FS:: Various parts F56
Old 09-30-2018, 01:28 PM
minicooperjp's Avatar
minicooperjp
minicooperjp is offline
Various parts F56
Category: Interior
Price: $1
Location (Region): Midwestern
8.8” Display - $250
Automatic Shifter $60
Start button assembly- $50
Cooper S Trim for hidden compartment $50
Cottonwood trim passenger $70
NBT Evo wire -$40
WiFi/Bluetooth Antenna $15
HUD - $150
Attached Thumbnails Various parts F56-screen-shot-2018-09-30-at-1.24.15-pm.png   Various parts F56-screen-shot-2018-09-30-at-1.24.19-pm.png   Various parts F56-screen-shot-2018-09-30-at-1.24.22-pm.png   Various parts F56-screen-shot-2018-09-30-at-1.24.26-pm.png   Various parts F56-screen-shot-2018-09-30-at-1.24.30-pm.png
Various parts F56-screen-shot-2018-09-30-at-1.24.34-pm.png   Various parts F56-screen-shot-2018-09-30-at-1.24.43-pm.png   Various parts F56-screen-shot-2018-09-30-at-1.24.46-pm.png   Various parts F56-screen-shot-2018-09-30-at-1.25.03-pm.png   Various parts F56-screen-shot-2018-09-30-at-1.25.13-pm.png
Old 09-30-2018, 01:31 PM
tylerhunter's Avatar
tylerhunter
tylerhunter is offline
Can you use the display in the base radio?
Old 09-30-2018, 01:37 PM
minicooperjp
Unfortunately no, you would need to change head units in order to do that. This display is for people wanting to retrofit the navigation into their Minis or upgrade from the 6.5" display.
Old 10-01-2018, 08:47 PM
GStacks69's Avatar
GStacks69
GStacks69 is offline
I want that 8.8. But have no idea how to retro fit. Can u help?
Old 10-02-2018, 07:12 PM
mcaanda's Avatar
mcaanda
mcaanda is offline
Question
Interested in the HUD - is there a way to retrofit that into a 15 MCS that does not have one?
Thanks!
Old 10-02-2018, 07:36 PM
minicooperjp
It can be retrofitted as I’ve seen it on YouTube but don’t really know how complicated it is, bought it cause I had found it as a great deal for $300 but I went with my navigation retrofit instead and haven’t had much time to figure it out.
Old 10-03-2018, 03:09 PM
bratling's Avatar
bratling
bratling is offline
Super Moderator
Originally Posted by mcaanda
Interested in the HUD - is there a way to retrofit that into a 15 MCS that does not have one? Thanks!
Yes, I've looked into this in the past and it's reasonably straightforward, if you're handy with MINI/BMW electrical systems already. I would not choose it as my first project, though.
Mechanically, you'll need to buy a plastic trim panel that goes on top of the dash (the HUD system, of course, being below), cut a hole, and bolt the HUD into place. This will require removing the dash panel so you can get underneath for the install.
That's the easy part — you'll also need to either find or fabricate a connector and wiring harness to tap into the existing vehicle wiring somewhere. There is one wire that connects directly to the instrument cluster on the steering column using a 6-pin connector. It's a bit odd. 4 conductors head off to a 4-pin connector on the cluster, one of them heads to one of the other connectors (and you'll need to add the receiver and wire it in), and the last heads off to a connector at the fuse box. (And there's a 7th on the wiring diagram … which appears to go to ground, but I'm not sure from which connector.) So, yeah, you'll have some work to do getting the wiring set up.
Start here, and read everything:
https://www.newtis.info/tisv2/a/en/f...ad-up-display/
Here's the wiring diagram – blue figures are clickable links to more info about the connectors referenced:
https://www.newtis.info/tisv2/a/en/f...1VnXUDgnfW.svg
mcaanda (10-03-2018)
Old 10-04-2018, 12:05 AM
Phenotis's Avatar
Phenotis
Phenotis is offline
how difficult is it to retrofit the larger screen? I have the 6.5" one and was thinking of upgrading to this and retrofitting the nav.
Old 10-04-2018, 05:03 AM
bratling's Avatar
bratling
bratling is offline
Super Moderator
At this point I’ll direct you to the forums for discussing this. We’ve hijacked a marketplace post. Sorry, JP!
https://www.northamericanmotoring.co...and-audio-431/
https://www.northamericanmotoring.co...fications-432/
Old 10-04-2018, 03:17 PM
minicooperjp
All good! The more info, the better for everyone
Old 12-10-2018, 12:11 PM
tilt's Avatar
tilt
tilt is offline
might be a stupid question, but what is the wifi/bluetooth antenna for?
Alpha Motoring
09-08-2015 07:15 AM
skitelluride531
03-24-2007 06:34 AM
weezer2282
03-09-2007 05:56 AM
calypson
17
02-22-2007 03:25 AM
Quick Reply: FS:: Various parts F56
