R60 What did you do to your Countryman TODAY?
Old 03-08-2018, 05:50 AM
Received 1,998 Likes on 1,794 Posts
Nice and well done.
Just talked to someone who helped produce the suspension to that WRC MINI. It was all custom and had custom front knuckles/carriers. Cant tell you who just yet.
Originally Posted by AWD_Rally
BC Racing custom coilovers are finally installed. Swift springs, 8k f/ 9k r. Also installed the 25mm M7 RSB. Almost done with the suspension. Need to raise the front about an inch or so and then add a little more negative camber to the front to clear the inside fenders a little better. We trimmed the hell out of the rear area to get them wheels and tires to fit.
Wheel setup: 17x8.5" et40 with 245/45-17 tires.
FYI on the coilovers, they were about 23 lbs lighter than the OE suspension. I was actually super surprised, I would've been happy with evening out. As far as the weight reduction goal with this car, that helped me get a lot closer sooner than I thought.
Beyond the suspension I want to finish up with the exterior. Change all chrome to matte black, also get the inside of the headlights painted black, possibly with some gold/bronze accents along with the black to match the colors of my company.
I've had a red Sparco EVO seat for about 4 years... I might install that as well, that'll drop about another 20 lbs off the car. Which would put my ALL4 at around 2900 lbs, or 300+ pounds lighter than stock. Nice thing is that it will match the interior panels of my car, so that works out if I do do that. Anyways, here are some pictures. I'll take better ones once the suspension is at 100% of what I want.
Going for a MINI WRC look as far as my aggressive stance goes.
  #2702
Old 03-08-2018, 06:48 AM
MannyJimenez's Avatar
MannyJimenez
MannyJimenez is offline
Originally Posted by iwashmycar
Throw down $130 or so and get the JCW front lip piece. Well worth it
I second this
BTW, i have a set of the Firestone Indy 500 Summer Performance Tires and I wuv them
  #2703
Old 03-08-2018, 06:58 AM
We have two people that bought Countrymans here and that was like there first OEM+ mod.
  #2704
Old 03-08-2018, 10:07 AM
AWD_Rally's Avatar
AWD_Rally
AWD_Rally is offline
This might sounds crazy, but I'm not a huge fan of the JCW front lip. lol. Maybe I need to see it in person again, it's been a couple years. Where did you get yours?
I want to make a custom one thats a little more simple, similar to the WRC car. Purpose build without too much flash.
  #2705
Old 03-09-2018, 05:11 AM
iwashmycar's Avatar
iwashmycar
iwashmycar is offline
ECS. I realize it isnt the greatest look ever, but lowered it helps...and it IS still better than the standard no lip IMO. I think even using the JCW lip to add a small splitter under is a good plan. The WRC car is a racecar. Got to be careful it doesnt look like you went all Home Depot on it being a street car.
  #2706
Old 03-09-2018, 07:00 AM
AWD_Rally's Avatar
AWD_Rally
I'll have to check it out in person again. I've modified a couple STIs, a couple M3s, a 1969 Mustang and even a Harley in the past and they've always been sharp looking. I always find a pro to make sure what I do to the exterior looks clean, I've always been about custom parts because I'm complicated like that.
  #2707
Old 03-10-2018, 02:51 PM
AWD_Rally's Avatar
AWD_Rally
Set the height to something more functional. Had to raise the front a little to compensate for the 3" exhaust. I'll need to get the exhaust tightened up in there, then I'll lower the car another .5 to 1 inch again.
Also fixed the extreme camber in the rear, it was set at -3.2 to compensate for the rubbing against the metal frame by the rear door. I had an awesome wheel shop cut it all off and weld it back together. No more rubbing there. I also trimmed the inside fenders, both the metal bracket and plastic. That opened up about 1" of space, which allowed me to set the rear camber at -2 degree with zero rubbing. Probably could go to -1.5, but I like the aggressive look. I also set the front camber to -2.2 degree. With the 25mm RSB the car feels it really balancing it all out.
Anyways, here's the updated pic with the new height and trimming, but before the new alignment. I'll take some better ones once the rain stops.
  #2708
Old 03-13-2018, 09:26 AM
AWD_Rally's Avatar
AWD_Rally
Nice and well done.
That suspension is pretty awesome and tough setup, only seen pictures though. That rear MacPherson setup is really cool... I want it.
  #2709
Old 03-13-2018, 09:54 AM
Well its Ohlins, i can tell you now as we carry there line. It was a custom motorsport R60 design, they dont have a direct fit R60/R61 kit yet.
  #2710
Old 03-13-2018, 10:32 AM
AWD_Rally's Avatar
AWD_Rally
Eye spy...
I'd be happy with the rad, IC and intake manifold setup.
  #2711
Old 03-13-2018, 11:11 AM
That be it! Prodrive did a lot of the other items.
  #2712
Old 03-13-2018, 11:55 AM
AWD_Rally's Avatar
AWD_Rally
I'm dreaming, but damn would it be cool to go for a ride in one of those... and loud.
  #2713
Old 03-14-2018, 09:28 AM
MannyJimenez
Eye spy...
I want that hood.
Holy Crap! Look at those top mounts for the front shocks and why does that engine bay look like it has so much room.
  #2714
Old 03-14-2018, 10:36 AM
iwashmycar's Avatar
iwashmycar
The whole front end is tubular...so lots of room. Its safe, but not "production-car-crumple-zone-safe"
  #2715
Old 03-14-2018, 12:27 PM
AWD_Rally's Avatar
AWD_Rally
Originally Posted by MannyJimenez
I want that hood.
ECU is in the passenger footwell, Rad/IC is moved more forward on the chassis, wire harness is out of the way, no firewall plastic, engine is slightly titled away from the front and so much more...
  #2716
Old 03-14-2018, 01:48 PM
B2FiNiTY's Avatar
B2FiNiTY
B2FiNiTY is offline
How are you planning on putting in the sparco seat? I haven't been able to find any solutions to mount some recaros in the car.
Custom rails and brackets? Planted has some brackets but only for R56. Maybe it can be modded?
  #2717
Old 04-13-2018, 07:16 AM
iwashmycar's Avatar
iwashmycar
Front wheel bearing is ROARING. Probably due to the same pothole that prompted wheel change.
Reserved two locally for ~$275 :( , so looks like my weekend plans are set. Hopefully they go smoothly. Relatively young car at 54K.
  #2718
Old 04-13-2018, 03:52 PM
AWD_Rally's Avatar
AWD_Rally
I believe the R56 brackets will fit the CM chassis.
  #2719
Old 04-15-2018, 06:48 PM
Snickerdoodle's Avatar
Snickerdoodle
Snickerdoodle is offline
Well.. It wasn't today, but yesterday. Installed the milltek turbo back exhaust on my Sheldon. Sounds amazing, not "tinny" at all. Really nice and throaty.
View this post on Instagram
  #2720
Old 04-15-2018, 07:18 PM
Jermajerm's Avatar
Jermajerm
Jermajerm is offline
Have you changed a hub on a countryman before? Did one last weekend. Didn't go so smooth as one of the bolts holding the hub is a ***** to get off and deal with in general. Pretty amazing once you're done though. Buttery smooth now.
  #2721
Old 04-15-2018, 08:38 PM
AWD_Rally's Avatar
AWD_Rally
Getting closer. Switching out the 12 blade for the tall 9 blade turbine for the 50mm turbo build. Had some custom parts that arrived for the cold side aluminum IC piping I'll be making.
Vibrant Hi-flow cat also showed up this past Friday.
  #2722
Old 04-16-2018, 04:56 AM
iwashmycar's Avatar
iwashmycar
Yeah, I hadnt before, but figured out a couple tricks to get in there. Made a little thread for future searchers
https://www.northamericanmotoring.co...-bearings.html
  #2723
Old 04-16-2018, 08:51 AM
Video
Thats great, that exhaust is so rare on the Countryman and Milltek just NLA'd both systems for the Countryman.
  #2724
Old 04-16-2018, 09:03 AM
Yep that's one of the old WRC cars. With the Ohlins one-off suspension.
  #2725
Old 04-16-2018, 09:44 AM
MannyJimenez
Finally added the Color Changing LED Headlight
Quick Reply: R60 What did you do to your Countryman TODAY?
