965_4008184508281850723_o.jpg   R56 part out!-12829369_10208321283456949_3164187643036856292_o.jpg   R56 part out!-12829250_10208321282976937_877299549145655678_o.jpg   R56 part out!-12829163_10208321283056939_5371097432803108012_o.jpg
R56 part out!-12633687_10208321282576927_7108347679354977151_o.jpg   R56 part out!-12495946_10208321283616953_6291559836308468533_o.jpg   R56 part out!-886620_10208321278376822_4604028679528107268_o.jpg   R56 part out!-img_4187.jpg
Old 03-15-2016, 01:19 AM
johntotah94
Cable
ADDED: iPod Media Cable w/ Lightning Adapter BMW 61122344300
Also supports data for MINI Connected App Sync
Attached Thumbnails R56 part out!-993542_10208321570224118_1632671022797714433_n.jpg
Old 03-15-2016, 12:48 PM
laforze's Avatar
laforze
laforze is offline
How about the turbo? Was that salvagable?
Old 03-15-2016, 12:50 PM
johntotah94
I was not able to remove it, would have took a ton of work to do in the back of a tow yard. And the turbo had a loose wastegate which needed to be repaired.
Old 03-15-2016, 01:14 PM
Grizld700's Avatar
Grizld700
Grizld700 is offline
Ouch. All that work. Any plans for the next ride?
Old 03-15-2016, 05:27 PM
johntotah94
Just ordered new F56 S Hatch
8-10 weeks ........
Headlight Rings SOLD Locally!
Old 03-15-2016, 09:07 PM
Ecuamini's Avatar
Ecuamini
Ecuamini is offline
Emailed you
Old 03-15-2016, 09:24 PM
Indimanic's Avatar
Indimanic
Indimanic is offline
Sorry totes
What about that manifold setup?
How does that fit with such limited room between air box and bulk head?
What did you do with the OZ wheels?
Old 03-15-2016, 10:57 PM
chav's Avatar
chav
chav is offline
all four spacers for $20?
Old 03-16-2016, 12:47 AM
johntotah94
Originally Posted by Indimanic
Sorry totes
OZ Wheels got more and more bent overtime. Roads here are horrible. And got more bent with the accident...
Manifold setup was a tight squeeze. Theres a wiring harness below the intake manifold that has to be moved to fit the spacer because of the nozzles in the way.
Old 03-18-2016, 11:33 AM
johntotah94
bump
Old 03-18-2016, 12:41 PM
GeneralSpecific's Avatar
GeneralSpecific
GeneralSpecific is offline
Take another look at your links... many are broken.
Old 03-18-2016, 12:49 PM
johntotah94
Wow all jacked up. Fixed them. Thanks!
Old 03-22-2016, 12:49 AM
johntotah94
Want the NM Intake sold!
Old 03-25-2016, 11:48 AM
johntotah94
Bump! I need the intake sold! Email Me!
Old 03-25-2016, 04:06 PM
Sleepy289's Avatar
Sleepy289
Sleepy289 is offline
I am interested in the cargo lid/shelf.
Old 03-25-2016, 04:16 PM
johntotah94
Great. Where are u located? I would have to figure out how to ship this.
Old 04-01-2016, 12:44 PM
johntotah94
Wheels sold
Old 04-01-2016, 09:20 PM
agordon1337's Avatar
agordon1337
agordon1337 is offline
pm about intake
Old 04-03-2016, 12:04 AM
agordon1337
Sent pm
Old 04-05-2016, 04:50 PM
johntotah94
Bump
Old 04-14-2016, 04:07 PM
johntotah94
bump
Old 01-06-2018, 06:57 AM
cornjuice's Avatar
cornjuice
cornjuice is offline
Necro bump.. is that Mani spacer still around?
Old 01-20-2018, 11:09 PM
Chrisstone32's Avatar
Chrisstone32
Chrisstone32 is offline
intake still for sale?
NVmini
02-29-2016 09:07 AM
USA-RET
02-27-2016 07:47 PM
tylewis
02-19-2016 05:38 AM
02-16-2016 08:26 AM
simpsoap
02-15-2016 04:42 PM
Quick Reply: FS:: R56 part out!
