Roll call - 8"+ wide wheels
Old 05-07-2016, 11:28 AM
Alan's Avatar
Alan
Alan is offline
Originally Posted by miniuy
you tried (rolling the metal under the plastic) and then, you decided to cut it (because rolling was not enough)
Exactly
  #902
Old 05-09-2016, 11:28 AM
miniuy's Avatar
miniuy
miniuy is offline
Total success!
The inferior metal lip (thinner) was folded and then all the metal edge where the plastic arch is supported was pulled out, getting a wider space, gaining about 1 1/2 inches. Special care with the zone where the holes for the plastic clips are present.
Additionally, after installing the plastic arch, it is open some more degrees, generating a wider plastic arch without a noticeable visual distorisión.
Fender guard was not modified it is supported on the plastic arch.
No more rubbing at all. I am more than happy after two days of hard and precise work.
I'll be uploading photos as I can.
I hope my comments can help anothers using wider wheels with low offset without the need for major changes.
  #903
Old 05-11-2016, 07:38 PM
qirlie's Avatar
qirlie
qirlie is offline
I have a staggered setup.
Wheel/Model: Klutch Republik SL1s
Offset: et15 Fronts, et18 Rears
Wheel Size: 16x8, 16x9
Tire Size: 195/40/16 all around Federal 595 EVOs
Suspension: Megan Euro Streets Coilovers - I don't know how much I am dropped, I'm maxed out with 2 collars removed in the front, 1 collar on each side removed in age rear. Also have Swift Metric Coilovers Springs that are for the fronts, will be installed soon. I have Megan Adjustable End Links for the camber.
Camber Settings: -.7 F, -6.1 R
Rubbing: nope.
I don't daily this car anymore.
Teabudy (04-20-2020)
  #904
Old 05-26-2016, 07:15 PM
boydie's Avatar
boydie
boydie is offline
Total success!
Thanks, this did help me as I am about to roll my fenders in the rear. I'm running 215/50 16x8 25et. I'm actually going to try and sell my tires though and run 215/45. No rush getting my car on the road.
  #905
Old 06-09-2016, 10:47 AM
MEHMini's Avatar
MEHMini
MEHMini is offline
17x8 ET35 <br/>215/45<br/><br/>Lowered on BC Coilovers
  #906
Old 06-28-2016, 07:13 AM
Dr. Spade's Avatar
Dr. Spade
Dr. Spade is offline
Those look great.
Anyone see the New 17X8 4 lug Tire Rack C4 wheel?
It's rather inexpensive and I'd trust them. Unknown specs other than it fits a ND Miata
  #907
Old 07-03-2016, 10:31 AM
BRG56's Avatar
BRG56
BRG56 is offline
Sorry to jump in and ask a question, however, I'm looking into an 8" wheel. With everything stock on my 2013 JCW, would this application work well? I was looking at 18" wheels if that helps. Thanks!
  #908
Old 07-03-2016, 10:54 AM
mini coop's Avatar
mini coop
mini coop is offline
Depends a lot on the offset and how far out you'll be moving the wheel. Being that a JCW suspension is approximately 3/4" lower than an S or base, moving the outside of the rim/tire too much may cause scrubbing on the wheel arch under load or during harder undulations. The only solutions then may be to stretch a narrower tire onto the 8" rim causing it to fold under the lip. The other solution may be at that point to adjust your camber so again the outside is angled under the wheel arch. Being an 18" doesn't help as the diameter/circumference between any wheel/tire combination should remain approximately the same as stock so to maintain revolutions per mile and keep your speedometer, tach and miles accurate.
  #909
Old 07-03-2016, 03:30 PM
BRG56's Avatar
BRG56
BRG56 is offline
thanks for all the great info mini coop. I'm still not sold on the 18's but seeing all the 8" wheels in this thread really has me tempted....
  #910
Old 07-03-2016, 06:58 PM
mini coop's Avatar
mini coop
For further consideration when trying to fit an 18"x8" inch wide wheel if replacing stock wheels: If a prospective wheel is the same width as the stock wheel, then the wheel will be pushed out only by the difference in offset. For instance, a 15x5.5 et35 will be 10mm further out when compared to a 15x5.5 et45 (45mm - 35mm = 10mm)
Factoring in extra width is a little more tricky. If the offsets are the same then the difference in width will be split evenly to the inside and outside. For instance, a 15x6.5 et45 will be ½" closer to the fender edge & ½" closer to the strut in the inside than a 15x5.5 et45.
Now, if the offset is different, that is then added (or subtracted if the offset is higher) to the outer movement. So a 15x6.5 et35 will be ½" (± 12.5mm) + 10mm (offset difference) = 22.5mm closer to the fender.
  #911
Old 08-02-2016, 08:39 PM
MiniF55's Avatar
MiniF55
MiniF55 is offline
Japan Power
Can't wait til Friday. I'll be part of he 18x8 club!!! Woot woot!
  #912
Old 08-05-2016, 07:09 PM
MiniF55's Avatar
MiniF55
MiniF55 is offline
Officially part of the club!
18x8+50
225x40x18
  #913
Old 08-21-2016, 05:57 PM
ayypeeemm's Avatar
ayypeeemm
ayypeeemm is offline
Originally Posted by Dr. Spade
Those look great.
I was wondering this same thing. C4's are 17x8 ET 45. When you add them to your cart it says "Aggressive fitment. Will require fender modification for proper clearance."
Anyone have any photos of this size wheel? I tried willtheyfit.com and it says it will stick out about .85 inches and be .6 inches closer to the strut. (11 r56s on stock suspension)
  #914
Old 08-24-2016, 01:38 PM
Dr. Spade's Avatar
Dr. Spade
Yea I'm more concerned with inner clearance. I know when I had 215 Federal RSRs (they run wide) on stock 7s they'd eat away lining on the inside front at full turn lock.
So I'd run 215's on these rather than 225. Still, I'd rather have a more aggressive offset, perhaps 40.
  #915
Old 09-02-2016, 09:41 AM
Speedpost's Avatar
Speedpost
Speedpost is offline
Hi guys, I'm having a year 2008 clubman S and Would like to seek your opinion if the follow set up can be used with little modification to the car:
17" Staggered setup Front 8,5 and Rear 9,5
Et13 and 25.
I read the whole thread however unable to find any information if it fits.
Thanks in advance
  #916
Old 09-02-2016, 10:46 AM
miniuy's Avatar
miniuy
miniuy is offline
Et13 and 25.
Thanks in advance
17X8.5 ET 13 and 17x9.5 ET 25?
It should look so good.
ET 30 was enough for me to start fixing rubbing issues
  #917
Old 12-09-2016, 07:54 PM
Bnourai's Avatar
Bnourai
Bnourai is offline
hi, I was looking at the XXr 530's xtreem concave and liked them very much so I called the vendor the gentleman was trying so hard to sell me a set of 17x9.75's et25 that will stick out about 2inches on my 2009 mcs, they do also offer the 17x8.25 etc 25, my car has eBach lowering springs so I am about an inch over my current 17x7's, I do have rear sway and adjustable on the car.with 9.75 I will need 18.1mm space on the inner side to clear the rear struts, will I have it.
Please chime in before I make a final decision.
Thx
Ben
  #918
Old 12-10-2016, 03:03 AM
njaremka's Avatar
njaremka
njaremka is offline
Received 1,739 Likes on 1,396 Posts
I have a 2012 Clubman S. Tire Rack has TR Motorsports C4 wheels in a 17x8 +45, and I want to run 215/45-17 tires. How tight is the fitment really going to really be? The 215/45 tire is only one step up from the OEM tire, same with the wheel. Are the Mini wheel wells really that tight to the OEM size that a performance wheel is going to take up that much more room?
  #919
Old 12-13-2016, 05:09 AM
miniuy's Avatar
miniuy
miniuy is offline
For wheels up to 18' I think the offset is the problem.
It should not be less than 35/40.
With a lower offset the rubbing issues will start but the aesthetics starts to get awesome
  #920
Old 01-10-2017, 03:28 PM
Bnourai's Avatar
Bnourai
Bnourai is offline
so i went with 17x8.25 et 22 and stretched rear tire 215/45/17 and front 205/45/17 looks great but as its been said i have a rear rubbing a little, so next week i will have the rear camber set since i have adjustable control arms.
  #921
Old 01-11-2017, 05:54 AM
miniuy's Avatar
miniuy
miniuy is offline
That looks really very nice! Congrats!
Do you think about "opening" a little the metal lip under the plastic cover to avoid too much camber change?
  #922
Old 01-11-2017, 05:37 PM
Bnourai's Avatar
Bnourai
Bnourai is offline
Yes actually as soon as I get my roller in.
Ben
Btw:my JCW 17x7 mint condition will be up for sell if anyone is intrested.
  #923
Old 01-12-2017, 05:22 AM
MrBlah is offline
just put 15x8s on my r53, with 225/45/15 rs3s, 10mm spacers all around +36 949racing wheels I had coilover rub without the spacers on front, and in the back the trailing arm was too close for comfort, I could go with 2mm minimum but went 10 to keep it even
No rub, but I'm on KW colivers with 9kg swift up front and 8kg swift in back, not much body roll I dunno what I would have to hit to get rub but it would be something bad lol
  #924
Old 01-12-2017, 12:26 PM
miniuy's Avatar
miniuy
miniuy is offline
Are you running 8 inch wheels with +26 offfset (36-10)?
It is a too lower offset, surely you need a camber adjustment and some roll to avoid rubbinf on a bumpy zone
  #925
Old 01-12-2017, 12:40 PM
Bnourai's Avatar
Bnourai
Bnourai is offline
So I had my VIS hood that I was waiting for a free time to add to the car.they make great carbon products.I think that there is too much meet on those tires so I may go with 215/40/17 tires vs 45's and lower the car a little bit more.
Ben
Attached Thumbnails Roll call - 8&quot;+ wide wheels-20170112_100104.jpg   Roll call - 8&quot;+ wide wheels-20170112_100129.jpg   Roll call - 8&quot;+ wide wheels-20170112_100203.jpg
Quick Reply: Roll call - 8"+ wide wheels
