D Stock Shock Caps
Old Jan 25, 2007 | 02:56 PM
trick's Avatar
trick
Shock Caps
I've searched, but can't track down a specific answer.
Got the Konis installed today. But the dust caps for the fronts. The little round rubbery/plastic caps that keep dirt out? Those. The adjuster on the Koni is too tall to allow that to seat.
Do you guys just go without? That's legal for stock class?
TIA.
Old Jan 25, 2007 | 06:07 PM
welshmenwillnotyield's Avatar
Are you talking about covers for the "well" at the top of the strut towers? These caps used to be on eBay for a ridiculous price, but some guys found the same things for almost nothing at Home Depot.
Old Jan 26, 2007 | 06:30 AM
mitchman's Avatar
mitchman
I think you'll be fine. If someone protests for that, they'd get laughed out of the event.
Old Jan 26, 2007 | 06:35 AM
trick's Avatar
trick
So you just leave them off then. I was thinking about drilling a small hole to let the just the tip of the adjuster poke through.
Not as good as sealed, but better than wide open.
Old Jan 26, 2007 | 06:40 AM
mitchman's Avatar
mitchman
I guess if you drive in a lot of dirt and dust, that could get into the upper shock mount bearing, you might consider running a modified version of them. But I wouldnt' drill a hole in them. That's kind of permanent. I'd take one to Home Depot and see if you can find a taller version. Or maybe get one that covers the entire hole (the fenderwell).
Old Jan 26, 2007 | 06:43 AM
trick's Avatar
trick
Thanks man.
Old Mar 24, 2007 | 05:07 PM
JustGo4It_'s Avatar
JustGo4It_
Push a little harder, the stock caps fit.
RobbyD
Jan 29, 2019 01:22 PM
gar56
Nov 15, 2016 06:41 AM
Southern Marylander
Oct 1, 2015 07:53 AM
silence2-38554
Sep 28, 2015 12:19 PM
BMC_Kid
Sep 27, 2015 04:31 PM
